Save + Export proposal
| Save + Export proposal | photocomix | 05 Oct 02:10 |
| Save + Export proposal | SorinN | 05 Oct 03:51 |
| Save + Export proposal | Omari Stephens | 05 Oct 04:23 |
| Save + Export proposal | Martin Nordholts | 05 Oct 22:20 |
| Save + Export proposal | Liam R E Quin | 05 Oct 23:50 |
| Save + Export proposal | photocomix | 06 Oct 18:52 |
| Save + Export proposal | photocomix | 20 Oct 13:20 |
| Save + Export proposal | peter sikking | 20 Oct 17:02 |
| Save + Export proposal | Rob Antonishen | 20 Oct 17:09 |
| Save + Export proposal | Ilya Zakharevich | 21 Oct 02:38 |
| Save + Export proposal | photocomix | 27 Oct 13:55 |
| Save + Export proposal | Nicolas Robidoux | 29 Oct 14:45 |
- postings
- 65
A clear distinction between Save and Export was needed
But even if conceptually different in practice , both operation are always
needed for the every edited image:
is needed to Save the original AND to export as jpg or png .
So why do not offer a chance to speed up the workflow, save time and
patience
achieving both result simultaneusly ?
A image is worth 1.000 words ,to avoid misunderstunding i invite to give a
look to this
mock up
http://farm3.static.flickr.com/2653/3981269891_998c2f513b_o.jpg
As you may see the idea is not to replace the Export dialog, but to offer a handy option from the Save dialog, to simultaneously export , with same name and in the same directory in other file formats
A possible objection is that "same name and some directory" is a severe limit but
1) For other cases there is well the proper Export Dialog
2) consider a real case
if in 1 day i edit 50 photos, i need to go trought 150 Save and Export dialog (and as now to click away about 300 warning ) to save original,a looseness png or tiff copy, and a jpg of my work
Using that option at the end of the work, in case i wish original, png and jpg in different folder i may get the result in 1 minute:
Is trivial filter the folder content for file extension and batch move all xcf, png, and jpg in their own dedicated folder
Even Picasa, or xnview and irfanview may do in a heartbeat...so would be not even needed to type a couple of commands in a terminal
1 minute Vs 100 additional dialogs
PS
i will appreciate a reply to this somehow connected technical question
http://www.gimpusers.com/forums/gimp-developer/12001-Gimp-file-save-interactive.html
In case the above proposal will be rejected, and anyway
in time-while i will really need a script doing something similar...script
is ready but that problem spoils the result
not bad - a bit radical - need some improvements because not all users are new GIMP users - a lot of GIMP users use PHOTOSHOP for production or Corel Photopaint or other windows / mac based programs and this way you will broke the traditional SAVE / EXPORT pattern.
Corel Phtotopaint has also a pretty good model where SAVE = save this file as is. SAVE AS = save this file with other name (eventually other format ). EXPORT = export canvas objects with an other file format. EXPORT FOR WEB = canvas content will be saved as CSS, HTML Text and Tables, and some Image slices. EXPORT FOR OFFICE = export canvas objects in a convenient way for MS OFFICE to be used in that context. Everything is clear from first look ans is simple - instead of a single tool with many options - they present you very direct your options to save a file. When you chose one or other option you know what will follow.
To save multiple copies on the same time, from a single shoot (maybe with different extensions), working in a project based workflow, ..hmm, that can be good and pretty unique ..to update all copies when you make a modification according to rules that you established on first save / export operation, well this can be an idea to play around. This can save a lot of time when you work on a project presented in web as well as in catalogs and brochures - same thing can be saved as jpg for web, png / tiff for DTP on the same time.
I think your idea deserve a brainstorm session.
2009/10/5 photocomix@gmail.com :
But even if conceptually different in practice , both operation are always needed for the every edited image:
is needed to Save the original AND to export as jpg or png .So why do not offer a chance to speed up the workflow, save time and patience
achieving both result simultaneusly ?A image is worth 1.000 words ,to avoid misunderstunding i invite to give a look to this
mock up
http://farm3.static.flickr.com/2653/3981269891_998c2f513b_o.jpgAs you may see the idea is not to replace the Export dialog, but to offer a handy option from the Save dialog, to simultaneously export , with same name and in the same directory in other file formats
PS
i will appreciate a reply to this somehow connected technical question http://www.gimpusers.com/forums/gimp-developer/12001-Gimp-file-save-interactive.html :
In case the above proposal will be rejected, and anyway in time-while i will really need a script doing something similar...script is ready but that problem spoils the result-- photocomix@gmail.com (via www.gimpusers.com) _______________________________________________ Gimp-developer mailing list
photocomix@gmail.com wrote:
::snip? SNIP!::
Wouldn't this be fairly straightforward to do as a plugin/python-fu/script-fu?
