Para not translated
4 of 5 messages available
Para not translated Kolbjørn Stuestøl 15 Jan 21:02
  Para not translated Kolbjørn Stuestøl 16 Jan 17:21
   Para not translated Kolbjørn Stuestøl 16 Jan 18:10
   201001161832.28697.ude88@we... Ulf-D. Ehlert 16 Jan 18:32
    Para not translated Kolbjørn Stuestøl 18 Jan 21:00
Kolbjørn Stuestøl
2010-01-15 21:02:41 UTC (about 15 years ago)
Para not translated
One paragraph not translated.
The msgid starting with
"A Voronoi's diagram consists in partitioning a plane with n master points " in the file "filters/artistic.po" is not translated when running make xml-nn?
All other po files are translated as far as I have found out by now. What error or mistake do I have to look for? To me this file looks like all the others.
The filter/artistic.po is updated from the corresponding pot file.
Kolbjoern
Kolbjørn Stuestøl
2010-01-16 17:21:55 UTC (about 15 years ago)
Para not translated
Kolbjørn Stuestøl skreiv:
Found a second item not translated: In filters/generic.po the msgid starting with: "On a solid background, this filter can delete noise: "
They both have the image commands in common: etc. Something to do with the stylesheets or programs not recognizing these commands in paragraphs?
Someone fix it?
Kolbjoern
Kolbjørn Stuestøl
2010-01-16 18:10:22 UTC (about 15 years ago)
Para not translated
Someone fix it?
Ooops!
Found some more not translated items! Seems to have something to do with the stylesheets not recognizing some commands or keywords such as , , etc. Working further on it.
Of course if somebody in the meantime have an explanation I'll be thankful. I don't know if others have the same problem and in case why (not).
Kolbjoern
Kolbjørn Stuestøl
2010-01-18 21:00:54 UTC (about 15 years ago)
Para not translated
Ulf-D. Ehlert skreiv:
Kolbjørn Stuestøl (Saturday, 16. January 2010)
Maybe your po file is created with a different xml2po program than your pot file, and this led to slightly different translations (with/without ).
Then you should touch the relevant src files and re-make the po files.
HTH, Ulf
Yes, Ulf.
As usual you have the solution.
I have not verified all my files, but so far it looks like they are cured. However, the placeholders are back in business again. I therefore have to control all my html files for correct commas etc. I used the tools/xml2po.py version.
Thank you! Kolbjoern
