Can the gimp-help-2 module be maintained using Damned-Lies?
Can the gimp-help-2 module be maintained using Damned-Lies? Aron Xu 23 Jun 13:30
  Can the gimp-help-2 module be maintained using Damned-Lies? Roman Joost 25 Jun 12:34
Can the gimp-help-2 module be maintained using Damned-Lies? Claude Paroz 25 Jun 23:21
  Can the gimp-help-2 module be maintained using Damned-Lies? Ulf-D. Ehlert 28 Jun 14:45
   Can the gimp-help-2 module be maintained using Damned-Lies? Claude Paroz 03 Jul 23:28
    Can the gimp-help-2 module be maintained using Damned-Lies? Ulf-D. Ehlert 07 Jul 11:56
Aron Xu
2009-06-23 13:30:20 UTC (almost 16 years ago)
I want to ask if we can use damned-lies on http://l10n.gnome.org/ to help maintain the translations of gimp-help-2? It can provide a better UI for the gnome translation teams to maintain it as a common module. I've asked the author of damned-lies, he said if we want to use it, he could adapt it to fit our needs.
Regards, Aron
Roman Joost
2009-06-25 12:34:40 UTC (almost 16 years ago)
Good question. I haven't investigated this further, but it would be very nice if we could hook up with that.
That are currently my 2cents. If someone volunteers for that to investigate what we need to change, it'll be more than welcome.
Cheers,
Claude Paroz
2009-06-25 23:21:10 UTC (almost 16 years ago)
Even if i cannot pretend to be the author of damned-lies, I'm the current maintainer. Thanks Aron for initiating contacts.
I checked the build system of gimp-help-2, wow... :-) Nice work.
I tried to see if it is possible to include the stats on l10n.gnome.org with minimal changes in both sides. With some minor adaptations, I could make it work as is. One of the current shortcomings is that we are using your Makefile only to generate pot files, but not to merge pot with po, hence not supporting the Compendium functionality.
Now I think the technical side is only one part of the question. The other part is the translators community stuff. I don't know Gimp help translation communities, and if they are close to the GNOME translation community. As soon as the stats would be published on l10n.gnome.org, you will probably see translations coming either directly as commits, or at least through the workflow part of our site. Is this desired? Does someone see any problem with the merge of existing communities?
Cheers,
Claude Paroz
Ulf-D. Ehlert
2009-06-28 14:45:41 UTC (almost 16 years ago)
Hi Claude,
Claude Paroz (Donnerstag, 25. Juni 2009, 23:21):
Which changes are required on our side? (And which changes on your side?)
We do not use one or two po files, but a set of 40+ files in several directories (and probably a non-standard naming scheme) - is this a problem?
Would it be possible to use some of our tools for building pot or po files (e.g. a patched version of xml2po)?
(Using a compendium is a nice feature, but it's not important or necessary.)
The GIMP help translation community? Oh god, the number of translators is extremely small - one or two poor volunteers per language spending a little bit of their time...
I don't see a problem - any help would be appreciated! :-)
Thanks for your offer! Ulf
Claude Paroz
2009-07-03 23:28:00 UTC (almost 16 years ago)
Le dimanche 28 juin 2009 à 14:45 +0200, Ulf-D. Ehlert a écrit :
Hi Claude,
I tried the most to not require any change on your side. We'll see if it's satisfactory. One little change may be a nice-to-have (DOC_LINGUAS), see below.
Not necessarily. We already have support for multiple po files per module, it's just that you put it to the limit :-)
Yes, we're currently using your Makefile.GNU to generate the pot file. And then we merge ourself to generate updated po files. One rule we have is to never have to run autogen.sh for generating potfiles, that's why we prefer using Makefile.GNU rather than Makefile.am. Paradoxically, gnome-doc-utils standard is to put a DOC_LINGUAS variable in a Makefile.am file, to specify languages to consider for building docs. Would it be possible for you to have such a DOC_LINGUAS variable with the list of current languages? (no *sh expansion please). However, this is not critical, if you don't change anything, you'll just have to live with a warning for each template.
Is your patch to xml2po worth going upstream? If yes, did you already report it in gnome-doc-utils bugzilla?
OK, I set up an experimental module for this on our site with 4 po files.
http://l10n.gnome.org/module/gimp-help-2/
If it suits you, I'll add the 36 remaining po references to the same page.
The next step would be to make the images stuff work with your particular directory setup. See for example: http://l10n.gnome.org/module/eog/help/master/de/images/
I guess this would require some more ad-hoc handling on our side.
Claude
Ulf-D. Ehlert
2009-07-07 11:56:41 UTC (almost 16 years ago)
Claude Paroz (Freitag, 3. Juli 2009, 23:28):
What's the maximal number of po files?
The build system is still "work in progress", so there is no problem adding or renaming variables (and more).
Is DOC_LINGUAS = $(YET_ANOTHER_VARIABLE) ok?
("*sh expansion" = backticks or $(shell ...)?)
We filed a bug report (a long time ago) and provided a patch, but didn't get any feedback.
The patched version reduces the number of placeholder tags generated by the xml2po script (and thus is not backward compatible), so I don't know if the author/maintainer will like it...
We are free to change our directory structure, so just ask if there are some problems you can't solve on your side.
Ulf
