[PATCH] Use Glade + GtkBuilder for file-png.c save_dialog()
14 of 15 messages available
[PATCH] Use Glade + GtkBuilder for file-png.c save_dialog() Martin Nordholts 07 Jan 16:36
[PATCH] Use Glade + GtkBuilder for file-png.c save_dialog() Martin Nordholts 07 Jan 16:43
  [PATCH] Use Glade + GtkBuilder for file-png.c save_dialog() SHIRAKAWA Akira 07 Jan 17:05
   [PATCH] Use Glade + GtkBuilder for file-png.c save_dialog() Stephen Griffiths 07 Jan 17:19
  201001071732.01167.tneuer@i... Torsten Neuer 07 Jan 17:32
  [PATCH] Use Glade + GtkBuilder for file-png.c save_dialog() Sven Neumann 07 Jan 23:10
  [PATCH] Use Glade + GtkBuilder for file-png.c save_dialog() Martin Nordholts 08 Jan 15:29
   [PATCH] Use Glade + GtkBuilder for file-png.c save_dialog() Aurimas Juška 08 Jan 16:05
    [PATCH] Use Glade + GtkBuilder for file-png.c save_dialog() Martin Nordholts 08 Jan 16:07
     [PATCH] Use Glade + GtkBuilder for file-png.c save_dialog() Alexia Death 08 Jan 18:42
    [PATCH] Use Glade + GtkBuilder for file-png.c save_dialog() Liam R E Quin 08 Jan 20:51
    [PATCH] Use Glade + GtkBuilder for file-png.c save_dialog() Sven Neumann 08 Jan 21:39
  [PATCH] Use Glade + GtkBuilder for file-png.c save_dialog() peter sikking 09 Jan 11:21
   [PATCH] Use Glade + GtkBuilder for file-png.c save_dialog() Nils Philippsen 13 Jan 11:27
    [PATCH] Use Glade + GtkBuilder for file-png.c save_dialog() Jon Cruz 20 Jan 20:23
Martin Nordholts
2010-01-07 16:36:23 UTC (about 15 years ago)
As an experiment, use Glade + GtkBuilder for the save dialog in the PNG plug-in. The layout is as good as identical. Mnemonics work and strings are still translated.
configure.ac | 1 + plug-ins/Makefile.am | 1 + plug-ins/common/file-png.c | 202 ++++++++++++++----------------------- plug-ins/glade/.gitignore | 2 + plug-ins/glade/Makefile.am | 6 + plug-ins/glade/file-png.glade | 226 +++++++++++++++++++++++++++++++++++++++++ po-plug-ins/POTFILES.in | 1 + 7 files changed, 313 insertions(+), 126 deletions(-) create mode 100644 plug-ins/glade/.gitignore create mode 100644 plug-ins/glade/Makefile.am create mode 100644 plug-ins/glade/file-png.glade
diff --git a/configure.ac b/configure.ac index 6edf057..2d8229c 100644
--- a/configure.ac
+++ b/configure.ac
@@ -2004,6 +2004,7 @@ plug-ins/fractal-explorer/examples/Makefile plug-ins/gfig/Makefile
plug-ins/gfig/gfig-examples/Makefile plug-ins/gfig/images/Makefile
+plug-ins/glade/Makefile
plug-ins/gimpressionist/Brushes/Makefile plug-ins/gimpressionist/Makefile
plug-ins/gimpressionist/Paper/Makefile diff --git a/plug-ins/Makefile.am b/plug-ins/Makefile.am index fd62823..b045c92 100644
--- a/plug-ins/Makefile.am
+++ b/plug-ins/Makefile.am
@@ -69,6 +69,7 @@ SUBDIRS = \
flame \
fractal-explorer \
gfig \
+ glade \
gimpressionist \
gradient-flare \
help \
diff --git a/plug-ins/common/file-png.c b/plug-ins/common/file-png.c index 7f7c86f..faaf0fb 100644
--- a/plug-ins/common/file-png.c
+++ b/plug-ins/common/file-png.c
@@ -1768,21 +1768,35 @@ respin_cmap (png_structp pp,
+static GtkWidget *
+toggle_button_init (GtkBuilder *builder, + const gchar *name, + gboolean initial_value, + gboolean *value_pointer) +{
+ GtkWidget *toggle = NULL;
+ toggle = GTK_WIDGET (gtk_builder_get_object (builder, name)); + gtk_toggle_button_set_active (GTK_TOGGLE_BUTTON (toggle), initial_value); + g_signal_connect (toggle, "toggled", + G_CALLBACK (gimp_toggle_button_update), + value_pointer); +
+ return toggle;
static gboolean
save_dialog (gint32 image_ID,
gboolean alpha)
PngSaveGui pg;
GtkWidget *dialog;
