gegl-0.1.2 test failures on IRIX/MIPSpro
gegl-0.1.2 test failures on IRIX/MIPSpro Stuart Shelton 15 Mar 13:21
Stuart Shelton
2010-03-15 13:21:54 UTC (almost 15 years ago)
After building successfully gegl's test-suite fails with the following output when built on MIPS/IRIX with the platform MIPSpro compilers (latest release: 7.4.4m):
Making check in gegl Making check in buffer
make[2]: Nothing to be done for `check'. Making check in graph
make[2]: Nothing to be done for `check'. Making check in module
make[2]: Nothing to be done for `check'. Making check in operation
make[2]: Nothing to be done for `check'. Making check in process
make[2]: Nothing to be done for `check'. Making check in property-types
make[2]: Nothing to be done for `check'. make[2]: Nothing to be done for `check-am'. Making check in operations
Making check in affine
make[2]: Nothing to be done for `check'. Making check in core
make check-local
make[3]: Nothing to be done for `check-local'. Making check in common
Making check in perlin
make[3]: Nothing to be done for `check'. make check-local
make[4]: Nothing to be done for `check-local'. Making check in generated
make check-local
make[3]: Nothing to be done for `check-local'. Making check in external
make[2]: Nothing to be done for `check'. make[2]: Nothing to be done for `check-am'. Making check in bin
make[1]: Nothing to be done for `check'. Making check in tools
make[1]: Nothing to be done for `check'. Making check in examples
Making check in data
make[2]: Nothing to be done for `check'. make[2]: Nothing to be done for `check-am'. Making check in tests
make check-am
make buffer-test
make[4]: `buffer-test' is up to date. make check-TESTS
36 of 36 tests succesful.
PASS: buffer-tests-results.sh
1 test passed
Making check in compositions
make[3]: Nothing to be done for `check'. make check-TESTS
make[4]: Entering directory `gegl-0.1.2/tests/compositions'
Failed to open ./reference/clones.png Failed to open ./reference/downsharptest.png Failed to open ./reference/downsizetest.png Failed to open ./reference/downsmoothtest.png Failed to open ./reference/reflect2.png Failed to open ./reference/reflect.png Failed to open ./reference/rotate.png Failed to open ./reference/simple-scale.png Failed to open ./reference/upsharptest.png Failed to open ./reference/upsizetest.png Failed to open ./reference/upsmoothtest.png -------------------------
0 of 11 tests succesful.
FAIL: verify-results.sh
1 of 1 test failed
make[4]: *** [check-TESTS] Error 1
make[4]: Leaving directory `gegl-0.1.2/tests/compositions' make[3]: *** [check-am] Error 2
make[2]: *** [check-recursive] Error 1 make[1]: *** [check-recursive] Error 1 make: *** [check-recursive] Error 1
Instructing make to continue after errors have occurred results in the following additional output:
make check-TESTS make[3]: Entering directory `gegl-0.1.2/tests'
** (test-change-processor-rect:31370014): WARNING **: Failed to set operation type gegl:text, using a passthrough op instead
** (test-change-processor-rect:31370014): WARNING **: Failed to set operation type gegl:text, using a passthrough op instead PASS: test-change-processor-rect
PASS: test-proxynop-processing
PASS: test-color-op
PASS: test-gegl-rectangle
All 4 tests passed
I don't know whether the 'passthrough' warning is significant or not (although it doesn't sound good), or why the opening of the above files (which do exist and have reasonable permissions) is failing.
Note that this gegl is built against the most-likely-broken babl I sent an email about earlier, which complains about non-symmetric transforms.
Cheers,
Stuart
