Invoking custom Gimp module from Web (Apache)
9 of 10 messages available
Invoking custom Gimp module from Web (Apache) Vio 02 Oct 17:47
  Invoking custom Gimp module from Web (Apache) Alexia Death 02 Oct 18:02
  Invoking custom Gimp module from Web (Apache) Martin Nordholts 02 Oct 18:39
   Invoking custom Gimp module from Web (Apache) Vio 02 Oct 22:17
    Invoking custom Gimp module from Web (Apache) BrockyL 04 Oct 05:26
     Invoking custom Gimp module from Web (Apache) Vio 04 Oct 15:19
9d40e4ef0910040902v5da23ce6... 07 Oct 20:27
  Invoking custom Gimp module from Web (Apache) Vio 04 Oct 22:33
   Invoking custom Gimp module from Web (Apache) Tom Rathborne 04 Oct 22:41
    Invoking custom Gimp module from Web (Apache) Iain Kennedy 05 Oct 00:45
Vio
2009-10-02 17:47:46 UTC (about 16 years ago)
I've been trying to debug invoking my gimp plug-in from an apache module for past 3 days without much success. I'm sure others tried the same, but Google didn't help much in finding these gems, so far.
So maybe a fresh pair of eyeballs may have other ideas ...
Ok, basically, I have a python-based GIMP plug-in which runs Ok when invoked from command-line.
But when called from apache (from a python-based apache plugin/module), for some reason the command:
gimp --no-interface --batch='(python-fu-pdf2jpg RUN-NONINTERACTIVE "/path/to/image/to/proces.pdf" )' --batch='(gimp-quit 1)'
doesn't get executed. Or it does but fails silently - which is not very helpful here !!
For testing, I've set the permissions of the OUTPUT directory to 'www-data' (apache user) and '777' (open to universe) but still got no output from the GIMP plug-in in this directory. ... though I got debugging files written by the apache module, so I know apache can write can write files in this directory at run-time.
But nothing from the Gimp module ... Actually I don't get ANY error message from GIMP in any of my /var/log files But once again, if I run that Gimp command from the command line (bash), it runs Ok !!
This would suggest a permissions problem, but I'm not sure. I wonder: does Gimp need to write to the user home directory by any chance? In that case, 'www-data' (the apache user) doesn't have a home directory per se.
So after 3 days of trying different options and digging the Web, I'm a little out of 'debug tricks' right now. If anyone knows why Gimp keeps silent
or knows of a mailing list thread which discusses this topic (i.e. Gimp web invocation),
I would very much appreciate it.
Cheers, vio
Alexia Death
2009-10-02 18:02:25 UTC (about 16 years ago)
Gimp needs a place IIRC designated by the $HOME env variable to have its user settings. Ive never tried what happens if is not there even to read, but Im not surprised it does not work. You cant try this out by running the command you have in the rights of www-data using sudo. you should have a clear picture what happens.
--Alexia
Martin Nordholts
2009-10-02 18:39:00 UTC (about 16 years ago)
Does it help if you set the GIMP2_DIRECTORY environment variable to "/tmp/gimpdir"?
/ Martin
Vio
2009-10-02 22:17:06 UTC (about 16 years ago)
Thanks for the hints ...
Some interesting developments while running under sudo. The first run:
----------------------------- sudo -u www-data gimp --no-interface --batch='(python-fu-pdf2jpg RUN-NONINTERACTIVE
"/dd/d/app/front/PAK_live/srvr/xformx.com/run/pdf_forms/le-50.0.11.01(2008-10)d8.pdf" )' --batch='(gimp-quit 1)'
gives error: error: Cannot create folder '/var/www/.gimp-2.6': Permission denied
So I temporarily opened up /var/www with permission 777 and tried previous command again - to see that gimp is going to write in the /var/www directory:
No protocol specified
/var/lib/python-support/python2.6/gtk-2.0/gtk/__init__.py:72: GtkWarning: could not open display
warnings.warn(str(e), _gtk.Warning) No protocol specified
(file-uri:5738): Gtk-WARNING **: cannot open display: :0.0
(gimp:5568): LibGimpBase-WARNING **: gimp: gimp_wire_read(): error No protocol specified
warnings.warn(str(e), _gtk.Warning) batch command executed successfully
This 2nd run interesting things (FINALLY) happened :) The most important is the last line: it says that gimp executed my plugin, and indeed, it did (wrote some debug file to the filesystem, as expected).
Also, after examining '/var/www', I see that gimp created 2 new directories:
drwx------ 4 www-data www-data 4096 2009-10-02 15:38 .gegl-0.0 drwxr-xr-x 21 www-data www-data 4096 2009-10-02 15:38 .gimp-2.6
I don't know how safe it is to keep these Gimp directories inside my main apache directory - it probably opens up some hole of some kind - but anyway, priority now is to make Gimp happy. I'll deal with holes inside my web server later ...
