buildiing PDF from git
buildiing PDF from git | Alexandre Prokoudine | 03 Aug 17:34 |
buildiing PDF from git | Ulf-D. Ehlert | 03 Aug 20:40 |
buildiing PDF from git | Marco Ciampa | 06 Aug 11:51 |
buildiing PDF from git | Ulf-D. Ehlert | 06 Aug 22:19 |
buildiing PDF from git | Marco Ciampa | 06 Aug 22:57 |
buildiing PDF from git | Ulf-D. Ehlert | 09 Aug 14:17 |
buildiing PDF from git | Marco Ciampa | 11 Aug 20:40 |
buildiing PDF from git | Ulf-D. Ehlert | 12 Aug 12:25 |
buildiing PDF from git | Marco Ciampa | 13 Aug 01:42 |
buildiing PDF from git | Ulf-D. Ehlert | 13 Aug 21:10 |
buildiing PDF from git | Marco Ciampa | 14 Aug 14:13 |
buildiing PDF from git | Alexandre Prokoudine | 24 Aug 11:28 |
buildiing PDF from git | Ulf-D. Ehlert | 25 Aug 20:43 |
buildiing PDF from git | Alexandre Prokoudine | 26 Aug 16:13 |
Trying to follow instructions to build PDF...
pdflatex -interaction=batchmode gimp_tmp.tex
This is pdfTeX, Version 3.14159-1.10a (Web2C 7.4.4)
libpng warning: Ignoring attempt to set cHRM RGB triangle with zero area
pdflatex failed
gimp_tmp.tex:3780: Undefined control sequence \endgroup.
gimp_tmp.tex:3780: leading text: \cite{WKPD-B^^c3^^89ZIER}
Error: pdflatex compilation failed
What am I missing and what further info do you need to figure this out? :)
Alexandre
Alexandre Prokoudine (Montag, 3. August 2009, 17:34): [...]
gimp_tmp.tex:3780: Undefined control sequence \endgroup. gimp_tmp.tex:3780: leading text: \cite{WKPD-B^^c3^^89ZIER} Error: pdflatex compilation failed
In src/appendix/bibliography.xml, replace "WKPD-BÉZIER" with "WKPD-BÉZIER" or "WKPD-BEZIER".
If one of these attempts works, it's probably a dblatex or pdflatex bug.
Ulf
Ulf
I've tried for English and Italian with the same (failed) results...
pdflatex -interaction=batchmode gimp.tex
This is pdfTeXk, Version 3.141592-1.40.3 (Web2C 7.5.6)
%&-line parsing enabled.
entering extended mode
pdflatex failed
A possible reason for transformation failure is invalid DocBook (as reported by xmllint)
What can I do?
Marco Ciampa (Donnerstag, 6. August 2009, 11:51):
I was able to build PDF for en. There's a minor problem with the Makefile, though: pdf/en/gimp.pdf depends on xml/en/gimp.xml, but it should depend on all xml files:
Workaround:
1) In src/appendix/bibliography.xml, replace "WKPD-BÉZIER"
with "WKPD-BEZIER".
2) Update xml/en/appendix/bibliography.xml:
make [-f Makefile.GNU] xml/en/appendix/bibliography.xml
(necessary due to the Makefile bug).
3) Build 'en' PDF:
make [-f Makefile.GNU] pdf-en
No. If you validate a single file, xmllint can't resolve links. Always
use
make validate-en
Ulf
Workaround: 1) In src/appendix/bibliography.xml, replace "WKPD-BÉZIER" with "WKPD-BEZIER".
2) Update xml/en/appendix/bibliography.xml: make [-f Makefile.GNU] xml/en/appendix/bibliography.xml (necessary due to the Makefile bug). 3) Build 'en' PDF:
Why not to put it directly on the git repo? May I do it? Anyone disagree? A bibliography tag has not to be correctly accented (IMHO)...
No. If you validate a single file, xmllint can't resolve links. Always use
make validate-enUlf
... that was not me but the make output error...you see, the English is correct! :-)
bye
Marco Ciampa (Donnerstag, 6. August 2009, 22:57):
1 1 0 1 ;-)
Ulf
1 1 0 1 ;-)
Ulf
ok green light!
...but I still see problems and the pdf is't build.
here the command output:
==================================0
$make pdf
Making pdf in quickreference
make[1]: ingresso nella directory
«/home/marco/git-gnome/gimp-help-2/quickreference»
make[1]: Non c'è da fare nulla per «pdf»
make[1]: uscita dalla directory
make[1]: ingresso nella directory «/home/marco/git-gnome/gimp-help-2»
*** Copying images (en) ... 1475
*** Making PDF (en) ...
/usr/share/dblatex/lib/dbtexmf/dblatex/grubber/util.py:8:
/ DeprecationWarning: the md5 module is deprecated; use hashlib instead
import md5
Build the book set list...
xsltproc --xinclude -o /tmp/tmpsdL9Qi/doclist.txt doclist.xsl
/home/marco/git-gnome/gimp-help-2/xml/en/gimp.xml
Build the listings...
xsltproc --xinclude -o /tmp/tmpsdL9Qi/listings.xml --param current.dir
'/home/marco/git-gnome/gimp-help-2/xml/en'
/usr/share/dblatex/xsl/common/mklistings.xsl
/ /home/marco/git-gnome/gimp-help-2/xml/en/gimp.xml
xsltproc --xinclude -o gimp.rtex --param current.dir
'/home/marco/git-gnome/gimp-help-2/xml/en' --param listings.xml
'/tmp/tmpsdL9Qi/listings.xml' custom.xsl
XSLT stylesheets DocBook - LaTeX 2e (0.2.11-1)
literal not supported in programlisting or screen
Processing Bibliography
Output Mode: all
Processing Bibliography - Bibliodiv
Missing character 최
Missing character 지
Missing character 희
Missing character 蔡
Missing character 芊
Missing character 杨
Missing character 红
Build gimp.pdf
built-in module pdftex registered
no support found for ifxetex
no support found for fontspec
no support found for xltxtra
no support found for fontenc
no support found for inputenc
no support found for fancybox
built-in module makeidx registered
no support found for docbook
no support found for unicode
built-in module bibtopic registered
building additional files...
checking if compiling is necessary...
the output file doesn't exist
pdflatex failed
any hint on how to spot this problem out? Where (which logs) I should go and see? ./log/en-xmllint.log says a lanconic "no error" ...
