[PATCH] fix to batch console support
[PATCH] fix to batch console support Christopher Montgomery 28 May 20:37
  [PATCH] fix to batch console support Martin Nordholts 28 May 21:07
   [PATCH] fix to batch console support Sven Neumann 28 May 21:19
    [PATCH] fix to batch console support Martin Nordholts 28 May 21:32
  [PATCH] fix to batch console support Esteban Barahona 29 May 04:42
2009-05-28 20:37:27 UTC (almost 16 years ago)
The batch mode console is using stdio but never flushing its output after fwrite()s. This still usually works by accident when using batch mode from a terminal, but it means scripts generally won't work as responses to requests never get flushed through the return pipe.
Apologies for this not being in git format-patch format, it was a spot test to get other unit tests working and trivial enough it doesn't seem worth the extra trouble.
Cheers,
Monty
diff --git a/plug-ins/script-fu/scheme-wrapper.c b/plug-ins/script-fu/scheme-wrapper.c index 9212801..fbcf81b 100644
--- a/plug-ins/script-fu/scheme-wrapper.c +++ b/plug-ins/script-fu/scheme-wrapper.c @@ -329,6 +329,7 @@ ts_stdout_output_func (TsOutputType type, if (len < 0)
len = strlen (string);
fprintf (stdout, "%.*s", len, string); + fflush (stdout);
void
Martin Nordholts
2009-05-28 21:07:51 UTC (almost 16 years ago)
Seems like a reasonable patch to me, I pushed to GNOME master:
commit 7b7d44837834061e8ee2c668b0f9d99d9ae13dcf Author: Christopher Montgomery
Date: Thu May 28 21:06:53 2009 +0200
plug-ins: Make sure to flush output in ts_stdout_output_func()
/ Martin
2009-05-28 21:19:40 UTC (almost 16 years ago)
Please merge this to the gimp-2-6 branch also.
Martin Nordholts
2009-05-28 21:32:43 UTC (almost 16 years ago)
There we go:
commit 3c59c936e075a36d1648cbf38ae12c2577432f74 Author: Christopher Montgomery
/ Martin
Esteban Barahona
2009-05-29 04:42:07 UTC (almost 16 years ago)
script fu?
.../5/28 Christopher Montgomery
Cheers,
Monty
void
