Airbrush/Brush Banding Effect At Low Pressure/Opacity
Airbrush/Brush Banding Effect At Low Pressure/Opacity Christopher Howard 20 Oct 22:22
  Airbrush/Brush Banding Effect At Low Pressure/Opacity Sven Neumann 20 Oct 22:39
   Airbrush/Brush Banding Effect At Low Pressure/Opacity Jay Cox 21 Oct 12:18
Christopher Howard
2009-10-20 22:22:23 UTC (about 16 years ago)
Hi. To try to learn GIMP development, I have been looking into old bug #588681 (Airbrush tool produces banding with with soft brush). From the initial problem summary:
"The Airbrush produces bandings when its used with a soft brush and low pressure. The sharp edges in the bands is [sic] very visible when it occurs in a otherwise soft image. The low pressure is very useful when I want to have good control over the spray."
He uploaded an image as well of the effect, which I can easily reproduce. When using the airbrush, the severity of the effect is indirectly proportional to the pressure level selected. The exact same problem can be reproduced with a normal fuzzy brush, simply by selecting a low opacity, and repeatedly clicking on the canvas in the same location.
Initially I spent a lot of time looking at app/core/gimpbrushgenerated.c, and especially gauss(), gimp_brush_generated_calc_lut(), and gimp_brush_generated_calc(). This is because I mistakenly supposed that the problem lay in the construction of the lookup table used initially to create the brush mask. However I discovered that this is completely unaffected by the brush opacity or airbrush pressure.
Though having a far from sufficient understanding of how the GIMP brush painting process works, it seems to me like this is the fundamental problem: In making black-and-white brushes semi-transparent, GIMP somehow "levels out" the grey-scale, so that certain ranges of darkness become the same. On a fuzzy brush, the result is that the fine graduation is changed to appear stepped or banded.
I would appreciate any insight into this matter. I have started to look into how brushes are made (applied?) semi-transparent in the code, but there are quite a few functions in the paint-funcs directory to look through.
2009-10-20 22:39:03 UTC (about 16 years ago)
The problem here is that the brush masks are 8bit only. With such a limited set of values to start with, banding is basically unavoidable.
Jay Cox
2009-10-21 12:18:18 UTC (about 16 years ago)
You should be able to get rid of most of the banding by performing error diffusion when multiplying the opacity into the brush mask. I suspect that a simple 1d error diffusion algorithm will be sufficient and I wouldn't bother with a Floyd-Steinberg type algorithm unless you could come up with an example where the simpler algorithm showed visible artifacts.
I believe the function that introduces the banding is apply_mask_to_sub_region in paint-funcs.c or in the function apply_mask_to_alpha_channel depending on your point of view. I have not worked with that code in a long time and I could be wrong about that.
You will need to make the starting error term effectively random or you run the risk of letting the upper-left pixel in each tile get special treatment.
Good luck,
Jay Cox
jaycox@gimp.org