(this output is for the "en" PDF, the "it" is similarly not build...)
TIA
Marco Ciampa (Dienstag, 11. August 2009, 20:40):
You can pass the '--debug' option to dblatex. e.g.
make [-f Makefile.GNU] pdf-en DBLATEXEXTRAFLAGS='--debug' 2>&1 \ | tee log/en-pdf.log
Then the temporary directory won't be removed (and the "tee" command saves the output) and you can check the TeX and log files.
Ulf
Ulf
Many thanks. This is the log:
import md5
xsltproc --xinclude -o /tmp/tmp0nVd9Q/doclist.txt doclist.xsl
xsltproc --xinclude -o /tmp/tmp0nVd9Q/listings.xml --param current.dir
'/tmp/tmp0nVd9Q/listings.xml' custom.xsl
Output Mode: all
Build gimp.pdf
pdflatex failed
Missing character 최
Missing character 지
Missing character 희
Missing character 蔡
Missing character 芊
Missing character 杨
Missing character 红
/tmp/tmp0nVd9Q not removed
but perhaps this is more useful, the end of gimp.log:
File: /home/marco/git-gnome/gimp-help-2/xml/en//images/using/gif-save-dialog.pn g Graphic file (type png)
! pdfTeX error (ext1): invalid image dimensions.
... page \GPT@page \fi {\Gin@base .pdf}
\setbox \@tempboxa =\hbox
l.3193 \begin{DBKadmonition}{warning}{Warning}
Here is how much of TeX's memory you used:
11347 strings out of 95086
181591 string characters out of 1183255
208873 words of memory out of 1500000
13687 multiletter control sequences out of 10000+50000
101717 words of font info for 158 fonts, out of 1200000 for 2000
28 hyphenation exceptions out of 8191
48i,20n,45p,2418b,506s stack positions out of
5000i,500n,6000p,200000b,5000s
! ==> Fatal error occurred, no output PDF file produced!
invalid image dimensions???? This is strange...
Marco Ciampa (Donnerstag, 13. August 2009, 01:42): [...]
libpng warning: Ignoring attempt to set cHRM RGB triangle with zero area libpng warning: Ignoring attempt to set cHRM RGB triangle with zero area libpng warning: Ignoring attempt to set cHRM RGB triangle with zero area pdflatex failed
/home/marco/git-gnome/gimp-help-2/xml/en//images/using/gif-save-dia log.png! pdfTeX error (ext1): invalid image dimensions.
I can't reproduce it: no libpng warnings, no invalid dimensions, and 'gimp.pdf' successfully built - using the following programs/libraries:
dblatex-0.2.9 texlive-2007-177.1 (by openSUSE 11.0) libpng-1.2.26
Ulf
Ulf
Hi Ulf, once again thanks to help me spotting this out. It comes it was due to this bug (I use karmic):
https://bugs.launchpad.net/ubuntu/+source/poppler/+bug/409673
so I'll be able to create pdf really soon!
Lucky you :)
gimp_tmp.tex:23402: You can't use `\spacefactor' in math mode. gimp_tmp.tex:23402: leading text: ...d0^^bd^^d1^^82^^d1^^83^^d1^^80^^d1^^83} gimp_tmp.tex:23402: Package inputenc Error: Keyboard character used is undefined gimp_tmp.tex:23402: leading text: ...d0^^bd^^d1^^82^^d1^^83^^d1^^80^^d1^^83} gimp_tmp.tex:23402: Missing $ inserted. gimp_tmp.tex:23402: leading text: ...d0^^bd^^d1^^82^^d1^^83^^d1^^80^^d1^^83} gimp_tmp.tex:26574: TeX capacity exceeded, sorry [main memory size=1000001]. gimp_tmp.tex:26574: leading text: ...examples/color-taj-ccanalyse.jpg}}}}}{}
Alexandre
Alexandre Prokoudine (Montag, 24. August 2009, 11:28):
Lucky you :)
I've just made an upgrade to dblate-2.12 and found the following question and answer in the FAQ -- maybe this will help you:
Q: I cannot compile my cyrillic document. Why?
A: A document using some characters different from the roman alphabet may face some troubles, because latex natively handles only latin1 encoding.
Try the different unicode supports provided by dblatex:
o Use the XeTeX backend, a new tex engine that natively supports
Unicode characters:
dblatex -b xetex file.xml.
o Ask for using the latex unicode support by setting the latex.encoding=utf8 parameter: dblatex -P latex.encoding=utf8 file.xml.
o Use the Passivetex extensions by setting the latex.unicode.use=1 parameter: dblatex -P latex.unicode.use=1 file.xml.
Ulf
On Tue, Aug 25, 2009 at 10:43 PM, Ulf-D. Ehlert wrote:
o Use the XeTeX backend, a new tex engine that natively supports Unicode characters:
dblatex -b xetex file.xml.o Ask for using the latex unicode support by setting the latex.encoding=utf8 parameter: dblatex -P latex.encoding=utf8 file.xml.
Having translations like Chinese as well shouldn't we be using one of those by default?
Alexandre
