Tilting the Canvas to draw slanted lines
Tilting the Canvas to draw slanted lines Magnusart 12 Dec 17:06
  Tilting the Canvas to draw slanted lines Alexia Death 12 Dec 18:11
   Tilting the Canvas to draw slanted lines Rob Antonishen 04 Jan 17:07
2009-12-12 17:06:13 UTC (almost 16 years ago)
Hello
I'd like to implement a feature where I can rotate/tilt the Canvas, draw a bit and reset it to it's original orientation quickly. This need to be fast and the rotation in itself should not make any permanent/destructive changes (should work like the current rotation preview but without dialogs).
I draw quite a bit with pen and paper and this work flow is vital to be able to sketch in a fluid manner.
My intention would be to write this as a plug-in. What I would like to know is A) does this already exist and B) would you consider it to be a hard task to implement this as a plug-in?
I have programming knowledge and work as a developer. I know several languages but I'm work with Java on a daily basis. I have no previous experience developing for GIMP or using it's libraries.
My approach would be to rotate the canvas by x degrees and letting the input from the tools would be rotated with -x so that they align with the screen orientation.
This need to have a short cut key that only allows the orientation to be altered when that key is pressed.
Happy for suggestions and information.
Best regards Magnus Andersson
Alexia Death
2009-12-12 18:11:45 UTC (almost 16 years ago)
This has been on the roadmap for a while.
This is NOT doable as a plugin. This needs to be tone in the core, In the part thats responsible for drawing the image projection.
C will come as a bit of a shock then ;) no garbage collection etc. but If you want to the skills can be aquired.
thats the business of the projection alright.
Let me warn you, its a lot more work than you think, more o if you have never used C or GIT. On the other hand its easier to learn than one would expect for c. The functionality you will need to alter is AFAIK nicely separated from the rest.
If you still want to do it, please join us in gimp net #gimp irc channel.
Rob Antonishen
2010-01-04 17:07:13 UTC (almost 16 years ago)
As a side note, this was implemented in CS4 using openGL http://kb2.adobe.com/cps/405/kb405745.html
-Rob A>
