command output from script-fu-server
command output from script-fu-server Ioan Calin Borcoman 21 May 07:31
command output from script-fu-server Niels Giesen 24 May 20:41
  command output from script-fu-server Ioan Calin Borcoman 25 May 09:15
   command output from script-fu-server Ioan Calin Borcoman 25 May 10:02
Ioan Calin Borcoman
2009-05-21 07:31:32 UTC (almost 16 years ago)
I have attached a small patch for script-fu-server that makes the server return to the clients the output of the commands executed, just like the script-fu-console does.
Is the patch ok? Any chance to apply it the mainline? Should I make a bug-report and attach the patch to it?
Thanx,
Ionutz
Niels Giesen
2009-05-24 20:41:17 UTC (almost 16 years ago)
Thanx,
Ionutz
This is great stuff. If we had had this a year ago, it would have saved me a *lot* of ugly hacking about developing the client side gimp-mode for Emacs. (If you wanna know, this was done by wrapping the code to be sent
inside scheme code that wrote back to a file, with stuff such as tracing and the various write and display functions not working). The other implementation I did to interact with GIMP was with GIMP as a subprocess as
a batch program; this is quite crude and does not work under that other OS I have to use at work.
Attached is a small python program (my first) I wrote this morning that gives a simple REPL interface to the script-fu server based on your patch, you might want to use that for testing if your patch works. So far it is going strong.
I very much like to see this one implemented, and am working on rewriting parts of gimp-mode for Emacs to use this facility. Even though the script-fu server apparently was not intended for actual use, its usefulness at least for developing script-fu inside an editor of choice
is greatly enhanced with these additions.
It is looking promising.
Regards, Niels.
Ioan Calin Borcoman
2009-05-25 09:15:26 UTC (almost 16 years ago)
Let's hope it gets applied. I'll make a bug report and attach the patch to it.
My code uses something like this to send the data:
def send(self, msg): l = len(msg)
raw = 'G' + struct.pack('H%ds' % l, socket.htons(l), msg) self.socket.send(raw)
To receive the data, I use something like: ...
raw = self.socket.recv(4)
l = socket.ntohs(struct.unpack('H', raw[2:4])[0]) raw = self.socket.recv(int(l))
Worked ok until now. Very similar with your code :)
Cheers,
Ionutz
Thanx,
Ionutz
Regards, Niels.
http://niels.kicks-ass.org
Ioan Calin Borcoman
2009-05-25 10:02:22 UTC (almost 16 years ago)
I've filed the bug as 583778 (http://bugzilla.gnome.org/show_bug.cgi?id=583778).
Cheers.
Ionutz
Cheers,
Ionutz
Thanx,
Ionutz
Regards, Niels.
