GAP Encoding
GAP Encoding Jason van Gumster 28 Jun 09:32
  GAP Encoding saulgoode@flashingtwelve.brickfilms.com 28 Jun 12:54
Jason van Gumster
2009-06-28 09:32:43 UTC (over 16 years ago)
GAP Encoding
I've been working my way through explaining GAP's video encoding feature and stumbled across something that I couldn't find any obvious documentation to (or figure out on my via trial and error). Basically, I'd like to know the difference between the SINGLEFRAMES and RAWFRAMES encoder options. The names seem to indicate that RAWFRAMES doesn't compress frame data, but if you set your output format to JPEG, the compression window appears and the encoder happily compresses each frame just as if you'd chosen SINGLEFRAMES.
If anyone could shed some light on this topic, I'd be very grateful.
Take care.
-Fweeb
2009-06-28 12:54:50 UTC (over 16 years ago)
GAP Encoding
Quoting Jason van Gumster :
I'm not certain about this, but I believe that RAWFRAMES is only meaningful for the "Storyboard" Input Mode, and then only if the source video file includes valid JPEG frames in its format (i.e., MPEG1 I-frames, or MJPEG). For these formats, rather than decode the (JPEG) frame into an image and then encode that image back to a JPEG file, the video encoder will simply extract the JPEG frame from the video stream. This is beneficial from both a speed and quality perspective.
If you are not in "Storyboard" Input Mode, encoding is mandated regardless of whether you use RAWFRAMES or SINGLEFRAMES.
