use of bitwise arithmetic in GEGL code
8 of 8 messages available
use of bitwise arithmetic in GEGL code Nicolas Robidoux 06 Aug 21:00
  use of bitwise arithmetic in GEGL code Martin Nordholts 06 Aug 21:03
  use of bitwise arithmetic in GEGL code Martin Nordholts 06 Aug 21:23
   use of bitwise arithmetic in GEGL code Nicolas Robidoux 06 Aug 22:02
    use of bitwise arithmetic in GEGL code Martin Nordholts 06 Aug 22:20
     use of bitwise arithmetic in GEGL code Nicolas Robidoux 06 Aug 22:39
  use of bitwise arithmetic in GEGL code Nathan Summers 06 Aug 22:34
   use of bitwise arithmetic in GEGL code Nicolas Robidoux 08 Aug 15:31
Nicolas Robidoux
2009-08-06 21:00:27 UTC (over 15 years ago)
Is the use of such tricks discouraged for GEGL (because gfloats could be doubles at some point?)
We can take the absolute value by setting the sign bit to zero: // Example 13.24
float f;
*(int*)&f &= 0x7FFFFFFF; // set sign bit to zero
(From http://www.agner.org/optimize/optimizing_cpp.pdf)
Nicolas Robidoux Universite Laurentienne
Martin Nordholts
2009-08-06 21:03:19 UTC (over 15 years ago)
float f;
*(int*)&f&= 0x7FFFFFFF; // set sign bit to zero
Why not use standard library functions?
/ Martin
Martin Nordholts
2009-08-06 21:23:50 UTC (over 15 years ago)
float f;
It was an interesting paper, but I doubt that the gained speed in execution performance outweights the messier code. Plus, his example was to set the sign bit, i.e. x = -abs(x). Maybe x = abs(x) is equal to the above for optimizing compilers
/ Martin
Nicolas Robidoux
2009-08-06 22:02:06 UTC (over 15 years ago)
Michael:
The bit twiddling absolute value was just an example. It's a branch-free float minmod we're actually after.
Do I gather that it may be OK to use such bit twiddling provided the speed gain is sufficient to justify code opacity?
Nicolas Robidoux
PS
Really, vector operations are where speed is to be found. But implementation is a bit more involved than the occasional bit twiddle.
Martin Nordholts
2009-08-06 22:20:02 UTC (over 15 years ago)
On 08/06/2009 10:02 PM, Nicolas Robidoux wrote:
Michael:
If the code is unlikely to require changes later, then I'm fine with these kind of optimizations
/ Martin
Nathan Summers
2009-08-06 22:34:15 UTC (over 15 years ago)
float f;
Doesn't this violate pointer aliasing rules?
Rockwalrus
Nicolas Robidoux
2009-08-06 22:39:09 UTC (over 15 years ago)
Ralf Meyer (another Laurentian prof) did some quick and dirty experimentation with preliminary versions of bit-twiddling minmods and found that on PowerPC chips it made a big difference. Not on Intel.
Not really surprising: Avoiding branches like the plague is more relevant to PowerPC/cell than Intel.
In GEGL (production) code? Not sure.
Nicolas Robidoux
Nicolas Robidoux
2009-08-08 15:31:24 UTC (over 15 years ago)
Nathan Summers writes:
> On Thu, Aug 6, 2009 at 3:00 PM, Nicolas Robidoux wrote > >
> > Is the use of such tricks discouraged for GEGL (because gfloats could > > be doubles at some point?)
> > We can take the absolute value by setting the sign bit to zero: > > // Example 13.24
> > float f;
> > *(int*)&f &= 0x7FFFFFFF; // set sign bit to zero >
Indeed.
Consequence of your observation: The next edition of Agner Fog's online optimization manuals
http://www.agner.org/optimize/#manuals
will contain an updated version of the above example:
union { float f;
int i;
} u;
u.i &= 0x7FFFFFFF; // set sign bit to zero
and the following caveat:
In general, it is faster to access a floating point variable as an integer if it is stored in memory, but not if it is a register variable. The union forces the variable to be stored in memory, at least temporarily. Using the methods in the above examples will therefore be a disadvantage if other nearby parts of the code could benefit from using registers for the same variables. Using type casting of pointers instead of unions in the above examples may not work on compilers that rely on the strict aliasing rule of standard C, specifying that pointers of different types cannot point to the same object, except for char pointers.
Nicolas Robidoux Laurentian University
