Introduction to GEGL Buffers
| Introduction to GEGL Buffers | Jerson Michael Perpetua | 11 May 22:48 |
| Introduction to GEGL Buffers | Jerson Michael Perpetua | 11 May 22:50 |
| Introduction to GEGL Buffers | Øyvind Kolås | 12 May 12:57 |
| Introduction to GEGL Buffers | utkarsh shukla | 12 May 14:02 |
| Introduction to GEGL Buffers | Nicolas Robidoux | 12 May 16:50 |
| Introduction to GEGL Buffers | Øyvind Kolås | 12 May 18:42 |
| Introduction to GEGL Buffers | Nicolas Robidoux | 12 May 21:46 |
| Introduction to GEGL Buffers | jcupitt@gmail.com | 13 May 03:06 |
| Introduction to GEGL Buffers | Øyvind Kolås | 13 May 11:36 |
| Introduction to GEGL Buffers | Nicolas Robidoux | 13 May 17:43 |
| Introduction to GEGL Buffers | utkarsh shukla | 13 May 18:30 |
| Introduction to GEGL Buffers | Nicolas Robidoux | 13 May 18:35 |
| Introduction to GEGL Buffers | Øyvind Kolås | 13 May 18:40 |
| Introduction to GEGL Buffers | Nicolas Robidoux | 13 May 19:05 |
| Introduction to GEGL Buffers | utkarsh shukla | 13 May 19:08 |
| Introduction to GEGL Buffers | Øyvind Kolås | 13 May 19:24 |
| Introduction to GEGL Buffers | Jerson Michael Perpetua | 14 May 01:22 |
| Introduction to GEGL Buffers | utkarsh shukla | 14 May 02:19 |
| Introduction to GEGL Buffers | Jerson Michael Perpetua | 14 May 06:10 |
| Introduction to GEGL Buffers | utkarsh shukla | 14 May 23:40 |
| Introduction to GEGL Buffers | Nicolas Robidoux | 14 May 04:03 |
| Introduction to GEGL Buffers | Jerson Michael Perpetua | 14 May 06:41 |
| Introduction to GEGL Buffers | Nicolas Robidoux | 14 May 06:58 |
| Introduction to GEGL Buffers | Jerson Michael Perpetua | 14 May 07:12 |
| 806dafc20905121307q3f323396... | 07 Oct 20:29 | |
| Introduction to GEGL Buffers | Nicolas Robidoux | 12 May 22:43 |
| Introduction to GEGL Buffers | utkarsh shukla | 12 May 22:55 |
| Introduction to GEGL Buffers | Øyvind Kolås | 13 May 00:40 |
| 806dafc20905121359i19d18881... | 07 Oct 20:29 | |
| Introduction to GEGL Buffers | Nicolas Robidoux | 13 May 02:31 |
| Introduction to GEGL Buffers | Nicolas Robidoux | 13 May 02:43 |
Hey,
I'm back and I've changed. I don't want to be verbose anymore. So, without further ado... Wait, let me just say this: GeglBuffers are awesome! Now that that's out of the way, let me tell you exactly why GeglBuffers rock. :)
GEGL TILES, WHAT THEY ARE AND HOW THEY ARE STORED
Internally, GeglBuffer data is subdivided into GeglTiles that are always of the same size (within that same buffer). The default tile size is 128x64. Tiles store image data within portions of the buffer. Image data within a tile is always linear, though tiles are allowed to be in different memory locations. Tiles do not overlap, meaning that no two tiles share the same pixels.
GeglTiles are identified through their x, y and z coordinates. The x and y coordinates are the tile's horizontal and vertical positions in the buffer, respectively. The last coordinate, z, is the tile's mipmap level. Mipmaps are scaled versions of tiles. Currently, there are three mipmap levels; z=0 which is the original tile, z=1 & z=2 which are 50% and 25% of the original tile size, respectively.
