http post or ftp post
http post or ftp post Nico 25 Jul 15:12
  http post or ftp post Joao S. O. Bueno 25 Jul 19:27
   http post or ftp post Nico 26 Jul 22:38
    http post or ftp post Nico 26 Jul 22:45
  http post or ftp post Kevin Cozens 27 Jul 16:13
Nico
2009-07-25 15:12:55 UTC (over 16 years ago)
Hi
Is it possible to send data (http and/or ftp) in a script-fu plugin ? Some examples ?
Wich way ?
Nico
Joao S. O. Bueno
2009-07-25 19:27:18 UTC (over 16 years ago)
On Saturday 25 July 2009, Nico wrote:
Hi
Wich way ?
Nico
The Scheme intrpreter used in script-fu it is there because an scheme interpreter is tiny enough to fit inside the source tree. (And for historical reasons as well, of course.) There are no libraries or moduyle to provide the tiny-fu scheme with much outside the GIMP API and some basic file I/O. So, while with unixish systems it is possible to provide a pipe/socket setup to make tiny-fu scripts answer network requests, that is not the way to do it.
For doing larger applications, you should use plug-ins in a language that can make full use of libraries and modules manintained outside of the GIMP project. The oficial high level language supported for GIMP plug-ins is Python, and it is easy to make data available via vairous network protocols using Python's standard libraries.
There re also gimp bindings for perl (although I think this is currently unmaintained) and ruby should you prefer these languages.
js ->
Nico
2009-07-26 22:38:16 UTC (about 16 years ago)
Hi
Wich way ?
Nico
Thanks for answer.
Is it a link to begin with python-fu ?
Nico
js
Nico
2009-07-26 22:45:23 UTC (about 16 years ago)
Hi
Wich way ?
Nico
Thanks for answer.
ok sorry : http://www.gimp.org/docs/python/pygimp.html
Nico
js
Kevin Cozens
2009-07-27 16:13:10 UTC (about 16 years ago)
It is not possible to do this with a default installation of GIMP. Socket handling functions exist for the TinyScheme interpreter in something called TinyScheme Extensions (tsx) which can be found at http://heras-gilsanz.com/manuel/tsx.html
It is a set of run-time loadable extensions for TinyScheme that adds functions related to sockets, file I/O, date and time, plus getenv and system calls. Currently, the loading of TinyScheme extensions is disabled by default.
If you want to get your hands dirty you could get tsx working with Script-Fu but it would require compiling GIMP (or the Script-Fu component) yourself. Run-time loadable extensions would need to be enabled, tsx compiled to exclude building of its file I/O and date routines (which are already included in Script-Fu), then building and installing tsx.
Admittedly, it is not something that average user would want to tackle. I was planning on enabling the run-time loading of extensions by TinyScheme. Perhaps, now is the time to do itn.