Conclusion: it seems Gimp needed these 2 dirs in that place, as now it seems to work with my preliminary (i.e. debugging) code. The key was to run that gimp command as "sudo -u www-data gimp ..."
to get that error message. Before that, I had no idea what Gimp was complaining about, or if it was even invoked at all ...
Thanks for your help, suggestions, and happy Gimping all ! (I'll be 'web-gimping' in my case :) vio
2009-10-04 05:26:14 UTC (about 16 years ago)
i consider myself pretty well versed with efficiency based upon server performance and apache conforms for me pretty well in plugging in modules to suite my needs and users demands. But I just don't see how you can use Common Gateway Interfacing for this task. I found your thread through a search engine looking for this exact same type of discussion but theres no way I'm gonna pipe gimp to apache in this manner. But Hey Man if you fetch yourself a release of mod_wsgi or mod_python this cgi method might just be doable, but with a lot of users running this, it could be hazardous. With My method I am developing I am going to use (hypothetically, I have not done this) a seperate module for gimp which will thread request's to and fro mod_wsgi(which I have just config'd and am working on the kinks). I would be more than happy to share my progress. Check out my website in a couple of days (http://site.google.com/site/abstractind)
-- Subscidiary Faction of AbstractIndustrys
Vio
2009-10-04 15:19:38 UTC (about 16 years ago)
I haven't tried mod_wsgi yet, so I'm doing it using mod_python. (I don't see a compelling reason to dump mod_python yet, not to mention the learning curve and potential time-cost to convert my scripts from mod_py to mod_wsgi - I don't really know if there are any, just guessing here...)
Invoking GIMP from mod_python works Ok, but it is quite slow. 1 round-trip request - from the client page requesting the Gimp stuff until the server gets back to the client with the response page is quite long - about 10-15 sec - and most (ALL?) of the time is spent on the Gimp side, NOT the apache/mod_py side. So obviously this is not a speed demon, as Gimp was not designed to serve web requests. But speed problem aside, it does work. ... it just needs 'veeery' patient users :)
Anyway, good luck on your side, I think you'll have no big problem making this work,
vio
Vio
2009-10-04 22:33:28 UTC (about 16 years ago)
You're right. Keeping a running Gimp daemon in memory would most certainly speed things up (for subsequent calls)
I recall the python tutorial has some sample code on writing simple servers in python (so, the python code is already available, therefore I'd guess it's probably just a matter of importing it into the Gimp-python plugin - hence no need to do much/any low-level socket programming.
I'm running my devel code (apache+mod_py+Gimp) on a tiny web-book (acer's aspire one) so I'd guess better performance would be achieved de-facto by simply using better hardware (I mean, in a production environment).
(and re-writing all this in C would obviously win the 100m hurdles, but that's overkill for me, for now, I'll be happy with working python code)
vio
PS. Hey, nice last name :) Sounds like You must get a lot of action at Halloween...
On Sun, Oct 4, 2009 at 12:02 PM, Alexia Death wrote:
I suspect part of the speed problem is that gimp is started and loaded at each call. a running gimp process is capable of taking over without a new process at least for opening images, but I don't know if you can do this for scripts. You might get better times if you write a plug-in that listens on a socket and executes received pdb calls.
Tom Rathborne
2009-10-04 22:41:21 UTC (about 16 years ago)
This worked very well with gimp-perl and mod_perl 10 years ago. It was relatively easy to establish a persistent connection from mod_perl to the gimp-perl server. Just as in database connections, each Apache child maintained a socket connection to gimp-perl.
It's just a matter of sorting out the socket permissions, as you have learned. For security purposes, I ran gimp as a different user, but granted permissions on the socket to www-data, and allowed gimp to write to a specific directory in the document root to enable caching of output images.
The performance was amazing, even 10 years ago.
I'm not sure if gimp-python has a similar server mode, but if it does, I'm sure that mod_python could cache the connections for similar performance levels.
Cheers,
Tom
Iain Kennedy
2009-10-05 00:45:36 UTC (about 16 years ago)
I run gimp and mod_perl on a production server and trigger longer jobs using the 'at' command so as not to keep users hanging around for a result. Some of the runs can generate upwards of 1,000 or so images, so the connections were timing out long before the job ever ended.
For shorter jobs, gimp start-up time can be significantly reduced - by upwards of 8 seconds on my laptop - by giving the apache process it's own gimp configuration directory in it's home directory.
On my debian systems the apache process runs as user 'www-data' and it's home directory is /var/www. I copy a '.gimp-2.2' directory and then set the permissions up:
cp ~/.gimp-2.2 /var/www chown -R www-data.www-data /var/www/.gimp-2.2
I have a tarball of a simple conf directory which I use to do the same thing on production servers, but the above is simple and effective and I was very chuffed when I figured it out! It's not as good as a keeping persistent connections going, but gives instant results for little work :)
Iain
P.S. I'll upgrade to gimp-2.2 soon, honest!
Cheers,
Tom
