Abyss color
Abyss color Eric Daoust 01 Aug 01:36
  Abyss color Martin Nordholts 01 Aug 09:26
   Abyss color Eric Daoust 07 Aug 19:47
    Abyss color Martin Nordholts 07 Aug 19:57
     Abyss color Eric Daoust 07 Aug 20:13
      Abyss color Nicolas Robidoux 07 Aug 20:19
Eric Daoust
2009-08-01 01:36:19 UTC (over 15 years ago)
Abyss color
Currently the defauly abyss color is 0,0,0,0 (RGBA). What would have to be done to allow users to specify their own abyss color?
Thanks, Eric
Martin Nordholts
2009-08-01 09:26:17 UTC (over 15 years ago)
Abyss color
Since the abyss logic is in GeglBuffer (gegl-buffer-access.c), I would add the abyss color as a property to the GeglBuffer.
/ Martin
Eric Daoust
2009-08-07 19:47:37 UTC (over 15 years ago)
Abyss color
Thanks for the reply.
How would I pass this information from my XML test file to gegl-buffer-access.c?
Example XML code (image rotation test using my upsharpfast sampler):
0.000000
0.000000
7.000000
upsharpfast
data/roemerlogo_large.png
Thanks,
Eric
 / Martin
Martin Nordholts
2009-08-07 19:57:02 UTC (over 15 years ago)
Abyss color
0.000000
0.000000
7.000000
upsharpfast
The properties in the XML file are set on operations, and GeglBuffer is not an operation.
You can add a property to gegl:rotate and pass that along to GeglBuffer. Perhaps not the prettiest, but it would work.
/ Martin
Eric Daoust
2009-08-07 20:13:49 UTC (over 15 years ago)
Abyss color
 / Martin
Sorry, I should have been more specific.
The rotation script is just one example of tests being done on the samplers. I am also doing scaling operations. An example of this would be:
What would be the most general way of getting this abyss color to gegl-buffer-access.c?
Thanks again, Eric
Nicolas Robidoux
2009-08-07 20:19:18 UTC (over 15 years ago)
Abyss color
gegl/operations/affine/affine.c
would take care of rotation and scaling and a few other things, although it probably is still not general enough.
Nicolas Robidoux Universite Laurentienne
