New color mode
11 of 11 messages available
New color mode Emil Assarsson 29 Jun 00:35
  New color mode Owen 29 Jun 00:49
  New color mode Martin Nordholts 29 Jun 06:57
   New color mode David Gowers 29 Jun 07:30
    New color mode Martin Nordholts 29 Jun 07:37
     New color mode Emil Assarsson 29 Jun 10:31
      New color mode Martin Nordholts 29 Jun 21:31
       New color mode Emil Assarsson 01 Jul 20:21
        New color mode Martin Nordholts 01 Jul 20:24
  New color mode Andrew A. Gill 29 Jun 07:26
  New color mode Emil Assarsson 29 Jun 15:42
Emil Assarsson
2009-06-29 00:35:13 UTC (over 16 years ago)
New color mode
Hi
I'm interested in writing a new color mode for gimp. I find the normal too saturated and would like to make a new more vivid.
I'm new to Gimp development and I think I need to discuss this with someone before starting. Do anyone got any pointers or information about how I should proceed with this? Are there any changes to the code structure that will permit this to be done with a plugin eventually?
Emil
Owen
2009-06-29 00:49:34 UTC (over 16 years ago)
New color mode
Hi
Just wondering what you mean by a "new color mode" (like RGB or Grayscale)
Or are you thinking about the swatches available. If so, these are just a text file (look at your palettes) and modify to suit.
Apolgies if I have you completely wrong
Martin Nordholts
2009-06-29 06:57:47 UTC (over 16 years ago)
New color mode
Emil Assarsson wrote:
Hi
Hi!
Exactly what do you mean by "color mode" here?
Do you mean that the default RGB -> CMYK conversion produces too saturated colors?
Best regards, Martin
Andrew A. Gill
2009-06-29 07:26:39 UTC (over 16 years ago)
New color mode
Hmmm...
Saturation (at least in the HSV model) is pretty much a synonym for vividness.
Are you talking about what you see when you print it out? Is it too dark or muddy? That can also be called saturation, but it's a different concept, and may be better discussed by the folks involved in Gutenprint.
If I don't have that right, you might want to look at the following site:
and make sure you've got the right term.
David Gowers
2009-06-29 07:30:23 UTC (over 16 years ago)
New color mode
I'm pretty sure Emil refers to the Color drawing /layer mode and the way that it tends to 'burn out' colors -- the result of applying a colorization is often far more vivid than could reasonably be expected; Basically the same as the bug regarding improvement of Color mode cf. Photoshop. A few theories have been advanced on how Photoshop does it; they both agree that an RGB-based application such as the current HSL application is incorrect, and IIRC argue for either LAB or YIQ/YCbCr based color application. In my opinion LAB is higher quality, however YIQ/YCbCr get the job done with acceptable quality and higher speed.
I can do some visual comparisons sometime soon if needed.
Martin Nordholts
2009-06-29 07:37:25 UTC (over 16 years ago)
New color mode
This sounds like
Bug 325564 – Layer mode "Color" doesn't work well http://bugzilla.gnome.org/show_bug.cgi?id=325564
/ Martin
Emil Assarsson
2009-06-29 10:31:27 UTC (over 16 years ago)
New color mode
I'm sorry that I didn't find the right terms...
I meant the modes that are used to mix colors with layers and brush like Normal, Dissolve, Multiply, Divide etc...
For instance: Place a high green and a high red area on a canvas. Then mix them together with a brush set to like 45% Opacity. The mid blend will be very dull. I want to create an alternative where the blend is more a combination of color, value and normal where the blend keeps some more of it's vividness.
I think I have to experiment with this a lot to find the correct algorithms for it... sometimes I want it to prefer a warm path and sometimes a cold. I think this mode could mimic the real life oil- and watercolors a little bit better if I get it right.
Emil Assarsson
2009-06-29 15:42:33 UTC (over 16 years ago)
New color mode
I meant desaturated sorry :-P
I find the normal too desaturated and would like to make a new more vivid.
Martin Nordholts
2009-06-29 21:31:32 UTC (over 16 years ago)
New color mode
Currently, the Color layer mode when using GEGL is supposed to use the Hue and Saturation of the upper layer and the Lightness from the lower layer. Maybe the RGB -> HSL conversion is buggy? We want Color to behave correctly in GIMP 2.8 when using GEGL for the projection, see http://bugzilla.gnome.org/show_bug.cgi?id=325564 . It is great that you want to look at this, and all you have to do is experiment with different algorithms in
gimp_operation_point_layer_mode_get_new_color_hsl() in app/gegl/gimpoperationpointlayermode.c.
Good luck!
Emil Assarsson
2009-07-01 20:21:13 UTC (over 16 years ago)
New color mode
I don't see it as a bug... it's more of a problem. Gimp uses HSL(?) and PhotoShop /seems/ to use CIELAB for these operations. This effects all layer modes that uses that color space for conversions and doesn't work in the same way as PS... Hue, Saturation, Color and Value.
HSL treats pure yellow by giving it the same lightness as pure purple. CIELAB treats them more from a human perspective and sets the pure yellow to be light (lightness) and pure purple as dark.
Helpful tool to visualize it: http://www.cs.rit.edu/~ncs/color/a_spaces.html
I think we need to add conversion tools for the color space and rewrite those routines (or add new ones) if it should be a goal to correctly import PS files with layer modes. (This could actually be a good way to learn some more about the gimp code for me)
Any comments on this?
Martin Nordholts
2009-07-01 20:24:21 UTC (over 16 years ago)
New color mode
If using a CIE Lab based color space for defining and implementing the color layer modes gives better looking and more intuitive results, than that is the color space we shall use.
A patch that uses CIE Lab (or CIE LCH?) for this when using GEGL would be much appreciated.
/ Martin