- GtkWidget *table;
- GtkWidget *toggle;
- GtkObject *scale;
- GtkWidget *hbox;
- GtkWidget *button;
+ GtkBuilder *builder;
+ gchar *gladefile;
GimpParasite *parasite;
+ /* Dialog init */
dialog = gimp_export_dialog_new (_("PNG"), PLUG_IN_BINARY, SAVE_PROC); -
g_signal_connect (dialog, "response", G_CALLBACK (save_dialog_response), &pg);
@@ -1790,142 +1804,78 @@ save_dialog (gint32 image_ID, G_CALLBACK (gtk_main_quit), NULL);
- table = gtk_table_new (10, 3, FALSE); - gtk_table_set_col_spacings (GTK_TABLE (table), 6); - gtk_table_set_row_spacings (GTK_TABLE (table), 6); - gtk_container_set_border_width (GTK_CONTAINER (table), 12); - gtk_box_pack_start (GTK_BOX (gimp_export_dialog_get_content_area (dialog)), - table, TRUE, TRUE, 0); - gtk_widget_show (table);
- pg.interlaced = toggle =
- gtk_check_button_new_with_mnemonic (_("_Interlacing (Adam7)")); - gtk_table_attach (GTK_TABLE (table), toggle, 0, 3, 0, 1, GTK_FILL, 0, 0, 0); - gtk_toggle_button_set_active (GTK_TOGGLE_BUTTON (toggle), - pngvals.interlaced); - gtk_widget_show (toggle);
- g_signal_connect (toggle, "toggled", - G_CALLBACK (gimp_toggle_button_update), - &pngvals.interlaced); -
- pg.bkgd = toggle =
- gtk_check_button_new_with_mnemonic (_("Save _background color")); - gtk_table_attach (GTK_TABLE (table), toggle, 0, 3, 1, 2, GTK_FILL, 0, 0, 0); - gtk_toggle_button_set_active (GTK_TOGGLE_BUTTON (toggle), pngvals.bkgd); - gtk_widget_show (toggle);
- g_signal_connect (toggle, "toggled", - G_CALLBACK (gimp_toggle_button_update), &pngvals.bkgd); -
- pg.gama = toggle = gtk_check_button_new_with_mnemonic (_("Save _gamma")); - gtk_table_attach (GTK_TABLE (table), toggle, 0, 3, 2, 3, GTK_FILL, 0, 0, 0); - gtk_toggle_button_set_active (GTK_TOGGLE_BUTTON (toggle), pngvals.gama); - gtk_widget_show (toggle);
- g_signal_connect (toggle, "toggled", - G_CALLBACK (gimp_toggle_button_update), - &pngvals.gama); -
- pg.offs = toggle =
- gtk_check_button_new_with_mnemonic (_("Save layer o_ffset")); - gtk_table_attach (GTK_TABLE (table), toggle, 0, 3, 3, 4, GTK_FILL, 0, 0, 0); - gtk_toggle_button_set_active (GTK_TOGGLE_BUTTON (toggle), pngvals.offs); - gtk_widget_show (toggle);
- g_signal_connect (toggle, "toggled", - G_CALLBACK (gimp_toggle_button_update), - &pngvals.offs); -
- pg.phys = toggle = gtk_check_button_new_with_mnemonic (_("Save _resolution")); - gtk_table_attach (GTK_TABLE (table), toggle, 0, 3, 4, 5, GTK_FILL, 0, 0, 0); - gtk_toggle_button_set_active (GTK_TOGGLE_BUTTON (toggle), pngvals.phys); - gtk_widget_show (toggle);
- g_signal_connect (toggle, "toggled", - G_CALLBACK (gimp_toggle_button_update), - &pngvals.phys); -
- pg.time = toggle =
- gtk_check_button_new_with_mnemonic (_("Save creation _time")); - gtk_table_attach (GTK_TABLE (table), toggle, 0, 3, 5, 6, GTK_FILL, 0, 0, 0); - gtk_toggle_button_set_active (GTK_TOGGLE_BUTTON (toggle), pngvals.time); - gtk_widget_show (toggle);
- g_signal_connect (toggle, "toggled", - G_CALLBACK (gimp_toggle_button_update), - &pngvals.time); -
- pg.comment = toggle = gtk_check_button_new_with_mnemonic (_("Save comme_nt")); - gtk_table_attach (GTK_TABLE (table), toggle, 0, 3, 6, 7, GTK_FILL, 0, 0, 0); - gtk_toggle_button_set_active (GTK_TOGGLE_BUTTON (toggle), pngvals.comment); - gtk_widget_show (toggle);
+ /* GtkBuilder init */
+ builder = gtk_builder_new ();
+ gladefile = g_build_filename (gimp_data_directory (), + "glade/file-png.glade", + NULL); + gtk_builder_add_from_file (builder, gladefile, NULL /*error*/); + g_free (gladefile);
+ /* Table */