Adding code makes things slower. If this isn't something that would benefit the vast majority of GIMP users (and I'm not sure it would), it seems better to offer it as an option for those who want it, rather than to add extra code for the users who won't touch it.
--xsdg
This assumption is wrong. Complex compositions will need to be refined for weeks. All work is done in XCF. Before final delivery there is only an occasional need to export to some other format.
/ Martin
is needed to Save the original AND to export as jpg or png .This assumption is wrong. Complex compositions will need to be refined for weeks. All work is done in XCF. Before final delivery there is only an occasional need to export to some other format.
Actually the two statements don't contradict each other -- it's fair
to say that the most likely workflows are
(1) load image (jpeg. png, tiff, cr2, etc)
work on image
maybe save image in proprietary format temporarily, between sessions
eventually, do at least one of
. save in archive format (tiff, png)
. export to jpeg or gif or .mov or whatever
. print
(2) create new image, and rest as above.
And in most cases you'll need to export the image at some point, for every image.
It's got a little harder to track what you've done, now, because you need to know if the export filenames are up to date as well as the xcf filenme, and right now you can't tell.
E.g. an "image file history" panel showing save status, or adding save & export events to the undo history (even though you can't undo them they are part of the history) might help.
Liam
- postings
- 65
I send the mock up to the gimp-Ui brainstorm.
And for end users that may be interested ,in the while RobA cooked a script that offer basically equivalent features
obviously can't offer same GUI of my mock up, but allow
1 ) to Save+Export , popping out a error message if the image was not already
saved
2 )to Save AS + Export ...this basically allow to run the Save As dialog as
usual and then automatically export copies in the chosen format
Actually Export only in jpg and png but should be trivial add more format option
But has a price to crowd even more the File menu with 2 additional entries
while, in my opinion a similar added option to the Save dialogs will not screw up the GUI and will be clear and handy .
Maybe no much feel the need as now but is hard feel the need for something
never experienced before...
Once experienced may be more clear that may be a time saver
anyway the script works may be easy edited to add more export format (for example tiff, psd) and is here
http://ffaat.pointclark.net/incoming/scripts/save_and_export_1.2.scm
for
Your point is not too clear to me, i agree that a composition may take weeks, but at the end (at least in most cases ) as, not only to be saved but also to be exported
Sure would be much less needed for who has to export only once in week,and much more needed by who has to export Save last edit +Export every 30 minutes
But as added option seems to me unobtrusive in that Spheciphic GUI and the distiontion between SAVE and EXPORT is not only preserved but may even made more clear (at least in the mock up)
- postings
- 65
i knew that Peter Sikking (or somebody else from Gimp UI brainstorm staff)replied but the message get lost for technical problems (full storage disk)
I am very interested to know the content of that reply,i hope you may send again now
disk)
yes, I am (by default) the Gimp UI brainstorm staff, and I had about 3 threads going on here before the list collapsed.
again now
here we go:
OK, I waited with replying because I wanted to think about this
carefully.
that is because quite a few issues are combining here.
first two fundamental issues:
1) let's face it: this is a new feature request. it is not that we
broke something in this 50 pictures a day (10 minutes each) workflow.
actually, on balance things got a bit better for this with clear
saving and exporting.
2) an even bigger picture: does GIMP has to solve this problem?
since part of what you want is a no-brainer conversion from
png to jpeg. sounds like a job for a batch tool. this way you
would save your GIMP file, then ctrl-shift-E, return, return,
and GIMP does remember if you wanted TIFF or png all the time.
run the batch job at the end of the day.
so why not add it anyway, doesn't hurt no? yes it does:
- by associating 2 or more export files, "Export to foo.png" (ctrl-E) has to be redesigned and never be as good as now.
