Applying GIT patch
Applying GIT patch Eric Daoust 15 Jul 21:59
  Applying GIT patch Martin Nordholts 15 Jul 22:04
Eric Daoust
2009-07-15 21:59:52 UTC (over 16 years ago)
Applying GIT patch
I have uploaded a couple patches (tarballs containing multiple commits) to bugzilla. What is the correct method to apply these patches so that others can see my work?
Thank you, Eric
Martin Nordholts
2009-07-15 22:04:21 UTC (over 16 years ago)
Applying GIT patch
To apply patches created with git-format-patch, use git-am, like this:
git am 0001-single-file.patch
or for multi-file commits:
tar -zxvf lots-of-commits.tar.gz git am lots-of-commits/*
where lots-of-commits contains the files
0001-foo.patch 0002-bar.patch
0003-foo-bar.patch
Often, you might want to create a new branch before you apply them
git checkout -b lots-of-commits origin/master
HTH, Martin