+ gtk_box_pack_start (GTK_BOX (gimp_export_dialog_get_content_area (dialog)), + GTK_WIDGET (gtk_builder_get_object (builder, "table")), + TRUE, TRUE, 0); +
+ /* Toggles */
+ pg.interlaced = toggle_button_init (builder, "interlace", + pngvals.interlaced, + &pngvals.interlaced); + pg.bkgd = toggle_button_init (builder, "save-background-color", + pngvals.bkgd, + &pngvals.bkgd); + pg.gama = toggle_button_init (builder, "save-gamma", + pngvals.gama, + &pngvals.gama); + pg.offs = toggle_button_init (builder, "save-layer-offset", + pngvals.offs, + &pngvals.offs); + pg.phys = toggle_button_init (builder, "save-resolution", + pngvals.phys, + &pngvals.phys); + pg.time = toggle_button_init (builder, "save-creation-time", + pngvals.time, + &pngvals.time); +
+ /* Comment toggle */
parasite = gimp_image_parasite_find (image_ID, "gimp-comment"); - gtk_toggle_button_set_active (GTK_TOGGLE_BUTTON (toggle), - pngvals.comment && parasite != NULL); - gtk_widget_set_sensitive (toggle, parasite != NULL); + pg.comment =
+ toggle_button_init (builder, "save-comment", + pngvals.comment && parasite != NULL, + &pngvals.comment); + gtk_widget_set_sensitive (pg.comment, parasite != NULL); gimp_parasite_free (parasite);
- g_signal_connect (toggle, "toggled", - G_CALLBACK (gimp_toggle_button_update), - &pngvals.comment); -
- pg.save_transp_pixels = toggle =
- gtk_check_button_new_with_mnemonic (_("Save color _values from " - "transparent pixels")); - gtk_table_attach (GTK_TABLE (table), toggle, 0, 3, 7, 8, GTK_FILL, 0, 0, 0); - gtk_toggle_button_set_active (GTK_TOGGLE_BUTTON (toggle), - alpha && pngvals.save_transp_pixels); - gtk_widget_set_sensitive (toggle, alpha); - gtk_widget_show (toggle);
- g_signal_connect (toggle, "toggled", - G_CALLBACK (gimp_toggle_button_update), - &pngvals.save_transp_pixels); -
- pg.compression_level = scale =
- gimp_scale_entry_new (GTK_TABLE (table), 0, 8, - _("Co_mpression level:"), - SCALE_WIDTH, 0, - pngvals.compression_level, - 0.0, 9.0, 1.0, 1.0, 0, TRUE, 0.0, 0.0, - _("Choose a high compression level " - "for small file size"), NULL); -
- g_signal_connect (scale, "value-changed", + /* Transparent pixels toggle */
+ pg.save_transp_pixels =
+ "save-transparent-pixels", + alpha && pngvals.save_transp_pixels, + &pngvals.save_transp_pixels); + gtk_widget_set_sensitive (pg.save_transp_pixels, alpha); +
+ /* Compression level scale */
+ pg.compression_level =
+ GTK_OBJECT (gtk_builder_get_object (builder, "compression-level")); + g_signal_connect (pg.compression_level, "value-changed", G_CALLBACK (gimp_int_adjustment_update), &pngvals.compression_level);
- hbox = gtk_hbutton_box_new ();
- gtk_box_set_spacing (GTK_BOX (hbox), 6); - gtk_button_box_set_layout (GTK_BUTTON_BOX (hbox), GTK_BUTTONBOX_START); - gtk_table_attach (GTK_TABLE (table), hbox, 0, 3, 9, 10, - GTK_FILL | GTK_EXPAND, 0, 0, 0); - gtk_widget_show (hbox);
- button = gtk_button_new_with_mnemonic (_("_Load Defaults")); - gtk_box_pack_start (GTK_BOX (hbox), button, FALSE, FALSE, 0); - gtk_widget_show (button);
- g_signal_connect_swapped (button, "clicked", + /* Load/save defaults buttons */
+ g_signal_connect_swapped (gtk_builder_get_object (builder, "load-defaults"), + "clicked", G_CALLBACK (load_gui_defaults), &pg);
- button = gtk_button_new_with_mnemonic (_("S_ave Defaults")); - gtk_box_pack_start (GTK_BOX (hbox), button, FALSE, FALSE, 0); - gtk_widget_show (button);
- g_signal_connect_swapped (button, "clicked", + g_signal_connect_swapped (gtk_builder_get_object (builder, "save-defaults"), + "clicked", G_CALLBACK (save_defaults), &pg);
