run batch from python scheduled via lanchd OS X
run batch from python scheduled via lanchd OS X heathcarlisle 09 Dec 01:11
run batch from python scheduled via lanchd OS X Omari Stephens 10 Dec 10:03
  run batch from python scheduled via lanchd OS X heathcarlisle 15 Dec 17:53
2009-12-09 01:11:21 UTC (over 15 years ago)
Greeting: interesting scenario:
I have a number of batch workflows, written in python, that run as python-fu plugins.
Sample bash terminal command:
gimp -ibdf '(python-fu-batch-colorRT RUN-NONINTERACTIVE \"*.JPG\")''(gimp-quit 1)'
Opens each file and applies the plug in. Works Fine.
Also fine when run from a wrapping python script as:
command = "gimp -ibdf '(python-fu-batch-usnaps-colorRT RUN-NONINTERACTIVE \"*.JPG\")''(gimp-quit 1)'"
process = Popen([command], shell=True)
..PROVIDED that the wrapping script is run from the bash command line:
./doColorRT
Problem is, when this same python wrapping script is scheduled via launchd,(OS X launch daemon) an error is generated "sh: gimp: command not found" and gimp never runs.
I can replace the entire gimp command with a common shell command (ls, whoami, etc for example) and I get the proper response from either run method.
The wrapper script runs based on launchd's key, as new images arrive in a folder.
Anyone use this type of workflow? Help is greatly appreciated,
kindly, -hc
Omari Stephens
2009-12-10 10:03:58 UTC (over 15 years ago)
launchd likely uses a sanitized environment where gimp is no longer in the PATH. Try adding the directory with gimp to PATH as the first step in your wrapper script.
--xsdg
./doColorRT
kindly, -hc
2009-12-15 17:53:57 UTC (over 15 years ago)
Thanks for the response. That does seem to be the case: I can query the environment variables from within the python wrapper and I do get an abbreviated list when the wrapper is called from launchd.
I can configure the plist to alter the environment for the wrapper job, but that seems to be an extremely combersome mehod.
For instance, if I add the path and successfully call GIMP, I get errors further down the dependency chain..
There are also a bunch of environment variables in /tmp/ that I can't hard wire into a plist.
thanks again! -hc
--xsdg
Heath Carlisle escribio:
python-fu plugins.
./doColorRT
arrive in a folder.
kindly, -hc
