Please help with a syntax error.
Please help with a syntax error. habeoanimusnon 04 Jun 01:46
  Please help with a syntax error. Robert Krawitz 04 Jun 01:52
   Please help with a syntax error. habeoanimusnon 04 Jun 01:57
2009-06-04 01:46:20 UTC (almost 16 years ago)
When i try to run this script in the console, it says "Error: Bad syntax of binding spec in let* : (var-one 1)"
I already wrote a much bigger script using information from an old tutorial but without trying out this simple part of it first and now that doesn't work, except when you replace the variables with values.
Using gimp 2.6.6 and Ubuntu 9.04
(let* (var-one 1)
(var-two 2)
(var-three 3)
If it is just written wrong please tell me how it should be written.
Thanks in advance
Robert Krawitz
2009-06-04 01:52:06 UTC (almost 16 years ago)
Date: Thu, 4 Jun 2009 01:46:20 +0200 (CEST)
(let* (var-one 1)
(var-two 2)
(var-three 3)
The syntax of let* is
(let* bindings &body body)
The bindings are a single argument, so they have to be a list:
(let* ((var-one 1) (var-two 2))
...body...)
2009-06-04 01:57:18 UTC (almost 16 years ago)
(let* (var-one 1)
(var-two 2)
(var-three 3)
...body...)
Thank you so much!