+ /* Show dialog and run */
gtk_widget_show (dialog);
pg.run = FALSE;
gtk_main ();
return pg.run;
diff --git a/plug-ins/glade/.gitignore b/plug-ins/glade/.gitignore new file mode 100644
index 0000000..b336cc7
--- /dev/null
+++ b/plug-ins/glade/.gitignore
@@ -0,0 +1,2 @@
+/Makefile
+/Makefile.in
diff --git a/plug-ins/glade/Makefile.am b/plug-ins/glade/Makefile.am new file mode 100644
index 0000000..ce54c0d
--- /dev/null
+++ b/plug-ins/glade/Makefile.am
@@ -0,0 +1,6 @@
+gladedatadir = $(gimpdatadir)/glade +
+gladedata_DATA = \
+ file-png.glade
+EXTRA_DIST = $(gladedata_DATA)
diff --git a/plug-ins/glade/file-png.glade b/plug-ins/glade/file-png.glade new file mode 100644
index 0000000..0005595
--- /dev/null
+++ b/plug-ins/glade/file-png.glade
@@ -0,0 +1,226 @@
+ 9
+ + 9
+ 1
+ 1
+ True
+ 12
+ 10
+ 3
+ 6
+ 6
+ _Interlacing (Adam7)
+ True
+ True
+ False
+ True
+ True
+ 3
+ Save _background color
+ True
+ True
+ False
+ True
+ True
+ 3
+ 1
+ 2
+ Save gamma
+ True
+ True
+ False
+ True
+ 3
+ 2
+ 3
+ Save layer o_ffset
+ True
+ True
+ False
+ True
+ True
+ 3
+ 3
+ 4
+ Save _resolution
+ True
+ True
+ False
+ True
+ True
+ 3
+ 4
+ 5
+ Save creation _time
+ True
+ True
+ False
+ True
+ True
+ 3
+ 5
+ 6
+ Save comme_nt
+ True
+ True
+ False
+ True
+ True
+ 3
+ 6
+ 7
+ Save color _values from transparent pixels + True
+ False
+ True
+ False
+ True
+ True
+ 3
+ 7
+ 8
+ True
+ 0
+ Co_mpression level:
+ True
+ compression-level-spin
+ 8
+ 9
+ True
+ True
+ compression-level
+ False
+ 1
+ 2
+ 8
+ 9
+ True
+ True
+ True
+ Choose a high compression level for small file size + ●
+ compression-level
+ True
+ 2
+ 3
+ 8
+ 9
+ True
+ 6
+ start
+ _Load Defaults
+ True
+ True
+ True
+ True
+ False
+ False
+ 0
+ S_ave Defaults
+ True
+ True
+ True
+ True
+ False
+ False
+ 1
+ 3
+ 9
+ 10
diff --git a/po-plug-ins/POTFILES.in b/po-plug-ins/POTFILES.in index 512cf96..6fefb91 100644
--- a/po-plug-ins/POTFILES.in
+++ b/po-plug-ins/POTFILES.in
@@ -207,6 +207,7 @@ plug-ins/gimpressionist/repaint.c plug-ins/gimpressionist/size.c
plug-ins/gimpressionist/sizemap.c
plug-ins/gimpressionist/utils.c
+plug-ins/glade/file-png.glade
plug-ins/gradient-flare/gradient-flare.c plug-ins/help-browser/dialog.c
plug-ins/help-browser/help-browser.c
Martin Nordholts
2010-01-07 16:43:58 UTC (about 15 years ago)
Right now GIMP has virtuall all of the UI imperatively constructed with code. This has a few problems:
* Tweaking the UI requires re-building the app * A lot of code duplication
* Not very modern
The patch I am replying to ports the PNG save dialog to Glade and uses GtkBuilder to construct the UI. The purpose of this change is to introduce declarative construction of UIs in GIMP to give us experience in this area. The benefits of using Glade is:
* Tweaking the UI doesn't requires re-bulding the app * Less code
* Easier to start using a script language like JavaScript in the core * We make the GIMP code base more modern * UIs can be constructed through drag-and-drop with Glade
There are a few things that should be noted:
* Translations still works * Mnemonics still works
* The tooltip is still there (although only on the spinner, not scale) * We use GtkBuilder, not the deprecated libglade * There is no need for any proprocessing, GtkBuilder reads direct XML * We don't rely on any extra tool, XML files can be written manually
And a warning: * Order of XML properties, see GtkAdjustment comment in file-png.glade
So, do people think this is a step in the right direction? Personally I do and would like to commit the patch. Opinions?
