i18n in an external pack of scripts
i18n in an external pack of scripts Alexandre Prokoudine 16 Nov 21:54
  i18n in an external pack of scripts Sven Neumann 16 Nov 22:14
   i18n in an external pack of scripts Alexia Death 17 Nov 09:20
2009-11-16 21:54:59 UTC (over 15 years ago)
Supposing there is a somewhat popular bunch of scripts distributable as one package. If I get it right, to make them translatable I would have to:
1. Somehow set package name for gettext that follows a particular scheme, e.g. 'gimp20-my-pack-of-scripts'. Requires a proper build environment perhaps (recommendations?).
2. Create po/POTFILES.in and a PO file (for testing purposes first).
3. Somehow make GIMP understand that it has to load gimp20-my-pack-of-scripts.mo files.
Step 2 is a no-brainer, but how do I do 1 and 3?
Alexandre
2009-11-16 22:14:29 UTC (over 15 years ago)
For a plug-in this is easy. The plug-in would have to make sure that it calls the gimp-plugin-domain-register procedure. A Script-Fu script however runs in the Script-Fu interpreter and can't do this. As long as Script-Fu doesn't provide support for internationalisation of third-party scripts, there is no way to do what you are aiming for.
Short answer: forget about Script-Fu and use Python instead.
Alexia Death
2009-11-17 09:20:33 UTC (over 15 years ago)
Can we haz a long answer? Because porting entire FX foundry to python is not feasible. Perhaps the script-fu component can be altered.