For those with poor imagination (like me), I have prepared an (awesome) ASCII table ('coz ASCII iz 1337) for your viewing entertainment:
| | (x0,y0) | (x1,y0) | (x2,y0) | 64
192 | (x0,y1) | (x1,y1) | (x2,y1) | 64
| | (x0,y2) | (x1,y2) | (x2,y2) | 64
v +---------+---------+---------+ -+-
|-- 128 --|-- 128 --|-- 128 --|
In the example above, we have a 384x192 buffer. Internally, the image is subdivided into nine tiles, 128x64 each. The pixels belonging to the top left-most rectangle is stored in tile (x0,y0), the top-most middle rectangle in tile (x1,y0), the top right-most rectangle in tile (x2,y0), the middle left-most rectangle in tile (x0,y1) and so on. Note that the tiles aren't necessarily stored in contiguous (linear) memory. In fact, some tiles may not even be in main memory at all[1]!
A buffer whose width is not a multiple of its tile width will pad its right-most tiles. Similarly, a buffer whose height is not a multiple of its tile height will pad its bottom-most tiles. A buffer whose width & height are both not multiples of its tile width & height will introduce padding to its right-most and bottom-most tiles (including, of course, the bottom right-most tile) as illustrated by another (equally awesome) ASCII table below:
| | | |00000|
| | | |00000|
| | | |00000|
| | | |00000|
| | | |00000|
| | | |00000|
| | | |00000|
+--------+--------+--+00000|
|00000000|00000000|00000000|
Tile portions marked with 0s are in the abyss (outside the image) and are padded[2].
GEGL BUFFER AWESOMENESS
The GeglBuffer class is part of a large family of classes called TileSources. A TileSource is an object that provides tile commands. The following commands are exposed by all TileSources:
GEGL_TILE_IDLE - used internally to run tile idle work GEGL_TILE_SET - set the tile at a particular xyz location GEGL_TILE_GET - get the tile at a particular xyz location GEGL_TILE_IS_CACHED - query if a tile is cached GEGL_TILE_EXIST - query if a tile exists GEGL_TILE_VOID - causes all the references to a tile to be removed GEGL_TILE_FLUSH - flush all cached tiles to the backing store GEGL_TILE_REFETCH - used internally to refresh all data relating to the coordinates
Note that not all TileSources implement all of the commands. Each TileSource subclass implements a subset of the commands. Each of this TileSources work hand-in-hand to provide all the needed commands by the GeglBuffer. More about this below.
Two classes directly inherit from the TileSource; the TileHandler and the TileBackend classes. The latter implements full storage for the tiles. As its name implies, the TileBackend is where data is ultimately read from or written to (at least in the whole duration of the program). As such, a TileBackend implements the tile get and set commands (among others, but I'm not sure). Currently, there are three TileBackend implementations; a RAM, a file and a tiledir backend.
TileHandlers, on the other hand, has this idea of a source. When a specific TileHandler doesn't implement a command, the TileHandler calls the same command from its source. It can also call the source's command when it needs data to process. To elaborate, let's look at the multitude of TileHandler implementations. Currently, there are five direct TileHandler subclasses; TileHandlerCache, TileHandlerZoom, TileHandlerEmpty, TileHandlerChain and the GeglBuffer (the only one in the family with super-cow powers :).
The TileHandlerCache implements (almost?) all commands. This TileHandlerCache caches tiles as they are retrieved from its source. Cached tiles are also written-back to the source through the TileHandlerCache's idle command.
The TileHandlerZoom implements the get tile command to create a mipmap when the mipmapped tile from its source is NULL. This TileHandlerZoom kicks into play only when z > 0.
The TileHandlerEmpty implements the get tile command to create a new tile when the tile from its source is NULL. It does this by creating a tile that shares its data with the TileHandlerEmpty's pre-created empty tile[3].
The TileHandlerChain doesn't implement any of the commands. It, however, delegates all of its commands to its source. What the TileHandlerChain really does is accept a list of TileHandlers and chain them. The TileHandlerChain sets these TileHandlers so that the first in the list becomes the TileHandlerChain's source and the next (i + 1)th TileHandler becomes ith's source (where i > 0 & i is zero-based). This lets a command pass through the chain looking for a TileHandler that will handle it.
