Compiling from git on Ubuntu 9.04
5 of 6 messages available
Compiling from git on Ubuntu 9.04 Chris Mohler 03 Oct 20:54
  Compiling from git on Ubuntu 9.04 Chris Mohler 03 Oct 21:02
9d40e4ef0910031427i5ac51e2f... 07 Oct 20:27
  Compiling from git on Ubuntu 9.04 Chris Mohler 03 Oct 23:39
   Compiling from git on Ubuntu 9.04 Owen 04 Oct 01:37
    Compiling from git on Ubuntu 9.04 Alexia Death 04 Oct 10:34
Chris Mohler
2009-10-03 20:54:07 UTC (over 15 years ago)
Not sure how best to proceed - GIMP is requiring libgtk 2.16.6 to proceed, and Ubuntu 9.04 is shipping 2.16.1.
Any ideas?
Also - the INSTALL file probably needs an update: 4. You need to have installed GTK+ version 2.16.1 or newer
Chris
Chris Mohler
2009-10-03 21:02:33 UTC (over 15 years ago)
Any ideas?
Never mind :)
Compiling 2.16.6 now, sticking in /opt...
Chris
Chris Mohler
2009-10-03 23:39:40 UTC (over 15 years ago)
you probably should remove any *.la files from your /usr/lib, or you will run into a bad dependency/libtool hell. Happened to me after installing gtk from git, and I was told this is common.
Well, I installed gtk 2.16.6 into /opt/gtk, then exported my LD_CONFIG_PATH to there before compiling gimp (and also added to PKG_CONFIG_PATH), so hopefully I've sidestepped that. If I'm headed for trouble with this approach, someone please let me know :)
It seems to be working OK, but it's not picking up the current GTK settings/devices (like tablet). I think this method will work well enough for testing purposes though, and my stock 2.6.6 install seems to be working just fine.
Thanks, Chris
Owen
2009-10-04 01:37:47 UTC (over 15 years ago)
This might work and might not.
Start gimp from the console, but before you do set the LD_LIBRARY_PATH to /opt/gtk or where ever you installed it
Owen
Alexia Death
2009-10-04 10:34:28 UTC (over 15 years ago)
For me it worked for some time an then suddenly after rebuilding something libtool was trying to link against wrong stuff and failed.
