push/pull problems
10 of 15 messages available
push/pull problems Kolbjørn Stuestøl 19 Mar 12:03
  push/pull problems Roman Joost 24 Mar 02:24
4BA7A7F1.7060701@stuestoel.no 07 Oct 20:29
  push/pull problems Kolbjørn Stuestøl 23 Mar 13:19
   push/pull problems Claude Paroz 23 Mar 21:52
    push/pull problems Kolbjørn Stuestøl 23 Mar 22:44
     push/pull problems Claude Paroz 23 Mar 23:41
      push/pull problems Kolbjørn Stuestøl 24 Mar 12:30
       push/pull problems Kolbjørn Stuestøl 24 Mar 18:23
        push/pull problems Roman Joost 26 Mar 10:16
         push/pull problems Kolbjørn Stuestøl 26 Mar 15:56
4BA7585C.7090407@stuestoel.no 07 Oct 20:29
598e9211003220459r45697819x... 07 Oct 20:29
4BA762CB.5080109@stuestoel.no 07 Oct 20:29
598e9211003220626m2ced0479j... 07 Oct 20:29
Kolbjørn Stuestøl
2010-03-19 12:03:00 UTC (about 15 years ago)
push/pull problems
When trying to pull or push files from/to server I get the following message:
$ git push
ssh: connect to host stuestoel.no port 22: Connection timed out fatal: The remote end hung up unexpectedly
According to what said in live.gnome.org/TranslationProject/GitHowTo my account is accepted. I.e. the command ssh -v MYUSERNAME@git.gnome.org returns what expected.
I do not know what "host stuestoel.no" is. (Assuming GNOME has nothing to do on my home site www.stuestoel.no). I think I have given a wrong command somewhere, but what do I have to do to correct it?
My config file is
$ git config -l user.name=Kolbjørn Stuestøl
user.email=kolbjoern@src.gnome.org color.ui=auto
remote.origin.url=ssh://kolbjoern@stuestoel.no/git/gimp-help-2 core.repositoryformatversion=0
core.filemode=true
core.bare=false
core.logallrefupdates=true
core.ignorecase=true
remote.origin.fetch=+refs/heads/*:refs/remotes/origin/* remote.origin.url=ssh://kolbjoern@git.gnome.org/git/gimp-help-2 branch.master.remote=origin
branch.master.merge=refs/heads/master
BTW: Why is the remote.origin.url defined twice? Kolbjoern
Kolbjørn Stuestøl
2010-03-23 13:19:41 UTC (about 15 years ago)
push/pull problems
Invalid .doap fil?
Finally I get through, resulting in another problem ;-) "git push" results in this return message:
$ git push Counting objects: 848, done. Compressing objects: 100% (435/435), done. Writing objects: 100% (486/486), 219.00 KiB | 13 KiB/s, done. Total 486 (delta 255), reused 4 (delta 0) ---
ERROR: gimp-help-2.doap is not valid: Invalid foaf:mbox property should be a mailto: URL
Please see: http://live.gnome.org/MaintainersCorner#maintainers ---
To ssh://kolbjoern@git.gnome.org/git/gimp-help-2 ! [remote rejected] master -> master (pre-receive hook declined) error: failed to push some refs to 'ssh://kolbjoern@git.gnome.org/git/gimp-help-2'
I have not changed the .doap file. Compared the gimp-help-2.doap to the one on the web site mentioned and found of course no difference in the setup. I do not believe the error is in the .doap file as others obviously are using it without problem and I have not changed it.
The steps before the "git push":
*** Validating XML (nn) ... nn: no errors.
$ git add .
$ git commit -m "Updated Norwegian translation" [master 075746b] Updated Norwegian translation 1 files changed, 1 insertions(+), 8 deletions(-)
Checked the http://git.gnome.org/browse/gimp-help-2/ in case of newer updates. None.
Some help?
Kolbjoern
Claude Paroz
2010-03-23 21:52:02 UTC (about 15 years ago)
push/pull problems
Le mardi 23 mars 2010 à 13:19 +0100, Kolbjørn Stuestøl a écrit :
Invalid .doap fil?
$ git add .
Never, never do that. You might have untracked files (generated by some operation) or files automatically changed for any reason (e.g. you host files on a FAT32 partition). 'git status' will tell you about that. Then 'git add' selected files that you purposely changed.
HTH,
Claude
Kolbjørn Stuestøl
2010-03-23 22:44:41 UTC (about 15 years ago)
push/pull problems
Claude Paroz skreiv:
Invalid .doap fil?
$ git add .
Never do what? Change the .doap file or whatever?
HTH,
Claude
I have run the "git status" but omitted it in the listing above because I do not understand what it tells me. I obviously have to study the git sites a bit more. The last thing I did before "git push" was as listed. ("git add ." --- "git status" --- "git commit"). Kolbjoern
Claude Paroz
2010-03-23 23:41:47 UTC (about 15 years ago)
push/pull problems
Invalid .doap fil?
$ git add .
Never do "git add .". Basically, this command tell gits that all modified/new files in the checkout should be added in the next commit. In most of cases, this will add too much unwanted stuff (like the .doap file you never intended to modify).
It is better to add selectively the files you know you want to be committed. (e.g. git add po/sv/gimp.po)
Claude
Roman Joost
2010-03-24 02:24:38 UTC (about 15 years ago)
push/pull problems
Hi Kolbjørn,
My config file is
remove that ^
You may have set one globally by accident?
Cheers,
Kolbjørn Stuestøl
2010-03-24 12:30:03 UTC (about 15 years ago)
push/pull problems
Claude
Thank you Claude and Roman
I'll work further on these tips. Hoping to succeed some day. Kolbjoern
Kolbjørn Stuestøl
2010-03-24 18:23:09 UTC (about 15 years ago)
push/pull problems
At last I got through.
Thank you Claude, Roman, and Julien.(private mails) and to Ulf for changing the gimp-help-2.doap file.
As I am the only Norwegian translator, I have time to correct any mistakes or mash ups :-)
I do not know what went wrong at the first place and how I corrected it. I just removed all new git files from my folders and started from scratch again.
Kolbjoern
Roman Joost
2010-03-26 10:16:55 UTC (about 15 years ago)
push/pull problems
While you're saying that, I'll sometimes use:
git clean -x -d -f
to remove all files which were generated during the setup or install process to start from scratch. Keep in mind before executing that this will also wipe all unknown files to git from the directory, including your working version you haven't committed ;)
Cheers,
Kolbjørn Stuestøl
2010-03-26 15:56:48 UTC (about 15 years ago)
push/pull problems
Roman Joost skreiv:
git clean -x -d -f
Cheers,
Oh, should have known this command before :-) Much better and faster than my handwork. I save the tip for future use. It will come ;-). Another reason for reading the git handbook more carefully. Kolbjoern