There is a special kind of TileHandlerChain called a TileStorage. A TileStorage is a TileHandlerChain that creates it's own set of TileHandlers to chain. Furthermore, the TileStorage attaches a TileBackend to the last element of the chain. Currently, the TileStorage chains TileHandlers like so:
TileStorage
v
TileHandlerEmpty
v
TileHandlerZoom
v
TileHandlerCache
v
(TileBackend)
In the diagram above, the arrow direction points from the TileHandler to its source. This means that a command to the TileStorage will pass through the chain (storage->empty->zoom->cache->backend) until either it is handled or it reaches the backend. For get tile, for example, the command will just go through all the TileHandlers until the TileHandlerCache. By which point, it will either return the tile from the cache or chain the command to the TileBackend depending on whether the tile is cached or not, respectively.
Consider the example in which the buffer is newly created so that there is no pixel data in the backend itself. A get tile command will go through the chain until it gets to the backend (the cache doesn't have data, of course, so it's also skipped). The moment the command returns unsuccessfully, the TileHandlerEmpty will catch the request and create a new shared empty tile to be returned. The same also occurs for the TileHandlerZoom. Only that it returns mipmaps instead of empty tiles.
The last TileHandler is the GeglBuffer. A GeglBuffer is a TileHandler that sets a TileStorage as it's source. GeglBuffers provide facilities to query and set rectangle pixel values. You can create a GeglBuffer that uses another GeglBuffer as its source (remember that GeglBuffers are still TileSources). It let's you convert from one color to another through Babl. It's lets you store data in a linear memory, RAM or swap. It can feed your dog, clean the house and kiss your girlfriend for you. As I've said, GeglBuffers have super-cow powers! But only because of the powerful architecture it sits on top of.
Ain't GeglBuffers awesome?
I know that I promised a new architecture. But, really, that new one is still up in the air as I'm still sorting out the details. Hope this article will be of help to anyone.
Kind regards, Daerd
P.S. Apologies if the humor is cheesy. Half of being a programmer is having a rotten sense of humor. It's from the same faculty as playfulness, I think. :)
[1] Now you know what a tiled sparse buffer is. (Well, half of the definition, actually. GEGL would also delay allocation of image data until a tile is actually used to store pixels. That is, a newly created tile would not occupy memory until they are written to. Thus, the other half of the 'sparse' definition.)
[2] With zeros, I think.
[3] A shared tile is a tile whose data is shared by other tile instances. Sharing tile data is a smart way of creating copy-on-write tiles that doesn't occupy significant memory during creation. Prior to the writing of pixel data, a shared copy-on-write tile is unshared and proper memory is allocated for the tile.
The ASCII diagrams above look better when viewed on the mailing list.
This is a good introduction to the architecture of GeglBuffers and shows a good understanding of what they currently are capable of. It could probably be integrated in the current documentation [1]
What follows is a blue-sky wishlist of features that should be possible to add to the architecture making it and GEGL a powerful base.
- Add GPU based means of setting and retrieving pixel data with a
unified CPU/GPU storage (an important initial part of making GEGL GPU
accelerated.)
- mmap the tile data in the backend instead of reading/writing (port away
from GIO).
- re-enable shared access across processes using mmap (this can currently
be made to work with patches to GIO).
- Make the background/empty color configurable (by making the empty
tile's contents configurable).
- Add abyss policies to be used by resamplers, allowing configuring the
behavior of affine transforms and warping image operations.
- Detect when a tile is set to be a solid block of the background color,
and make the tiled shared with the empty tile.
- Implement backends directly fetching tile data with random access from
image file formats. (tiled EXR and TIFF), some formats with scanlines
or groups of scanlines as tiles.
- Implement backends relaying tiles from OpenStreetMap or other http
based tiled mipmap servers.
- Add a webserver that serves tiles, perhaps from a different processes
reading the tiles shared by a different process. Allowing web hosted
javascript front ends.
- Use webserver / web backend to implement multi-host read/writeable
image buffers for collaborative painting and networked processing.
- Detect uniformly colored and perhaps other types of tiles and store
them more compactly, perhaps even just compressing tile contents and
share duplicate tiles detected through hashing of their compressed data.
/Øyvind K.
unified CPU/GPU storage (an important initial part of making GEGL GPU accelerated.)
- mmap the tile data in the backend instead of reading/writing (port away from GIO).
- re-enable shared access across processes using mmap (this can currently be made to work with patches to GIO).
That is only what I meant with the minimaps.
Utkarsh Shukla,
Btech, Material Science and Metallurgy,
IIT KANPUR.
