Problems building git version
Problems building git version Emil Assarsson 17 Mar 22:49
  Problems building git version Michael Natterer 18 Mar 11:28
   Problems building git version Emil Assarsson 18 Mar 20:12
    Problems building git version Martin Nordholts 18 Mar 20:14
     Problems building git version Emil Assarsson 18 Mar 20:27
Emil Assarsson
2010-03-17 22:49:25 UTC (about 15 years ago)
I can't build Gimp from the git:
Making all in libgimpwidgets make[2]: Entering directory `/home/emil/gimp-build/gimp/libgimpwidgets' CC gimpstock.lo
gimpstock.c:394: error: ‘stock_input_device_22’ undeclared here (not in a function)
gimpstock.c:521: error: ‘stock_input_device_16’ undeclared here (not in a function)
gimpstock.c:521: error: initializer element is not constant gimpstock.c:521: error: (near initialization for ‘gimp_stock_menu_pixbufs[24].inline_data’) make[2]: *** [gimpstock.lo] Fel 1
make[2]: Leaving directory `/home/emil/gimp-build/gimp/libgimpwidgets' make[1]: *** [all-recursive] Fel 1
make[1]: Leaving directory `/home/emil/gimp-build/gimp' make: *** [all] Fel 2
Do I need to upgrade xorg or something?
Michael Natterer
2010-03-18 11:28:40 UTC (about 15 years ago)
No, you need to *always* use autogen.sh and *never* configure directly when you build from git (as opposed to tarball).
--mitch
Emil Assarsson
2010-03-18 20:12:28 UTC (about 15 years ago)
Thank you! it worked like a charm...
git pull ./autogen.sh
--mitch
Martin Nordholts
2010-03-18 20:14:46 UTC (about 15 years ago)
On 03/18/2010 08:12 PM, Emil Assarsson wrote:
make distclean #
If you want a greater feeling of satisfaction, run
git clean -xdf
instead. Warning: removes all unversioned files
I never run make distclean...
/ Martin
Emil Assarsson
2010-03-18 20:27:15 UTC (about 15 years ago)
Quite useful :-) Thanks!
make distclean #
  git clean -xdf
 / Martin
My GIMP Blog: http://www.chromecode.com/
"Multi-column dock windows and 2.8 schedule" _______________________________________________ Gimp-developer mailing list
