How far away from watching other colorspaces in real time?
7 of 7 messages available
How far away from watching other colorspaces in real time? Martin Cracauer 22 Jul 23:59
  How far away from watching other colorspaces in real time? Martin Nordholts 23 Jul 00:14
   How far away from watching other colorspaces in real time? Martin Cracauer 23 Jul 00:27
    How far away from watching other colorspaces in real time? Martin Nordholts 23 Jul 00:37
     How far away from watching other colorspaces in real time? Martin Cracauer 23 Jul 04:11
      How far away from watching other colorspaces in real time? Martin Nordholts 23 Jul 07:54
      How far away from watching other colorspaces in real time? David Gowers 23 Jul 07:54
Martin Cracauer
2009-07-22 23:59:14 UTC (almost 16 years ago)
Hi.
Can somebody tell me how far away GIMP is from being able to view manipulations that you do in a different color space in real time in real colors?
I could get along with constant recomposing to view with HSV. But I have recently discovered the LAB colorspace which does really useful things for me. But now it is a pain that I cannot mess with the LAB layers and see how the picture looks like.
Photoshop seems to do it, although I haven't personally observed it. How do they do it quick enough? Is it quick in the first place?
Even a preview with a much smaller picture or magnified rectangle would be very useful. I don't need too high precision since I usually take the result of LAB layers for mixing with existing layers, so the colors coming out of LAB aren't the final word.
Martin
Martin Nordholts
2009-07-23 00:14:15 UTC (almost 16 years ago)
On 07/22/2009 11:59 PM, Martin Cracauer wrote:
Hi.
The current plan is get GIMP 2.8 out the door asap, hopefully within the next few months. Once that is done we will finish porting GIMP to GEGL. That means finally getting rid of all 8bpc-only code and introduce the GEGL data types. With the help of the babl library, GEGL can transparently process image data in any color space, including CIE Lab. See http://www.gegl.org/babl/BablFishPath.html for a more complete list.
Currently, neither babl nor GEGL is aware of ICC color profiles, but I don't expect it to be too much work to make GEGL color-profile aware. It is just a matter of feeding the right data into GEGL, which for the vast majority of operations works in linear light RGBA float.
So, once we have GEGL in place, working in any color space that has a one-to-one mapping to and from linear light RGBA (this does not include CMYK), should be fairly trivial.
/ Martin
Martin Cracauer
2009-07-23 00:27:07 UTC (almost 16 years ago)
Martin Nordholts wrote on Thu, Jul 23, 2009 at 12:16:34AM +0200:
Hi.
That sounds great.
Do I understand that correctly that you will move to single-floats/color?
What exactly happens when you select the "use GEGL" menu item right now? It uses GEGL but only with the current capabilities? Does it give more than 8 bits/pixel?
Martin
Martin Nordholts
2009-07-23 00:37:43 UTC (almost 16 years ago)
Yes, virtually all image processing and compositing will be performed in the linear light RGBA color space with 32 bit float depth per channel. There have been discussions about introducing regression tested optimizations for 8 and 16 bit depths, but I don't expect any effort to be put into that soon. First, we need to finalize getting GEGL into GIMP.
If you in GIMP 2.6 enable Colors -> Use GEGL, then the image processing itself will occur in RGBA float for the color tools. However, the data being processed is stored as RGBA u8. That means that if you do an color adjustment with Use GEGL enabled, then you first have to convert that data to RGBA float for processing, and than back to RGBA u8 to store it again. In other words, not very useful to the end user.
If you in the yet not officially released GIMP 2.7 do View -> Use GEGL, then the layers will be composited using GEGL. In other words, we have the layers etc ported to a GEGL graph. It is worth mentioning that it is technically trivial to insert non-destructive nodes in the graph, but our focus now is getting GIMP 2.8 out.
/ Martin
Martin Cracauer
2009-07-23 04:11:06 UTC (almost 16 years ago)
Martin Nordholts wrote on Thu, Jul 23, 2009 at 12:40:06AM +0200:
I use the git version of last week. Lost my tablet (probably due to some dbus API issue) but works otherwise.
Let me just poke some more.
And does all this survive layer copying and other changes?
Let's use an example: I like to use the levels tools with a non-destructive adjustment first and although 2.6/2.7 allow me to take the levels I found right to curves I usually don't do this. I prefer to commit the level change, then duplicate the layer and mess with the curves in the new layer. This, of course, causes me losses from interpolation with the 8-bit channels, where it would not if I would edit levels and curves in the same moment without committing levels first and start over with curves. Does current 2.7 carry floating point layers through all of this?
I just tried this and I get the same teeth in the histogram in 2.7 no matter whether I asked it to use GEGL or not, but I'm not sure I activate it the right way. This was just on a layer originating from a JPEG.
Does 2.7 as is support storing and reloading the floating point format in *.xcf files?
Martin
Martin Nordholts
2009-07-23 07:54:33 UTC (almost 16 years ago)
No, in git master, everything feeded to a GEGL graph is RGBA u8, and everything returned is RGBA u8, it is just the intermediate processing that is done in RGBA float. Part of the remedy for this is replacing GIMP's TileManager with GEGL's GeglBuffer, which can store image data in any format supported by babl.
/ Martin
David Gowers
2009-07-23 07:54:51 UTC (almost 16 years ago)
GEGL graphs are completely non-destructive (of course, you can flatten part or all of a graph to destroy information at any time.) The plan for GIMP here is that it will only modify the graph in the course of usual operations, which will enable the option of fully non-destructive workflow.
In this system, we simply have to decide the way to present this ability to insert arbitrary nodes at arbitrary positions to the user. The idea I regard as most sensible here is simply treating nodes like a container -- that is, the input being made up of 1 or more node outputs composited together. With this idea, you would be attaching an effect to a group of layers (and effects
There are issues with the above (primarily, I oversimplified -- we need to deal with nodes that simply produce, like eg. checkerboard, constant color, as well as filtering nodes), but that's a reasonable overall way to think about it for now.
IMO GIMP is heading towards providing a fairly thin abstraction layer over the abilities of GEGL graphs, which in general is good news for anyone concerned about possible leaky abstraction ("does all this survive layer copying and other changes") -- thick abstraction layers tend to be much leakier (for example, Photoshop's "Adjustment Layers" idea -- they are only layers in an absurdly broad sense (so broad as to be nearly meaningless), so they tend to disobey common-sense rules followed by other types of layer.)
In short:
the capacity for inserting arbitrary nodes is available in GEGL, but GIMP does not currently adulterate the constructed layer graph in any way; When some ability to control the graph in a finer way (like I described) is implemented, we ought to have moved on to the next-generation file format, which should support it in a straightforward way
Even shorter: A completely theoretical yes, since such functionality is currently available in GEGL, not leveraged by GIMP or presented to the user yet.
There are no floating point layers yet. During the composition, the layer pixels are automatically converted to floating point, and converted back after composition. to display the finished projection. Thus, the difference in the resulting image is minimal.
During the application of a color tool, a similar thing happens: pixels are converted to float, the change is applied, and pixels are converted back. Eventually, using a color tool will just modify the image graph rather than directly writing pixels; at this time, floating point values will be preserved through that operation (and presumably most subsequently operations -- obviously if there is an explicit 'convert to 8bit' operation in use, floating point values are not going to last beyond that.
Again, floating point currently has nothing to do with the normal representation of image in the GIMP, yet. This should answer your question.
I believe we are planning to move to a new native image format for 3.0, which will address such problems as: metadata support being bolted on rather than a standard part of the file format, more sophisticated ICC support, support of higher bitdepths, support of different color models (LAB, YCbCr etc)...
David
