select pencil/paintbrush and undo/redo from a script
select pencil/paintbrush and undo/redo from a script Ioan Calin Borcoman 07 Jun 11:22
  select pencil/paintbrush and undo/redo from a script Sven Neumann 07 Jun 11:28
Ioan Calin Borcoman
2009-06-07 11:22:30 UTC (almost 16 years ago)
My gimpsketchbook app is offering an alternative (extended) interface for gimp via a plugin that acts as a proxy between the gimpsketchbook and gimp.
I would like to be able to add buttons for selecting the current active tool (for example, select the pencil or the paintbrush) or to execute undo/redo. Unfortunately, there are no functions in pdb for any of these. Any idea how I can implement these?
Thanx,
Ionutz
2009-06-07 11:28:35 UTC (almost 16 years ago)
It is not the purpose of the PDB to allow scripting of the GIMP UI.
There is no interface exported by GIMP that would allow to do what you are asking for. Except for the accessibility interface that GTK+ exports. It may be possible to do what you are asking for using this framework. Have a look at at-spi, dogtail and ldtp.