Mob: 9936339580
I expect the following items from Øyvind's list to be tackled by Adam Turcotte and Eric Daoust (both GSoC students which I mentor). Consequently, if someone is planning to tackle these issues in the foreseable future, please let everyone know.
Øyvind Kolås writes:
I'm not making promises on the following (given that they are not part of the original GSoC) but they are related to Adam and Eric GSoCs, but it would make sense to have them have a look at the following (I may give more programming help with the resampler parts to free them for what's below):
> - Detect when a tile is set to be a solid block of the background color, > and make the tiled shared with the empty tile. > - Detect uniformly colored and perhaps other types of tiles and store > them more compactly, perhaps even just compressing tile contents and > share duplicate tiles detected through hashing of their compressed data.
Nicolas Robidoux Universite Laurentienne
I forgot to add one more item to my list of potential/desired enhancements of GeglBuffer and that is to make the extent (width and heights) of the buffer be updated on demand when tiles are changed, allowing automatically growing buffers that are "auto-clipped" to the bounding box of content that differs from the configured background color.
/Øyvind K.
> color.
Do I gather correctly that this is related to the possible solution you gave for
http://bugzilla.gnome.org/show_bug.cgi?id=549999
namely,
The bug is manifest because the different interpolation methods have different sampling footprints. The resulting image size is computed based on the size of the kernel, this is similar in behaviour to the gaussian blur which increases the size of the input image as well by smearing it out. The upper left corner of the bounding box is stored to be in negative coordinats so sampling from 0,0 would yield the upper left sample anyways. One way to work around this would be to crop the image to the original bounding box.
Not completely sure if this is a bug or not, I guess it depends on what types of behavior we want to support for the edges of transformed buffers.
Please let me know if I am completely off track, but there are some issues which I want to understand if possible (even though you may have explained it to me already) in order to guide Eric and Adam:
Question 1:
If my memory is good, samplers in GIMP use the "center" image size convention, which means that the centers of the boundary pixels "creep in" when downsampling, but "creep out" when upsampling, because what is kept fixed is the position of the corners of the areas implied by the boundary pixels, which are half a pixel width out from their centers.
The most common alternative is the "corner" convention, which anchors the positions of the centers of the boundary pixels.
I am omitting discussion the pros and cons for each. (Generally, "center" is better for downsampling, and "corner" is better for upsampling, so no single convention works best for all situations.) However, it is my opinion that "corner" convention is generally better.
Do you have a preferred "implied" convention for GEGL? Should it comply with what is generally the "implied" convention in GIMP?
This matters, because if the abyss policy is "no blending: image goes to the boundary ignoring the abyss, and the abyss is constant whatever (0, say, but one of your requested features is that this be configurable), we need to know where the boundary is.
Question 2:
Do you want resampled image sizes to be enlarged by the size of the footprint (more specifically, by the size of smallest rectangle which contains the footprint, since, for example, the footprint of nohalo is not a rectangle), or do you want the resampled image size to be cropped, in accordance with the image size convention (in the corner convention, the image ends right at the center of the boundary pixels, in the center convention, it ends one half pixel past it).
Prior to our conversations last week, I was sure that cropping should be done. however, now that I have been exposed to the "wonderfulness" of GEGL buffers, I have the impression that the buffer should be extended by this footprint so that the "blending" implicit in most abyss policies be applied not only inside the extent of the original image, but also outside. A consequence is that the bounding box will depend on the abyss policy, which is the case now. In other words, this would be a feature, not a bug.
Question 3:
Because the footprint of the samplers is often asymetrical (for example, for bicubic, the "anchor" is the second pixel from the left, out of the four positions which make up the footprint in the horizontal direction; this breaks left/right symmetry) the number of pixels by which the image is extended at the top and left is often not the same as the number by which it is extended at the bottom and right. Of course, symmetry is resolved in that "extra" ones are set to the background abyss colour (0).
Again, I previously saw this as a bug, which in principle could be avoided using some logic or cropping. However, at this point, I am enclined to treat it as a quirky feature which is a side effect of a sound design decision.
Is this agreed?
I hope that I am not making my confusion too manifest here.
Cheers,
Christopher Montgomery writes:
> I suspect you are conflating center/corner with 'are we point sampling
> or area sampling the pixel?'.