Regards, Martin
SHIRAKAWA Akira
2010-01-07 17:05:52 UTC (about 15 years ago)
On 2010-01-07 16:45, Martin Nordholts wrote: [...]
I'm not expert enough to decide whether using GtkBuilder to construct the UI is a good thing or not, but less code, more flexibility and no need to rebuild the app for interface customization all seem a good thing to me. Are there any disadvantages? Performance issues at start up and during actual program usage?
Ideally, would this be limited to dialog windows or, instead, the entire user interface?
Stephen Griffiths
2010-01-07 17:19:55 UTC (about 15 years ago)
PiTiVi uses GtkBuilder to do this everywhere, and then uses python after that. Point being that the heavy lifting is still done by GTK+ and GStreamer. GIMP is a significantly larger program, but I don't think hooking up the widgets is all that time intensive here either.
As far as I know switching over to using GtkBuilder everywhere would be a feasible thing to do as the heavy lifting is constructing the widgets not joining them together.
regards, Stephen.
2010-01-07 23:10:25 UTC (about 15 years ago)
Why are the files still installed in a folder called "glade" then and use the file extension .glade? Since we have the chance to do this right from the beginning, that should probably be changed.
Other than that, using GtkBuilder has been on the TODO for quite a while. So it's nice that someone finally took a step forward and started doing this.
We will probably have to improve libgimpwidgets somewhat to allow our custom widgets to be used from GtkBuilder.
Martin Nordholts
2010-01-08 15:29:46 UTC (about 15 years ago)
The conclusion was to go ahead so I will commit the patch soon after changing "glade" to "ui" as per Sven's comment.
In response to Akira's comment on performance:
We need to be aware of that we are introducing extra disk IO which can give us problems, especialy during startup if we have to load a lot of files. In practice I don't think this will be a problem for a long time though, but doesn't hurt to have a mitigation strategy. We could:
* Put files as static strings in the code so that we don't have to significant disk IO at all
* Merge several files together to minimize disk seeking times for many files
In response to the question on to what extent to use Glade:
We should not sacrifice good interaction design for simplicitly of writing the UI code. UIs constructed through drag-and-drop of widgets have a tendency to have bad usability, it is important that we keep this in mind so we don't fall into the same trap.
In response to Torsten's comment on custom widgets:
Yes I agree, eventually we need to support our custom widgets with Glade. This might require adaptions to our widgets and even to Glade and to GtkBuilder.
In response to Michael:
"Less code" means less C code. In this case file-png.c now has 46 lines of C code less. Also, you seemed to interpreted all my points as arguments for using Glade while many of them were just comments. For example, the bullet that we don't rely on any extra tool was just to calm down people that don't want any new build dependency. The use of Glade is optional but I except only extreme hackers to code the XML files manually :).
/ Martin
Aurimas Juška
2010-01-08 16:05:30 UTC (about 15 years ago)
Why not to convert XML's to C code when compiling distribution ? XML's are large and not very fast to parse. This approach would have all the benefits of XML's while developing and would not cause additional penalties for release distribution.
