the Delete command of Images Dialog
the Delete command of Images Dialog SimaMoto, Ry?Ta 27 Nov 21:28
SimaMoto, Ry?Ta
2009-11-27 21:28:58 UTC (over 15 years ago)
The Delete icon button of the Images Dialog is described that it is not working. But I found this button is useful, when I wrote my first Script-Fu script.
This command works only on a image which is loaded without any window. Though images can be opened by the New Window command, if the image has been already loaded without window by a primitive procedure command (such as gimp-image-new,
file-png-load, etc.), it can not be unloaded even if its windows are closed to the last. Then use this command to close it.
I did not read its source file, so I don't know the actual purpose of this command.
SimaMoto,Ry?Ta
http://code.google.com/p/gimp-doc-ja/