I am not.
Although area sampling generally works better with the center convention, and point sampling works better with the corner convention, one can use either with either convention. In my mind, these are related, but separate, issues. I have programmed and used area sampling methods with either convention, for example.
More about this later.
(Thanks for joining the discussion.)
Nicolas Robidoux Laurentian University
hi,
Actually I am not a GSOC student but I was very much interested in writing
some code or some patch for gimp. Please guide me in case you feel I can be
of bit help.
On Wed, May 13, 2009 at 2:13 AM, Nicolas Robidoux < nrobidoux@cs.laurentian.ca> wrote:
> I suspect you are conflating center/corner with 'are we point sampling > or area sampling the pixel?'.
> ...I am not.
_______________________________________________ Gegl-developer mailing list
Gegl-developer@lists.XCF.Berkeley.EDU https://lists.XCF.Berkeley.EDU/mailman/listinfo/gegl-developer
On Tue, May 12, 2009 at 9:55 PM, utkarsh shukla wrote:
hi,
Actually I am not a GSOC student but I was very much interested in writing some code or some patch for gimp. Please guide me in case you feel I can be of bit help.
I am not a mentor in the summer of code but I am interested in GEGL becoming a powerful framework for both using and developing image processing algorithms. I welcome you to discuss and help implement and improve any part of GEGL. You've got knowledge of relevant technologies like OpenGL, GLSL as well as development in general and can be valuable in guidance on prototype code and ideas as that project gets off the ground.
/Øyvind K.
Let me try to be a bit more specific, one issue at a time.
I agree that, at least at low order (which is all we're doing for now), abyss policies are independent of whether we are using the "center" or "corner" image conventions, and are also independent of whether we are implementing an exact area method (like most implementations of box filtering), or a point resampler (like standard bicubic).
However, Øyvind expressed a desire to have something implemented in or for the resamplers which cannot really be done with the usual abyss policy implementations.
Here is:
Associate a "default" constant colour with a buffer. What Øyvind would like (if I understand correctly) is that instead of sampling through the implied boundary using the resampler as if there was no boundary (filling in the missing footprint values using the abyss policy), the resampled values "drop dead" at the boundary and from then on are filled (filled, not blended) with the default colour. For example, the sampler could use the nearest neighbour abyss policy (a.k.a. clamp) for requested values up to the boundary line, and return the default colour past it.
Comment: Thinking about this some more, I am starting to think that it is a bad idea to implement this. (Later.)
Irregardless of whether this is a good or bad idea, the main point is:
Where should the "drop dead" transition occur:
Aligned with the (center of) the boundary pixels? Or half a pixel width out (at the boundary of the pixel area associated with boundary pixels)?
One of my worries is that if one when doing something else than resizing this will essentially behave like nearest neighbour (from the outside in), which will be ugly. So, >>I<< am actually starting to think that "drop dead" is not such a good idea.
But I'd love to hear opinions on this.
nicolas
> Ah, you mean that the implementation is easier, not that the output
> results differ?
Christopher:
Can we start from scratch? I'm afraid that we may take a long time explaining to each other exactly what we mean, with the most likely end result that we agree with each other on the essential (code-wise consequences). I started the ball rolling being vague, let me see if I can stop it.
It's not that I don't welcome your input (I actually sought it, and it is important to me that we align the GEGL resampler team with their GIMP counterparts), it is just that I am too tired/busy to get into a "I actually mean this, which really is the same although it is different from what you mean, is that right? Oh! you were talking about this limited situation but I was talking about the more general one and things are not the same but you can emulate the other if you are willing to blah blah blah" debate.
It's more important to me to be useful than to be right.
nicolas
2009/5/12 Øyvind Kolås :
- Add abyss policies to be used by resamplers, allowing configuring the behavior of affine transforms and warping image operations.
An efficient way to do this is to remove the rule that buffers need to have fixed-size, non-overlapping tiles.
If you remove this restriction, then an image, rather than having to have it's own set of tiles, can instead just have a pointer to the tiles on another image. This lets you efficiently implement operations that keep most pixels unchanged but which make some small change to an edge (for example).
You can then implement abyss policies by writing an operation that enlarges an image in a certain way: for example by extending the edges out by 10 pixels and filling with a solid color. For most of the image, the operation can just use a tile from the original image at effectively no cost. It's only tiles which include part of an edge that need a copy and paint.
