prototype Inspect plugin uploaded to Gimp registry, re gimp_env_init() abort
prototype Inspect plugin uploaded to Gimp registry, re gimp_env_init() abort lloyd konneker 17 Mar 15:36
lloyd konneker
2010-03-17 15:36:41 UTC (about 15 years ago)
I uploaded a prototype of an "Inspect" plugin to the gimp registry.
Refer to a previous thread about gimp_env_init() and a proposed patch.
If I get encouragement and the proposed patch to GIMP-Python is approved, I might continue development.
I think this plugin fits the Gimp practice of keeping documentation in the code.
From the README file:
A Gimp plugin that lets plugin programmers view documentation for PDB procedures, GIMP-Python modules, plugins and modules written in Python, and image data. The documentation is live, generated from the code itself and from the current state of GIMP and the PDB.
Installation:
Copy plugin-inspect.py and the inspector directory to your own, local plugin directory. Make plugin-inspect.py executable. See a comment in plugin-inspect.py for Linux commands.
Version:
This is an alpha version, a proof-of-concept, a work in progress. It works, and shouldn't crash. It is released for comments about the features and about the GUI.
This alpha version asks:
1) whether Gimp Python plugin programmers need an inspector, a unified way to browse internals.
2) whether pydoc documentation for Gimp plugins and Gimp-Python is worthwhile. If so, Gimp needs to be patched to allow plugins to be reimported by pydoc without aborting with the message "gimp_env_init() must only be called once." Refer to a discussion on gimp-dev mail list.
You won't see the crash from this version since this version explicitly only documents a few plugins (itself) that are safe from this crash, i.e. that guard the call to main() so that it is only called if the script is imported at the top level.
3) whether to migrate Help>Browse Plugins etc. from C to Python and Glade.
Discussion:
Uses Glade3 graphical GUI designer and pygtk (requires gtk+ 2.16).
Duplicates the existing Gimp menu items "Help>Browse Plugins" and "Help>Browse Procedures".
Documents python language plugins and modules (including GIMP-Python) using the pydoc module (distributed with python, the official way to produce documentation from python code.)
Its data driven. Other views of the data could be added, for example to view plugins by directory path.
