Using web transparency
Using web transparency Andrew Douglas Pitonyak 01 Sep 02:18
Using web transparency Ulf-D. Ehlert 01 Sep 21:33
  Using web transparency Andrew Douglas Pitonyak 02 Sep 03:13
2009-09-01 02:18:47 UTC (over 15 years ago)
I am updating src/using/web.xml and I found a paragraph that feels very wrong.
http://docs.gimp.org/2.6/en/gimp-using-web-transparency.html
To point out my complaint, consider:
Step 1: use wilber image
Step 2: Verify you have an alpha channel
The next step, things feel very wrong:
Step 3: You can now remove the background layer to get a completely transparent background, or create a gradient from color to transparency. You are only limited by your imagination. To demonstrate the capabilities of alpha transparency, we'll make a soft glow in the background around our Wilber.
********* Complaints:
Complaint 1:
"You can now remove the background layer to get a completely transparent background"
I do not have a background layer to remove. The image (http://docs.gimp.org/2.6/en/images/using/preparing_for_web1.png) has only one layer named background, which includes Wilber and the background. I assume that this means that I can use an erase to erase the blue and white background.
Complaint 2:
"create a gradient from color to transparency."
This has not yet been covered in the documentation (up to this point). I do see a menu option for Colors > Colors to alpha, but I am not clear how this helps me obtain the soft glow in the background around Wilber.
Complaint 3:
"To demonstrate the capabilities of alpha transparency, we'll make a soft glow in the background around our Wilber."
I suppose that this should read:
"To demonstrate the capabilities of alpha transparency, the author used transparency to make a soft glow in the background around our Wilber."
I have no idea how to cause this effect.
If anyone has an opinion on this section, please say so, otherwise, I will make radical changes to this one paragraph.
Ulf-D. Ehlert
2009-09-01 21:33:11 UTC (over 15 years ago)
Andrew Douglas Pitonyak (Dienstag, 1. September 2009, 02:18):
Complaint 1:
Apparently the author used the Wilber construction set (src/images/Wilber_Construction_Kit_original.xcf) to create an image with two layers: a blue background layer containing the silly flare effect, and a layer containing Wilber with shadow(s).
Consider adding a caption similar to src/toolbox/tool-brush.xml, Paint Mode Examples ("Wilber over a blue background layer") to make that there are two layers.
Complaint 2:
It's one of the standard gradients, see .../gimp-gradient-dialog.html.
Complaint 3:
One way (don't know if there are better ways) is 1. duplicate the layer (wilber with transparency), 2. apply Filters -> Alpha to Logo -> Alien Glow (change the Glow color, e.g. to 255,215,0 = gold). 3. remove the black background layer.
But I can't believe that's what the author had in mind.
Ulf
2009-09-02 03:13:46 UTC (over 15 years ago)
Thanks Ulf. This is enough for me to go on. We need not provide all details at this point. I will think about what I should write while making it clear and trying to keep the original author's intent.
Complaint 1:
Complaint 2:
This has not yet been covered in the documentation (up to this point). I do see a menu option for Colors> Colors to alpha, but I am not clear how this helps me obtain the soft glow in the background around Wilber.
Complaint 3:
Ulf
