modify scale of brush with libgimp
modify scale of brush with libgimp Tim Chen 27 Dec 16:39
  modify scale of brush with libgimp Sven Neumann 28 Dec 12:37
Tim Chen
2009-12-27 16:39:06 UTC (over 15 years ago)
Hi all,
A quick question, is it possible to modify the scale of the brush using some functions in libgimp from plug-in side?
I know there is a gimp_brush_set_radius() function that could set the brush radius, but it is not exactly the *scale* in the tool option and could bring some problem when choosing some default brush that are not editable.
My current workaround is to duplicate the non-editable brush and modify its radius on the clone then delete it. But I am wondering is there any better way?
thanks,
Tim
2009-12-28 12:37:11 UTC (over 15 years ago)
On Sun, 2009-12-27 at 23:39 +0800, Tim Chen wrote:
Hi all,
No, all the newer options that modify how the brush is applied in the current context are not yet exposed to the PDB. We would happily accept proposals for the API and of course patches that implement this.
