PerfECT code repository
PerfECT code repository Henrik Akesson 11 Jul 08:14
  PerfECT code repository Martin Nordholts 14 Jul 10:11
   PerfECT code repository Henrik Akesson 15 Jul 21:48
Henrik Akesson
2009-07-11 08:14:48 UTC (almost 16 years ago)
There are for the moment some discussion as to wheter the code I've produced should be in the main gimp project or in a separate one.
However, at this point, I feel that it should be under some version control system, for ease of sharing and security. Thus, I've commited it to the following google code site: http://code.google.com/p/perfekt/
(the name perfect was already taken)
I will of course move it, if necessary, according to the descision taken (when it is taken).
Best regards,
Henrik
Martin Nordholts
2009-07-14 10:11:29 UTC (almost 16 years ago)
Hi Henrik
Could you give rough step-by-steps on how to run this please?
BR, Martin
Henrik Akesson
2009-07-15 21:48:49 UTC (almost 16 years ago)
My excuses for the delay. I decided to test the project build and setup on a second platform and found some problems: - Arrays.copyOf is only java 1.6 and I want to keep the compatability with java 1.5
- servlet-api.jar mistakenly included in war file (only necessary at build-time) - ant build errors
- etc...
these have been fixed and I've created a wiki page with the instructions:
http://code.google.com/p/perfekt/wiki/InstallationAndSetup
You'll also need to read:
http://code.google.com/p/perfekt/issues/detail?id=1
Henrik
2009/7/14 Martin Nordholts :
Hi Henrik
BR, Martin
