[GSoC] About the idea: Basic gegl based paint tool
12 of 12 messages available
[GSoC] About the idea: Basic gegl based paint tool Jenny 27 Mar 11:09
  [GSoC] About the idea: Basic gegl based paint tool Alexandre Prokoudine 27 Mar 11:28
   [GSoC] About the idea: Basic gegl based paint tool Jenny 27 Mar 12:26
    [GSoC] About the idea: Basic gegl based paint tool Martin Nordholts 27 Mar 13:02
     [GSoC] About the idea: Basic gegl based paint tool Jenny 27 Mar 13:25
      [GSoC] About the idea: Basic gegl based paint tool Martin Nordholts 27 Mar 13:59
       [GSoC] About the idea: Basic gegl based paint tool Jenny 27 Mar 14:40
        [GSoC] About the idea: Basic gegl based paint tool Liam R E Quin 27 Mar 17:59
         [GSoC] About the idea: Basic gegl based paint tool Jenny 29 Mar 17:34
          [GSoC] About the idea: Basic gegl based paint tool Alexia Death 29 Mar 18:41
           [GSoC] About the idea: Basic gegl based paint tool Øyvind Kolås 29 Mar 19:46
    [GSoC] About the idea: Basic gegl based paint tool peter sikking 27 Mar 13:29
Jenny
2010-03-27 11:09:21 UTC (about 15 years ago)
Hi all,
On the idea list, the idea "Basic gegl based paint tool", is it means to write a GUI for gegl?
But as far as I know, gegl has had a GUI. Is my comprehension wrong?
Regards, Jenny
2010-03-27 11:28:27 UTC (about 15 years ago)
Not any more :)
Alexandre
Jenny
2010-03-27 12:26:02 UTC (about 15 years ago)
GEGL shipped an GUI application for test, with which user takes many OPs on the default image. But this application can not load images.
I want to write a user-friendly GUI for GEGL as my GSoC project. I think this application should provide many drag-able "block"s, where each block assigns an operation. User drags blocks and connects them to process image. Kinda like the simulink (http://en.wikipedia.org/wiki/Simulink).
Expecting feedback.
Thank you, Jenny
On Sat, Mar 27, 2010 at 6:28 PM, Alexandre Prokoudine < alexandre.prokoudine@gmail.com> wrote:
Not any more :)
Alexandre
Martin Nordholts
2010-03-27 13:02:15 UTC (about 15 years ago)
Expecting feedback.
IMHO, GEGL should only be a great image processing library, not an image processing library + an advanced UI tool. Also being the latter adds considerable maintenance and development burdens, making it harder to focus on the core functionality. It'd be fine to create an external project that has a GEGL dependency though, of course.
/ Martin
Jenny
2010-03-27 13:25:56 UTC (about 15 years ago)
Thanks Matin's feedback. :)
Another question: could developing a stand alone but gegl-based application be a GSoC project?
Thanks,
Jenny
Expecting feedback.
/ Martin
My GIMP Blog: http://www.chromecode.com/
"GIMP 2.8 development still under control"
peter sikking
2010-03-27 13:29:36 UTC (about 15 years ago)
I want to write a user-friendly GUI for GEGL as my GSoC project. I think this application should provide many drag-able "block"s, where each block assigns an operation. User drags blocks and connects them to process image. Kinda like the simulink (http://en.wikipedia.org/wiki/Simulink ).
Expecting feedback.
the graph/boxes and hoses/visual programming metaphor will one day be in GIMP, because we have 'researching cutting edge image algorithms' in the vision.
but it is certainly not how I see anybody creative or production working. that is much more hands-on, a continuation of the way you see right now in GIMP: hand-tools, a free combination of selections + filters/operations + layer techniques.
the graph thing can be added _after_ all of these normal things have been adapted to GEGL.
--ps
Martin Nordholts
2010-03-27 13:59:39 UTC (about 15 years ago)
I'm not a GSoC authority, but my guess is "no".
/ Martin
Jenny
2010-03-27 14:40:11 UTC (about 15 years ago)
But... it is on the idea list, names "Basic gegl based paint tool".
/ Martin
Liam R E Quin
2010-03-27 17:59:36 UTC (about 15 years ago)
It's on the idea list for gimp - i.e. a gimp paint tool that's based directly on gegl, I would think was meant. Maybe one that lets you apply gegl operations to a brush-sized area as yo u"paint", rather like brushes in Krita (a KDE drawing/painting program).
There's a certain amount of flexibility around the GIMP projects, but I rather think they do actually have to involve GIMP :-)
Liam
Jenny
2010-03-29 17:34:51 UTC (about 15 years ago)
Here is my draft proposal
https://docs.google.com/Doc?docid=0ARZjTPkuA386ZGRmY3JteG1fOTRoZmJ4cm1keg&hl=en
thanks, Jenny
Liam
-- Liam Quin - XML Activity Lead, W3C, http://www.w3.org/People/Quin/ Pictures from old books: http://fromoldbooks.org/ Ankh: irc.sorcery.net irc.gnome.org www.advogato.org
Alexia Death
2010-03-29 18:41:37 UTC (about 15 years ago)
https://docs.google.com/Doc?docid=0ARZjTPkuA386ZGRmY3JteG1fOTRoZmJ4cm1keg&hl=en thanks,
Jenny
No, that was not even in the same ballpark as the idea. Integration with gimp was said to be optional but the project is for a paint tool in gimp sense. Like paintbrush tool or airbrush tool using gegl as the back end. The aim of this idea is the creation of that back end with optional GIMP integration. That back end should support paths with outputs and rendering of those paths either using stamping of a bitmap or some other sort of creation of a stroke(for example the kind ink tool in gimp uses now). Essentially an implementation of paint core in gegl.
Øyvind Kolås
2010-03-29 19:46:27 UTC (about 15 years ago)
Jenny
Note that there already is code in GEGL that could serve as a starting point/inspiration that does stroking of paths using bitmaps/potato stamps with a procedurally generated brush, as well as a minimal experiment testing it. Since performance of GEGL based things in GIMP is going to be hampered by the lack of native use of GeglBuffers it probably makes sense to also be able to experiment with such new infrastructure outside GIMP.
