What dos are there t translate?
8 of 8 messages available
What dos are there t translate? Alfonso Santana 05 Dec 17:03
  What dos are there t translate? julien 05 Dec 20:45
  What dos are there t translate? Luigi A. 05 Dec 22:53
   What dos are there t translate? Michalis Gkiokas 05 Dec 23:44
    What dos are there t translate? julien 06 Dec 07:42
     What dos are there t translate? Claude Paroz 06 Dec 20:44
      What dos are there t translate? Sven Neumann 06 Dec 20:53
       What dos are there t translate? Claude Paroz 06 Dec 21:22
Alfonso Santana
2009-12-05 17:03:16 UTC (over 15 years ago)
I just want to begin to translate. Whta docs are there that need to be translated?
julien
2009-12-05 20:45:51 UTC (over 15 years ago)
Welcome to the GIMP Help team.
According to your name, you probably want to translate to Spanish.
You should agree with Luis, who recently started translation, to decide what you will translate.
Julien
Luigi A.
2009-12-05 22:53:52 UTC (over 15 years ago)
Hi, or better, hola
Para comenzar, soy Luis, ya comencé la traducción de los documentos, puedo darle una listade los archivos .po que ya traducí para que sepa cuáles necesita traducir(el problema es que yatraduje unos detalles en todos los archivos para ahorrar tiempo) entonces tendria que darletodos los archivos .po!(mejor que los de GIT.) Necesita usar poedit(para windows o linux) o kbabel(linux, kde). Espero su respuesta para trabajar con usted. Date: Sun, 6 Dec 2009 11:33:16 +1930 From: freesoftware.doc@gmail.com
To: gimp-docs@lists.XCF.Berkeley.EDU Subject: [Gimp-docs] What dos are there t translate?
__________________
Michalis Gkiokas
2009-12-05 23:44:43 UTC (over 15 years ago)
ok i understand you both english and espagnol but ok....can someone tell us where to find those .po files?
thanks in advance
julien
2009-12-06 07:42:29 UTC (over 15 years ago)
Since wiki.gimp.org is broken, I started writing my own How to contribute wiki:
http://gimp-help-how-to-contribute.rendez-vous-wiki.com/
I am still doing it, and it is improving every day, but it can be used to start a gimp-help-2 translation straight away.
I would appreciate feedback.
Claude Paroz
2009-12-06 20:44:09 UTC (over 15 years ago)
Some months ago [1], I made some work so as GIMP manual translation stats may be automaticly generated on http://l10n.gnome.org/module/gimp-help-2/
Couldn't this simplify a bit the translation process?
Claude
[1] https://lists.xcf.berkeley.edu/lists/gimp-docs/2009-September/001878.html
2009-12-06 20:53:36 UTC (over 15 years ago)
Thanks for your efforts. Unfortunately your page title spells the name of the GNU Image Manipulation Program incorrectly. Would you mind changing the title to "GIMP User Manual" ?
Claude Paroz
2009-12-06 21:22:18 UTC (over 15 years ago)
Sure, done.
Claude