The resampler is then given the enlarged image to work on, and need only generate pixels where the interpolation stencil is completely filled. In effect, the abyss code runs per-edge-tile rather than per-image-pixel and the cost almost vanishes.
Anyway: you get a very flexible abyss system which has almost no memory or CPU cost. You can use the same system to implement zero-copy crop and paste operators, of course.
John
GeglBuffers already allows shared tiles, but they are not fully used in the locations where they should (gegl_buffer_copy, which is also used by for instance gegl_buffer_dup should be duplicating the tile data by hooking into the circular list of shared tiles.)
/Øyvind K.
Hello Utkarsh,
Maybe implementing multi-threading in GEGL would be a good, not yet taken, project?
(Note that I do not have enough of a broad/detailed view on GEGL to make this suggestion from a position of authority.)
Thanks.
Are you sure that Multi threading has not been taken. I feel ( I may
surely be wrong) that the project of the adding of Gpu support should
deal with that. Basically What I was planning for the GPU support
project was to create a type of multiple parts or divide the
GEGLBuffer tiles or kind of break up the buffer into different parts.
and to store them into either CPU or GPU or over the network(where
they can be accessed by HTTP) or diferent core of the CPU or RAM, and
to consider them as a distinct identity an to apply the GEGL
operatoins on them. There should be a memory map for it and so that
you can know where the tile is residing and then you can apply the
corresponding operation. This i believe could or infact be implemeted
in various threads as parallelization is obvious here. ( I am sure I
am wrong somewhere as I havent yet gone into the understanding of the
GEGL (as I had no time as I was looking for something to get some
money) ) (Please correct me where I am wrong)
I hope you wished to say about the multi threading at a higher level.
(If I am again not wrong)
with different threads at the same time.I am not exactly sure of it.
I also feel that multithreading at that higher level should been
already implemented. ( I am not at all sure of the above line, I
havent looked into the structure of GEGL much). It would be better if
you help me out.
Utkarsh Shukla
On 5/13/09, Nicolas Robidoux wrote:
Hello Utkarsh,
Dear Utkarsh:
I was talking about CPU multi-threading, that is, using multi-cores, e.g.
http://www.vips.ecs.soton.ac.uk/index.php?title=Benchmarks#Results_in_detail
And unfortunately, I am swamped, and consequently, I basically can't help.
I may be wrong, but I am pretty sure that GEGL does not multi-thread as of now.
Nicolas Robidoux
On Wed, May 13, 2009 at 5:35 PM, Nicolas Robidoux wrote:
Dear Utkarsh:
This is correct. GEGL has been designed to paralellize the rendering work-load and most of this architecture is in place. At an earlier stage when I initially tried this I had some locking issues and decided to discontinue that development at the time instead of destabilizing GEGL.
The first attempt was to split out the actual rendering from the graph manipulation, this would already be a great benefit for instance for GIMP since it means GEGL processing would happen in the background and be non-blocking.
After that is working, multiple GeglProcessors should be used concurrently (instead of just one working serially through chunks of the output image like it is now). Exchange of data should happen as extensions to the GeglBuffer architecture.
/Øyvind K.
Utkarsh:
Although clearly the two projects probably should not proceed without some mutual consultation, I feel that GPU and multi-core involve fairly seperate programming. For this reason, I would not be overly concerned that your fixing multi-core (say) would duplicate the GPU effort.
Clearly, some coordination would be desirable. However, in the nitty gritty, these are separate projects.
So you are suggesting to parallelize the Gimp image operation means that multiple GEGL processes should run at the same time. So currently the GEGL has graph manipulation and then the rendering. I am not sure how you tried to split the rendering from graph manipulation. Dou you mean to say that curretnly Gimp first processes the graph and then renders the whole of the image afterwards. So if I get a clear overview then what I feel that this thing is much different than the GPU thing as here the parallelization is needed at much higher level and just very below the Gimp interface infact on the interface the things should be parallel threaded. Am I correct??
Dear Utkarsh:
/Øyvind K. --
«The future is already here. It's just not very evenly distributed» -- William Gibson http://pippin.gimp.org/ http://ffii.org/
By having a dedicated thread that does the actual processing work, and reporting that results have finished rendering in the main thread (which is with the application/GUI/graph manipulation code).
