Spawn a new project?
Spawn a new project? Henrik Akesson 07 Jul 15:45
  Spawn a new project? Martin Nordholts 07 Jul 20:23
   Spawn a new project? Henrik Akesson 08 Jul 12:00
Henrik Akesson
2009-07-07 15:45:22 UTC (almost 16 years ago)
the work I've done so far can be split into two parts: 1) gegl scripting - for the moment a ruby script that allows me to run tests of gegl and some test cases.
2) visualisation tool - a java web project that is made for displaying performance data.
1) should obviously be commited to the gegl project. 2) however, I believe should be a new open source project.
For the moment, I've named the visualisation tool PerfECT, for Performance Evaluation and Control Tool.
I propose to create a new open source project at code.google.com using a LGPL license.
Do you have any preferences as to which version control system I should use? The google code hosting offers Mercurial and SVN. I'm leaning towards using SVN on the server and git-svn on my laptop, mainly because I already know both svn and git (well, git only a little bit).
Henrik
Martin Nordholts
2009-07-07 20:23:05 UTC (almost 16 years ago)
How does the dependencies look here? I suppose GEGL would have a soft (optional) dependency on the visualization tool?
And as for the VCS preference, git is my clear preference, it's a shame Google Code doesn't offer that.
/ Martin
Henrik Akesson
2009-07-08 12:00:53 UTC (almost 16 years ago)
The only dependency there is between the visualisation tool and GEGL would be the output file format from callgrind.
/Henrik
2009/7/7 Martin Nordholts :
 / Martin
