Split complex po files into separate po?
Split complex po files into separate po? jhardlin 19 Feb 07:35
jhardlin
2010-02-19 07:35:40 UTC (about 15 years ago)
Translators working with Vertimus need to transform their po files to html, not using git and the gimp-help-2 module. It is possible to do that, (also under Windows), with simple po files (po files from only one xml file):
1 - Transforming po to xml with xml2po -e -p translatedFile.po -o name.xml englishFile.xml
2 - Transforming xml to html, using stylesheets found in gimp-help-2: xsltproc plainhtml.xsl name.xml
But this is not possible with our po files, built from several xml files. Would it be possible to have a program that splits our po files into several separate po files? ( common strings between several xml files may be a problem...)
Julien