Not quite sure I understand what you mean. The paralellization in GEGL should occur within the existing API and be splitting up the workload into paralell rendering tasks for different subregions of the output image.
GEGL is a demand driven caching data-flow based rendering system. First the graph is set up, nodes connected and properties set. Then either a sink node is processed or more normally like in a GIMP use case; a GeglProcessor is set up with a full region to be computed. GEGL doesn't compute all data at once but splits the requested region into rectangular chunks and processes these chunks in paralell. As chunks are computed GEGL signals will be emitted on the node reporting which areas have been computed. Behind the scenes a GeglProcessor could be doing it's real work in a thread, or even create multiple GeglProcessors that operate on separate parts of the output in paralell. Going beyond this, with buffers shared between processes and hosts it should be possible to extend the processing even further. After this GSOC I hope to have the means to have a unified memory architecture for GeglBuffers, at that stage GEGL could perhaps even do portions of the processing and|or compositing on the GPU (IO will be a concern in this case).
/Øyvind K.
In GEGL, image data that needs processing is subdivided into rectangles (I'm not sure how these rectangles map into GeglTiles though). Currently, to process a portion of the image data, a GeglNode iterates over the rectangles and sequentially instructs the relevant operation code to execute over those rectangles.
There are two forms of parallelization that we can tackle above. One is to let an operation process all pixels of the rectangle in parallel, as in my project's case. The other is to get rid of the sequential manner of processing rectangles. That is, different rectangles are assigned to different CPU threads that call the same operation. Moreover, a thread can be instructed to process its rectangle in the GPU or in the CPU enabling us to use different computation devices in parallel.
I could be wrong, but my intuition tells me that implementing the latter parallelization is difficult to tackle in my GSoC's timeframe. Especially because locking issues (as Øyvind mentioned before) are time-consuming to debug and fix.
The reason why a certain level of communication is required to implement both projects is that we need to agree on where tiles and rectangular pixel data are stored/cached (GPU memory vs. main memory) and when.
As utkarsh expressed previously, we should be more concerned about how and when pixel data are transfered from main memory to the GPU. Transfer operations from one computation device to another is expensive.
My current plans (as outlined in a different post) assume that a single computation device will be used for each GeglNode and its GeglOperation. A node whose associated operation publishes GPU-support will create GPU-based buffers only, CPU/RAM-based buffers otherwise. It doesn't matter what computation device is used by the neighboring nodes as they will be concerned with their own computations and transfers can still be taken cared of by the relevant accessor methods.
Cached GeglTiles in my current plans are always stored in GPU memory for GPU-based buffers, hence, the need for a GeglTileFactory to decouple tile creation from tile access. I am sure that this mechanism will disappear when we move to rectangle-level parallelization, but still, how and when do we store tiles in GPU memory then?
Øyvind, I'd appreciate more thoughts regarding the unified memory architecture you were talking about. For example, does your thoughts involve how and where pixel data are stored internally? Or is it just the access you are talking about?
Kind regards, Daerd
This i quite correct..
Let us start the we will see
I am not sure about this. Your work woulbe like to access the memory map and
find out where the tile is residing. Then Correspondingly you have to apply
the operation if it is CPU or GPU.
We need to talk upon the structure of the memory map.I also (not quiet sure)
was thinking that since the we are implementing the two level
parallelization so why not justcreate the memory map at the lowest level. I
mean if I put a rectangle into a GPU then I would write information like all
the tiles are in GPU instead of the rectangle in GPU. they can be grouped
but i feelIn the unified memory the tiles must be written. It would be
better if someone looks into this logic.
I would say let them flow freely. you can track them by memory map
Are You sure?
If Gpu memory is free we try to use it, but we will have to find a function to optimize the storage and data Transfer.
I dont know about the locking issue and would prefer if someone explains it bettter.
Here is a link to the
Nona-GPU: Image Remapping on the Graphics Processor
talk:
http://river-valley.tv/nona-gpu-image-remapping-on-the-graphics-processor/
Thank you for your help, utkarsh.