- you have coupled saving to exporting of multiple files, hard. in general these things do not happen at the same time, saving work is a different thing then delivering. write times go up by a factor of 1+N, where N is the number of export formats.
- so it is easy to set (well, you will have to 50 times a day) but how to stop it for a file? it was in the Save dialog, but to get there again? Save as?
- UI also needs to be not-error-inducing and give a clear model to users to how things work. this proposal here is one of several to get a liiiiitle bit of export back into the Save dialog. each of these creates _a_ way to export, that users may figure out as _the_ way to export, because they are migrating from 2.6 to 2.8. No, it does not help that we have clear Export on the File menu. we simply cannot let these models of export develop.
so that is why I am against this.
--ps
--ps
Even that said, anyone is free to develop a save and export plugin and offer it up for public consumption. It may not make it into the core, but assuming it is worthwhile, it will find use.
-Rob A.
[Looks like every time I post, I kill the list. My apologies; reposting]
mock up
Suppose you do this. You edit something, and press C-s. What would happen?
Ilya
- postings
- 65
probably this will be my last reply on the matter, i do not like insist proposing something that someone else has to code, even if in this case would be just a trigger for not interactive call(s)
I divided the objection in 2 groups, the first group focused on possible disadvantages and technical problem ,
..the second in my opinion derived of some misunderstanding of what proposed, or how i proposed to implement
In the first group
but how to stop it for a file? it was in the Save >dialog, but to get there again? Save as?
Suppose you do this. You edit something, and press >C-s. What would happen?
Correct , i was too generic in proposing the change for "the save dialogs"
let focus in the "Save as" dialog, in that case i can't image any similar
problems
(For who wish something as "save+export" a third party script
may be a better option and the script already exist)
################################# Then there is the second group of objection: a lot complains about the risk to complicate the code or on the work needed to modify both the Save and Export function
well i can't see nothing to redesign (except a detail in the Save as dialog) neither any need to re-associate files or redesign ctrl_E
Because i do not propose any change for the save function, but basically
only
a modification to the GUI of "save AS"
Sure any change in the GUI is connected to a change in the code
But in this case not to a change in the Save as functions:
that "export copy too as"would be there just because is most handy for users
there, but will not interfere on how the Save function will work but just add
not interactive call(s) after saving will be done
So whatever user will chose Save as will work as usual with no any change, no
interference, no complications
just at the end "Export" will be called
in not interactive way passing as arguments the filename,
the directory used to save and the chosen file formats(my mock up show how
chose
the file format ) and for the rest the user deafault.
Export function does not need any modification to support not interactive
call
(as far i know):
If the user chose to Save as+ export a jpg ...a not interactive call will
be done
if user wish also also png , a second call would be done to "export as
png"
using for the rest the identical arguments (same filename and directory +
user defaults
chosen for that format)
please allow me a metaphor
Eat and Drink are 2 different concept ,no less then Save and Export
Suppose you go in a Restaurant to eat, you order your food then you ask
"do you have something to drink ?"
And the waiter reply
"sure we have!..but drinking is a different concept and we do not want
create confusion
in our clients.
we have a separate room for who wish to drink, you will be welcome there
Obviously eating there is not allowed, that is for drink...but you are free
to
change room anytime you feel thirsty and get back here when you wish to eat
The fact that 2 things are conceptually different do not exclude that may
be much better achieve both simultaneously
An idea (especially for when GIMP moves to GEGL). Apologies if this has been suggested/shot down before.
I think that the following terminology would be fairly clear to users:
Save IMAGE (basically, export to a non-xcf format)
Save PROJECT (save the xcf/gegl tree)
Save WORKSPACE (save the current configuration of GIMP, not the xcf/gegl tree or the image: visible tools, visible non image windows etc)
IMHO, this 3-pronged "save" option makes it pretty clear what this is about.
I suggested earlier that "Save workspace" (like nip2) should be the non-export quick save, but eventually realized that a "workspace" suggests a set of easily accessible tools organized to fit a specific TYPE of project.
On the other hand, "Save project' suggests that all the components of the intended final image should be kept around.
"Save image" really suggests that what you are saving is the final product, in a common image format, that is, it corresponds to exporting.
Nicolas Robidoux
Universite Laurentienne
