Save/Export Patch
Save/Export Patch James Hughes 16 Sep 11:16
  Save/Export Patch Alexandre Prokoudine 16 Sep 12:32
   Save/Export Patch Alexia Death 16 Sep 13:04
  Save/Export Patch Martin Nordholts 16 Sep 16:54
  Save/Export Patch Liam R E Quin 16 Sep 17:45
James Hughes
2009-09-16 11:16:24 UTC (over 15 years ago)
Save/Export Patch
Can someone advice me the best place to start in making a patch to the UI to revert the 2.7 version to using the 2.6 style save dialogue. If someone would kindly point me in the right direction of which files I need to change would really appreciate it.
Thanks
James
2009-09-16 12:32:23 UTC (over 15 years ago)
Save/Export Patch
http://www.kernel.org/pub/software/scm/git/docs/user-manual.html
Sticking a fork into GIMP was never successful. Most everybody who tried didn't get as far as picking a knife with the other hand.
Alexandre
Alexia Death
2009-09-16 13:04:51 UTC (over 15 years ago)
Save/Export Patch
10pts for good humor.
To the fork operator, in all seriousness tho, look at git. Relevant commits are clearly marked. However, the remark above is 100% true. Just stick to 2.6 if you like that so much.
-- --Alexia
Martin Nordholts
2009-09-16 16:54:21 UTC (over 15 years ago)
Save/Export Patch
Hi James,
The first work regarding save+export was merged to git master in commit cd8829b91b3a. Type
gitk cd8829b91b3a
in your GIMP git repo and you'll see the initial commits. After that, development has happened incrementally directly in git master so you'll need to manually browse the commits and identify the relevant ones.
HTH, Martin
Liam R E Quin
2009-09-16 17:45:27 UTC (over 15 years ago)
Save/Export Patch
If you can bear it, I'd say wait a little longer - the design is still evolving, and I think it's improving.
Also, you can of course say what about the new design is making things harder for you, and maybe that will help. For me the hardest thing left is that GIMP doesn't remember the "right" directory to export images, and that's already being fixed, or at least the design is in place now.
Liam
