contact sheet : some questions
8 of 9 messages available
contact sheet : some questions Nico 21 Jul 21:57
  contact sheet : some questions Kevin Cozens 21 Jul 23:00
   contact sheet : some questions Nico 22 Jul 00:10
   contact sheet : some questions Nico 23 Jul 10:42
    contact sheet : some questions Nico 23 Jul 10:50
    contact sheet : some questions Sven Neumann 23 Jul 18:41
3644709b0907211518j7b0bc4d4... 07 Oct 20:27
  contact sheet : some questions Nico 22 Jul 00:22
   contact sheet : some questions Kevin Cozens 22 Jul 02:07
Nico
2009-07-21 21:57:45 UTC (over 16 years ago)
Hi
I have work on this script : http://www.gimp-attitude.org/forum/viewtopic.php?t=5904&sid=b4258adb87aec27867805ea3ea02ed91
I have got enough 2 problems : - I can't run it on a directory that have a peripheric location on Windows (DVD, usb-key...) - look at the SF-DIR return - I can't run the script when no image is opened (and I can't find how to do it)
Any idea to fix it ?
One question more : why some script's name are begun with _ ?
I think about some evolutions : working with more kinds of filetype (tif, png, jpeg, tiff etc.), choose dimensions of the contact sheet...
Nico
Kevin Cozens
2009-07-21 23:00:30 UTC (over 16 years ago)
I can't comment much on this. The script should not care where the files are located.
There is an error in the script-fu-register block. The image type is listed as "*" when it should be "".
I don't know of any scripts where the names start with _. The use of - vs. _ within a name depends on the conventions of the particular scripting language used.
Nico
2009-07-22 00:10:03 UTC (over 16 years ago)
Hi
Thanks
I'm sorry but I don't understand what problem do you have ? (problem to translate :( ) Do I understand the script doesn't work at all ?
I test it on different configuration (GIMP 2.4 Linux, 2.6 winXP), and there is no problem with directory/files on harddrive.
In this script, the file path on windows c:\dir\test is changed to /dir/test. If not, file-glob doesn't work with a win'path Lines 74 to 86
Thanks, it works :)
I didn't find this information.
You can see it by example :
(script-fu-register "script-fu-3d-outline-logo" _"3D _Outline..."
_"Create a logo with outlined text and a drop shadow" in /usr/share/gimp/2.0/scripts/3d-outline.scm
Nico
Nico
2009-07-22 00:22:18 UTC (over 16 years ago)
Rob Antonishen a écrit :
The underscore signifies text strings that can (do?) have internationilization/translation strings for other language support, but I have no idea how the language files are made or stored.
Where can I find this kind of information ? (second part : "how work the internationalisation")
Nico
-Rob A>
Hi
Thanks
Thanks, it works :)
Nico
Kevin Cozens
2009-07-22 02:07:56 UTC (over 16 years ago)
Look up the documentation for intltool (http://www.freedesktop.org/wiki/Software/intltool) and gettext.
Nico
2009-07-23 10:42:25 UTC (over 16 years ago)
I see that there is a problem with dirname that have é ç à or è... under Linux. I mean that is encoding problem
But I tri :
(file-glob "/home/nico/Téléchargement/*.jpg" 1)
(2 ("/home/nico/T" "/home/nico/T"))
(file-glob "/home/nico/Téléchargement/*.jpg" 0)
And then problem to list the files :(
Do you know how I can fix it ?
Nico
Nico
2009-07-23 10:50:31 UTC (over 16 years ago)
Gimp message :
La procédure « gimp-message » a été appelée avec la valeur « Erreur à l'exécution de
(script-fu-tounoki-contact "/home/nico/Téléchargement" 4 TRUE '(0 0 0) "Generated with tounoki-contact")
Error: Error reading string  » pour l'argument « message » (#1, type gchararray). Cette valeur est hors-limite.
But I tri :
Nico
2009-07-23 18:41:24 UTC (over 16 years ago)
Try to specify the filenames in UTF-8 encoding. And actually, you should also use UTF-8 for your filesystem. Everything else is broken and only works (to some extent) if you set the environment variable G_BROKEN_FILENAMES.
