[Fwd: Re: Stylesheet missing?]
3 of 5 messages available
[Fwd: Re: Stylesheet missing?] Ulf-D. Ehlert 21 Oct 20:55
200910181835.42290.ude88@we... 07 Oct 20:29
  [Fwd: Re: Stylesheet missing?] Kolbjørn Stuestøl 20 Oct 23:23
4ADF74ED.2010802@stuestoel.no 07 Oct 20:29
  [Fwd: Re: Stylesheet missing?] Ulf-D. Ehlert 24 Oct 18:09
Kolbjørn Stuestøl
2009-10-20 23:23:36 UTC (about 16 years ago)
Ulf-D. Ehlert skreiv:
(Duplicate, mail was not delivered - gimp-docs is still dead.)
Kolbjørn Stuestøl (Montag, 12. Oktober 2009, 23:20):
Hmm, this conclusion is not necessarily correct: For example, many Linux applications look for a system and a personal configuration file, and it's usually ok if one or both are missing.
I didn't know that. Sorry.
(But, I would perhaps have put such calls in a if sentence I think. (if found the else something other) )
I think this is exactly the way how a browser is expected to do it: if stylesheet X exists then read stylesheet X endif if stylesheet Y exists then read stylesheet Y endif etc.
Agree! Don't know how in a short expression. Have not studied the sequences in the html code.
I had a quick look at the HTML and CSS specifications, and didn't find anything about missing stylesheet files. So I still don't know if a missing CSS is an error. Just the implication missing file ==> error
seemed to be wrong to me.
It looks I was too strict ;-) Never to late to learn something new. In the future I do not bother if some unnecessary style sheets are missing.
But since browsers handle missing CSS gracefully and the users don't recognize it, I think it's more likely not an error.
A matter of definition. The program I uses to check the links (a W3.org duplicate) are programmed to look at it as an error. But as said before, this is more a matter of taste than a problem. Except perhaps for some perfectionists?
I still think that the average users of the manual doesn't bother about the stylesheets at all.
That's definitely true.
More exactly: probably more than 99% of the users don't care... unless we make the background pink! ;-)
Interesting background
When I am putting together a web site for other people they do not allways even know what I am speaking of if I mentions html or css. PHP is perhaps the name of some sweets :-)
So if broken links are normally programming habit in Linux, I do of course have to follow this habit. Even though I do not agree.
Well, broken links are always a certain problem. But not every missing file is a broken (link or a problem). Some files are just optional. (BTW, the same is true for your personal gimp config files in $HOME/.gimp-2.6.)
Ulf
Nice. Was not aware of this.
BTW: I have a complete (per yesterday) Norwegian translation. When running "git format-patch" absolutely nothing happens. Am I missing something or doing it the wrong way? I have two copies of the gimp-help-2, one copy for "git pull" and a copy of this as a working copy:
gimp/gimp-help-2
gimp/work/gimp-help-2
Updates my copies - making pot files - translating the nn/po files - running
make -f Makefile.GNU validate-nn make -f Makefile.GNU html-nn
git format-patch
(I have to use your special "tools/make_image_links.pl" to copy the images). Kolbjørn
Ulf-D. Ehlert
2009-10-21 20:55:22 UTC (about 16 years ago)
Kolbjørn Stuestøl (Dienstag, 20. Oktober 2009, 23:23):
gimp/gimp-help-2
git format-patch
I think you have to specify the commit(s). For example, git format-patch --stdout HEAD^
will print (to screen) the last commit (HEAD) as a patch (with a mailbox header).
I did not yet merge the Cygwin branch -- didn't get any feedback.
Ulf
Ulf-D. Ehlert
2009-10-24 18:09:59 UTC (about 16 years ago)
Kolbjørn Stuestøl (Mittwoch, 21. Oktober 2009, 22:54):
As the nn/po files are completely rewritten, will it be possible to replace them instead of using patch?
Yes, of course. But depending on the tarball size it may be a problem to send it by email, then you'll have to upload it somewhere.
Sorry. I had too much to do during spring and summer. Don't remember the question(s). Have to get back and follow the tree. Not much spare time until ultimo November I think. (I'm one of the editors of an annual booklet with deadline in November).
I think the problem was working with symlinks under Cygwin, and the branch contained changes to check for Cygwin and create hardlinks instead of symlinks under Cygwin.
Ulf
