Exact Area Box Filtering
Exact Area Box Filtering Adam Turcotte 24 Jun 03:29
  Exact Area Box Filtering Nicolas Robidoux 24 Jun 04:35
Adam Turcotte
2009-06-24 03:29:55 UTC (over 16 years ago)
I have been investigating the possibility of implementing exact area box filtering in GEGL. Specifically, I would like to build a sampler that behaves like exact area box filtering when downsampling but also behaves reasonably when performing other transformations.
The basic idea is to average the piecewise constant "nearest neighbour" surface on the smallest rectangle (width and height at least 1) that contains the pull-back (inverse image, anti-image) of an "output" pixel area by the inverse Jacobian (approximated if needed).
The main issues are:
1) Averaging over a region too large for the usual 64x128 tile.
If we downsample by a significant amount, the region to average over may be larger than the size of a tile. This could be solved by either calling gegl_sampler_get_ptr () repeatedly with a large, constant footprint, or by devising a system to change the footprint on a pixel-by-pixel basis. The latter solution just involves modifying context_rect on the fly, which should be feasible.
2) Passing the four numbers which define (an approximation of) the inverse Jacobian to the sampler from the operation which calls it.
I see that there are create_matrix () methods that seem to construct a Jacobian for various affine transformations. The proposed method would require the inverse Jacobian instead, which may require some changes to the API. Since more complex warping may also make use of this feature in the future, would it be acceptable to add methods to support this?
3) Is there already code which does this?
I have noticed that resample_boxfilter_u8 seems to do something related. How similar is this code and Is there too much overlap for this project to be worthwhile?
I would appreciate any feedback or help that anyone can provide.
Adam Turcotte
Nicolas Robidoux
2009-06-24 04:35:05 UTC (over 16 years ago)
An alternative is to pull back an output pixel area with a modified inverse Jacobian set so that that its singular values are all at least 1, and then find the smallest rectangle which contains the pull-back. This is somewhat related to what Craig DeForest has done in PDL::transform (sp?). (You may also modify the Jacobian so that its singular values are at most 1: no difference really in the final result.)
I have an honour thesis student (Chantal Racette) trying to figure out which approach is best. It is not really important to figure out now which one is best because once the code is written for one approach, it would be fairly easy to set it up for the other. (2x2 SVD's are not really a big deal.)
Because the smallest rectangle is exactly the pull back when doing straight downsampling, the method boils down to exact area box filtering when downsizing images (e.g., thumbnail production). For transformations which don't map axes to axes (most rotations, shear, warp), the rectangle ends up being larger, which is a good thing because aliasing is generally more pronounced.
Nicolas Robidoux Laurentian University