On Thu, May 14, 2009 at 8:19 AM, utkarsh shukla wrote:
I am not sure about this. Your work woulbe like to access the memory map and find out where the tile is residing. Then Correspondingly you have to apply the operation if it is CPU or GPU.
This is an interesting architecture. Is the memory map a hash table where the GeglBuffer translates tiles into OpenGL textures? I guess we still have to provide a mechanism to specify whether or not a GeglBuffer should map tiles to the GPU if at all. This is useful in the case where a node has an attached GeglOperation that doesn't support OpenGL (i.e. doesn't implement a shader). We can let GPU-supporting GeglBuffers (meaning, buffers which can map tiles to the GPU) allocate GPU memory first and fall back to returning normal tiles when the allocation is unsuccessful. This is, however, a greedy approach and would prefer a better algorithm to decide whether or not a tile should be mapped to the GPU.
We need to talk upon the structure of the memory map.I also (not quiet sure) was thinking that since the we are implementing the two level parallelization so why not justcreate the memory map at the lowest level. I mean if I put a rectangle into a GPU then I would write information like all the tiles are in GPU instead of the rectangle in GPU. they can be grouped but i feelIn the unified memory the tiles must be written. It would be better if someone looks into this logic.
I'm not sure if I'm getting you right. But I'm going to stab in the dark, anyway. :) What about with rectangles that don't fall on tile-boundaries? By that, I mean that a certain rectangle may start somewhere in the middle of the first row/column of tiles and/or end in the middle of the last row/column of tiles, like so:
| |R|RRRRR|RR| |
| |R|RRRRR|RR| |
| |R|RRRRR|RR| |
| |R|RRRRR|RR| |
(the rectangle enclosing the Rs is the requested rectangle of pixels)
Kind regards, Daerd
Thanks Nicolas. I've seen the video just this morning. As expected, it turned out to be my general definition of "awesomeness". He discussed quite a few pitfalls that should apply and not apply to GEGL. Quite particular is pitfall #4 where he got ~500ms to render the image but got it transfered from the GPU back to the CPU in ~3 seconds! That's just crazy!
Hopefully, we will be able to dodge that issue by uploading textures whilst the GPU is computing. This needs the rectangle-level CPU parallelization we are discussing as of the moment. I am now convinced that the latter parallelization is needed to extract the GPU's (evil) power.
Another issue not discussed by the talk is OpenGL texture formats. I suspect (though I'm not quite sure, like I always am :) that Nona-GPU doesn't deal with different color formats. OpenGL can only process 1-4 tuples of vector data in the shader level, so I can't imagine how we can provide support for Babl formats with channels exceeding 4. Also, current generation GPUs don't support double-precision floating point data. Providing support for RGBA doubles, for example, is difficult.
Kind regards,
Daerd
J. Perpetua writes:
My impression is that currently everything is done with float[4] RGBA pixels (converted from/to whatever by BABL) within GEGL operations.
Yeah, but even that is a bit murky. It has something to do with GPU vendors and what they support as rendering targets (shader output)[1]. Also, I'm not sure if we should implement GPU-support for Babl conversions, but just in case we should, conversions could be done with shaders.
On Thu, May 14, 2009 at 12:58 PM, Nicolas Robidoux wrote:
J. Perpetua writes:
OpenGL can only process 1-4 tuples of vector data in the shader level, so I can't imagine how we can provide support for Babl formats with channels exceeding 4. Also, current generation GPUs don't support double-precision floating point data. Providing support for RGBA doubles, for example, is difficult.My impression is that currently everything is done with float[4] RGBA pixels (converted from/to whatever by BABL) within GEGL operations.
| |R|RRRRR|RR| |
| |R|RRRRR|RR| |
| |R|RRRRR|RR| |
| |R|RRRRR|RR| |
+-----+-----+-----+(the rectangle enclosing the Rs is the requested rectangle of pixels)
I was really very very dumb when i said about the tiles, actually I did not looked into the structure of GEGL properly. I just was proposing that the we should find out a way so that the map is not two level based. (I hope I am correct). I am very very sorry for not being able to spend much time in this as I am frantically searching for some place to work and some income. My work at hotel takes more time and I dont get much money but I have no option so I am just a bit busy looking for a job in coading, buts its been hard luck for me. :P
I hope to discuss upon the final structure to be implemented on both the level.
