Layer folders: layer masks?
Layer folders: layer masks? BRAXS69 19 Oct 04:53
  Layer folders: layer masks? SorinN 20 Oct 08:39
  Layer folders: layer masks? Michael Natterer 20 Oct 19:36
2009-10-19 04:53:50 UTC (over 15 years ago)
I don't know if the developers planned it or decided to take it out. but in the earlier dev versions of gimp before the single widow mode XD, when layer folders was first introduced their was the ability to add a layer mask to that folder.. .. I know probably that it was unplanned feature because gimp treated the folder like a layer. but in the recent builds of gimp the ability to add a layer mask to the folder has been taken out taken out. *heart attack*
however loading the saved gimp file of a drawing that i coloured in gimp using the layer masks on folder loaded flawlessly and not only that i could still edit the mask... so it's not like um asking for a new feature but enabling something that's already there just probably not thought of using in that way.
I think that it's a must have feature, and one that I'll dearly miss if it never comes back in. so i was wandering what people had to say on this. i might try and get in contact with the devs to see whats going on.
Here's a screenshot with layer folders with layer masks in action. http://dl.getdropbox.com/u/1682366/Screenshots/gimp_folderlayermasks.png
I can upload the gimp file if any ones interested.
thanks for your time.
SorinN
2009-10-20 08:39:55 UTC (over 15 years ago)
sure I need the file ..you can send this file attaches at nemes.sorin@gmail.com
2009/10/19 Brett :
-- Brett (via www.gimpusers.com)
Michael Natterer
2009-10-20 19:36:54 UTC (over 15 years ago)
That is because the folder *is* a layer.
I disabled layer mask creation on groups because it's not finished and crashes badly in some situations. Plus, it's not trivial to fix and I was distracted by other hacks.
Of course we thought about it. The group is just a layer and will have all a layer's features apart from editing its pixels.
The feature is completely there, just the GUI to create the mask is blocked. It will be there in the final 2.8 release.
ciao, --mitch
