Flame plug-in and large images.
Flame plug-in and large images. Pacho Ramos 21 Sep 14:44
  Flame plug-in and large images. Pacho Ramos 21 Sep 14:49
Pacho Ramos
2009-09-21 14:44:09 UTC (over 15 years ago)
Please excuse me if this was sent twice, as I may have sent it from the wrong E-mail address.
I noticed in the docs that it explicitly states that the flame plug-in wasn't working with large images, stating that while it worked with an image at the resolution of 1024x768, it failed with one at 2500x2500.
I tried this out on multiple platforms. On GNU/Linux (Ubuntu 8.10, x86 W/ 512MB of RAM, Gimp 2.6.1) the flame plug-in was successful on a 2560x1600 image. That was the largest I tried on that platform. On Windows (Windows 7 build 7600, x86 w/2GB of RAM, Gimp 2.6.6), it was successful on a 3840x2400 image, which is quite a bit larger than the 2500x2500 stated.
Should the documentation be changed, as it would seem that the plug-in does work with large images?
~Nick
It still fails on my system with 2Gb Ram, gimp-2.6.6 under Gentoo. I think that it depends on flame used. I attach one for reproducing, simply open it with flame plugin and try to apply it to a black image of 2500x2500 (well, it fails for me one it's larger than 2000)
But I am not sure if I should open a bug report for this :-/
Regards
Pacho Ramos
2009-09-21 14:49:47 UTC (over 15 years ago)
~Nick
Regards
Really attaching it. Test it with zoom=4
time 0,2 image_size 2028 1536 center 0,1 0 pixels_per_unit 100 spatial_oversample 2 spatial_filter_radius 0,75 sample_density 5 nbatches 1 white_level 200
brightness 1 gamma 2 cmap_inter 0
xform 0 density 1 color 1
var 0 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 coefs -0,838504 0,480056 0,14986 -0,716226 0,576762 0,219756 xform 1 density 1 color 0
var 0 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 coefs -0,636694 -0,457333 0,017635 0,728182 0,074694 -0,489891 xform 2 density 1 color 0
var 0 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 coefs 0,443109 -0,490792 -0,684466 -0,305791 -0,344419 -0,147514 xform 3 density 1 color 0
var 0 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 coefs -0,706116 -0,227088 0,342798 0,8249 -0,689059 -0,362536 ;
