What's next for the meta-data browser
What's next for the meta-data browser Roman Joost 02 Jul 03:53
  What's next for the meta-data browser Sven Neumann 02 Jul 21:58
   What's next for the meta-data browser Roman Joost 04 Jul 15:40
Roman Joost
2009-07-02 03:53:41 UTC (over 16 years ago)
Hi folks,
I'm currently devoting some of my spare time on working on the metadata browser and I'm wondering which should be worked on next. As a quick background:
The metadata browser currently consists of seven tabs: Description, Copyright, Origin, Camera 1, Camera 2, Advanced. Only two tabs "work": Description and Advanced. The first tab shows dublin core metadata fields, such as: title author, description, keywords. The last - advanced - tab, shows schemas and their properties expanded as a tree. Some of the property values can be edited by the user, some can't.
So, I picked as a next working target the description tab.
Two questions:
1. Do I have to be careful when entry callbacks write to the XMPModel (or any other model or structure) everytime a user types in a character (performance wise)?
2. I tried to find out how I can add callbacks to editable tree items. Those callbacks should update the corresponding fields in the description tab. E.g someone changes in the advanced tab the title field. This change should then visible in the description tab and the title has changed.
What am I looking for, when I want to add callbacks to those tree columns? A pointer to documentation or some keywords I should look out for would be helpful.
If there are more important changes for the browser than the description tab, let me know. Maybe I should rather focus on make the advanced tab more usable ... don't know.
If you need more information to provide useful help, let me know :)
Cheers!
2009-07-02 21:58:33 UTC (over 16 years ago)
On Thu, 2009-07-02 at 11:53 +1000, Roman Joost wrote:
Two questions:
Usually this is not a problem. But if it turns out to be one (because changing the model is expensive), then you might want to delay changes to the model. You can do that for example by not connecting to 'changed' but instead apply the changes when the dialog is closed. Or you could connect to 'activate' and 'leave-notify-event' and apply the change when the user presses Enter and when the focus leaves the entry.
You want to connect to the 'edited' signal of the GtkCellRendererText object that is responsible for rendering the editable cell.
Roman Joost
2009-07-04 15:40:05 UTC (over 16 years ago)
On Thu, Jul 02, 2009 at 09:58:33PM +0200, Sven Neumann wrote:
Two questions:
Cheers for that response! Helped a lot!
Greetings,
