add feature to change "ctrl" and "shift" shortcuts
add feature to change "ctrl" and "shift" shortcuts Luis Diego Alpizar Alpizar 23 Jul 21:15
  add feature to change "ctrl" and "shift" shortcuts Sven Neumann 23 Jul 21:36
2009-07-23 21:15:30 UTC (almost 16 years ago)
I think i cannot change the default keys to pick a colour(ctrl) or to make a straight line using the paint tools(Shift) There is a future implementation to bring the chance to modify this shortcuts?
I got a pen tablet and wanted to change the straight line shorcuts to the pen tablet buttons, so i could draw with my pen,
but i cannot do that, and GIMP for some odd reason won't detect my pen tablet configuration(i changed wacom pen tablet preferences, to set a button to be "ctrl") but didn't work, as GIMP opens the right-click menu instead of doing "ctrl" function(or shift).
__________________
2009-07-23 21:36:41 UTC (almost 16 years ago)
Your idea of configuring the tablet is the right thing to do here. If that doesn't work, then please ask Wacom to fix this.