Martin Nordholts
2010-01-08 16:07:46 UTC (about 15 years ago)
That's also a good option in case parsing turns out to be a big bottleneck
/ Martin
Alexia Death
2010-01-08 18:42:05 UTC (about 15 years ago)
Option of generating code from glade was removed before version 3 by what I read, so currently its not possible and is not considered a good thing. May be if it becomes a problem, such a function can be added again specially with this, pre-compiling the XML for acceleration, use in mind.
--Alexia
Liam R E Quin
2010-01-08 20:51:48 UTC (about 15 years ago)
On Fri, 2010-01-08 at 17:05 +0200, Aurimas Juška wrote: [...]
Large - that's subjective. XML is not a compact format, though.
Not very fast - 50 MBytes per second isn't unreasonable with libxml.
ls -lh with-sources.xml $ -rw-r--r-- 1 lee lee 42M 2009-12-22 22:30 with-sources.xml $ time xmllint --noout with-sources.xml 0.57user 0.10system 0:00.68elapsed 97%CPU (0avgtext+0avgdata 580224maxresident)k
0inputs+0outputs (0major+36332minor)pagefaults 0swaps
So not actually all that significant.
Liam
2010-01-08 21:39:51 UTC (about 15 years ago)
Can you back up your claims that parsing the XML would have noticeable impact? I am pretty sure that the effect is negligible. So pre-processing the XML to C code would make things more complex without any need and it has the potential danger that people start to edit the generated code. The solutions that Martin suggested can be considered when it turns out that parsing the XML becomes a problem. Converting to code is certainly not an option we should consider.
peter sikking
2010-01-09 11:21:26 UTC (about 15 years ago)
* Not very modern
well I see we have to be quick here to get a word in, as Martin has already gone ahead.
as an ex-UI developer, planner of actual GUI frameworks and as a interaction architect I have a strained relationship with GUI builder applications. which of course are by themselves front-ends for declarative construction of UIs.
discussing GUI builders fundamentally in recent years, I must observe that if GUI builders were offering the same flexibility as coding by hand, then using the GUI builder would be just as quick as coding by hand. speed vs. flexibility is a hard trade-off.
rinse and repeat the paragraph above for declarative construction of UIs.
now I can understand how a load of humdrum dialogs we have could be quickly build/maintained in the builder/declarative way.
however,
let it be really clear that I will _not_ entertain the following excuses in the future:
"your UI design cannot be build with the builder/declarative way."
"that layout can only be start-up/compile time static, because of the builder/declarative way."
"that custom widget cannot be used with the the builder/declarative way."
"theoretically we could write some code for that special interaction, but then we could not maintain it in the the builder/declarative way."
"yes that looks shit on platform xyz but we cannot do anything about it through the builder/declarative way."
GIMP a high performance application that on the UI front should constantly push the envelope of what GTK has to offer.
just for the record,
--ps
Nils Philippsen
2010-01-13 11:27:29 UTC (about 15 years ago)
I have some experience with using glade/libglade to program UIs (gtk builder should be the same or better), so I wanted to chime in even if I'm a few days late on it.
On Sat, 2010-01-09 at 11:21 +0100, peter sikking wrote: [...]
however,
IMO there's no need for that:
In the program, you can do the same things with a widget from gtk builder as you can with a manually coded widget. From the POV of the programmer in the application, there's no difference once a widget object exists. Dynamic interaction in widgets needs to be programmed in the application (as usual).
AIUI, you can make custom widgets known to gtk builder and use it like normal gtk/gnome widgets.
"Special interaction" would need special code anyway. As gtk builder is for taking care mainly of the "view" side of things (read: arrange widgets in a UI instead of with code), and only partly for the "controller" (map signals to callbacks), this doesn't hurt really. Again, you can do anything with these widgets that you can do with traditionally coded ones. You can still connect signals to callbacks in the code (you don't have to do it in glade), you still need to code your own callbacks.
I can't imagine why something looking shit would be due to the use of glade/gtk builder. Maybe I'm a bit unimaginative ;-).
Nils
Jon Cruz
2010-01-20 20:23:01 UTC (about 15 years ago)
Just a minor FYI...
I've not gone over the latest versions of all, but in the past this has actually been a problem I've hit. Running UI's through several themes, including a *few* used for accessibility is important, and can expose such problems.
One of the initial signs to look for is if the tool lets any *physical* details into the markup. As I recall, Qt's builder had more problems in this regards, but it is still a good warning.
