gegl build problem (babl include)
gegl build problem (babl include) Mason Thomas 18 Jul 19:52
  gegl build problem (babl include) Martin Nordholts 18 Jul 19:59
   gegl build problem (babl include) Mason Thomas 18 Jul 21:29
Mason Thomas
2009-07-18 19:52:10 UTC (almost 16 years ago)
I am having some difficulty building the most recent gegl (from a git clone). I cloned the babl repository and successfully built that, but the gegl build stops when it tries to include in gegl/buffers/gegl-tile-source.h.
Note I am building these libraries in a local directory. For babl I do: ./autogen.sh --prefix=/home/mason/localinstall make
make install
and for gegl I use: BABL_LIBS=/home/mason/localinstall/lib BABL_CFLAGS="-O2" ./autogen.sh --prefix=/home/mason/localinstall make
The make fails when trying to include the babl header. Should the configure script catch the different location of the babl directories, or is there a commonly understood step I am missing?
Thanks,
-Mason
__________________
Martin Nordholts
2009-07-18 19:59:34 UTC (almost 16 years ago)
make install
make
Hi Mason,
Instead of setting the BABL_LIBS/CFLAGS manually you should use pkg-config. To use pkg-config you set the PKG_CONFIG_PATH=/home/mason/localinstall/lib/pkgconfig
But there is an even better trick, the config.site. Put this content in the file /home/mason/localinstall/share/config.site:
export CFLAGS="-g -O0" export PKG_CONFIG_PATH="/home/mason/li/lib/pkgconfig:$PKG_CONFIG_PATH" export LD_LIBRARY_PATH="/home/mason/li/lib:$LD_LIBRARY_PATH"
and then that file will be sourced automatically whenever you invoke configure with that prefix. This means that the Makefile.am build dependencies that are setup are managed correctly and most of the time it is enough to make after a git pull --rebase.
HTH, Martin
Mason Thomas
2009-07-18 21:29:59 UTC (almost 16 years ago)
Date: Sat, 18 Jul 2009 20:01:57 +0200
make install
make
Hi Mason,
HTH, Martin
Yes, that worked. Many thanks.
-Mason
__________________
