buildiing PDF from git
4 of 5 messages available
buildiing PDF from git Ulf-D. Ehlert 27 Aug 22:03
  buildiing PDF from git Alexandre Prokoudine 26 Jan 02:52
   201002042058.26839.ude88@we... Ulf-D. Ehlert 04 Feb 20:58
    buildiing PDF from git Alexandre Prokoudine 11 Feb 23:04
     buildiing PDF from git Alexandre Prokoudine 11 Feb 23:17
Ulf-D. Ehlert
2009-08-27 22:03:21 UTC (over 15 years ago)
Alexandre Prokoudine (Mittwoch, 26. August 2009, 16:13):
On Tue, Aug 25, 2009 at 10:43 PM, Ulf-D. Ehlert wrote:
   o  Use the XeTeX backend, a new tex engine that natively supports Unicode characters:
              dblatex -b xetex file.xml.
   o  Ask for using the latex unicode support by setting the       latex.encoding=utf8 parameter:               dblatex -P latex.encoding=utf8 file.xml.
   o  Use the Passivetex extensions by setting the       latex.unicode.use=1 parameter:               dblatex -P latex.unicode.use=1 file.xml.
Having translations like Chinese as well shouldn't we be using one of those by default?
Probably yes. Did these suggestions work for you?
Ulf
2010-01-26 02:52:58 UTC (about 15 years ago)
Nope. All of the options lead to:
--- snip ---
Build the book set list... Build the listings...
XSLT stylesheets DocBook - LaTeX 2e (0.2.11-1) =================================================== literal not supported in programlisting or screen literal not supported in programlisting or screen No template matches placeholder-1 in para. Processing Bibliography
Output Mode: all
Processing Bibliography - Bibliodiv
Build gimp.pdf
A possible reason for transformation failure is invalid DocBook (as reported by xmllint)
--- snip ---
I see the same for xml/en/gimp.xml too, even though HTML versions for both en and ru build just fine.
Alexandre
2010-02-11 23:04:15 UTC (about 15 years ago)
On 2/4/10, Ulf-D. Ehlert wrote:
This is most likely a result of mixing default xml2po and customized xml2po based po files.
Workaround:
touch every xml source file,
then all pot files (as well as po files, translated xml files, pdf etc.) will be rebuilt when you make pdf or html.
--- snip ---
gimp.tex:67: leading text: \maketitle gimp.tex:67: Encoding scheme `T2A' unknown. gimp.tex:67: leading text: \maketitle gimp.tex:67: Undefined control sequence \cyrm. gimp.tex:67: leading text: \maketitle
--- snip ---
Should I try alternative encoding related commands again?
Alexandre
2010-02-11 23:17:32 UTC (about 15 years ago)
Tried all three. Same :(
Alexandre
