tab-menu.png seems wrong
tab-menu.png seems wrong Andrew Douglas Pitonyak 03 Jul 18:29
  tab-menu.png seems wrong Sven Neumann 03 Jul 20:45
2009-07-03 18:29:02 UTC (almost 16 years ago)
Issues on DOCKS
http://docs.gimp.org/2.6/en/gimp-concepts-docks.html
The documentation uses the following image, which differs from mine (see attached PNG). You will notice that I have an extra menu item: Show Button Bar
http://docs.gimp.org/2.6/en/images/using/tab-menu.png
Problem with the documentation that I should fix, or something special about my Fedora Core 11 installation?
Moving rights along, look at Figure 3.9
http://docs.gimp.org/2.6/en/images/using/dialog-highlight-tabmenu.png
Notice that the tab menu button is circled (as it should be). Now, look directly to the right of the tab menu button, there is an x. I do not have this x. The "Close Tab" entry mentions a "Close Tab" button, and I assume that they refer to this x. I do not have this x. Again, is this an issue with my setup, in which case I will push on. Otherwise, I will probably take some more screen shots and remove references to the "Close Tab" button.
Do I need to take new screen shots, or is there something about my installation?
2009-07-03 20:45:19 UTC (almost 16 years ago)
The screens-shot seems to be from GIMP 2.4 and needs to be updated.
Again, the screen-shot is from 2.4. The 'Close' button has been removed in GIMP 2.6.
