automake version problem
7 of 7 messages available
automake version problem gbstack 11 May 15:32
  automake version problem Roman Joost 11 May 15:52
   automake version problem gbstack 11 May 16:01
    automake version problem Marco Ciampa 11 May 23:29
     automake version problem gbstack 12 May 15:40
   automake version problem gbstack 11 May 16:03
  automake version problem huntxu 11 May 15:59
gbstack
2009-05-11 15:32:41 UTC (almost 16 years ago)
after I used git to download gimp-help-2 clone,I ran this command: /./autogen.sh --without-gimp ALL_LINGUAS="en zh_CN"/
but I got this error message: /Looking for latest automake version ... You must have automake 1.10 or newer installed to compile gimp-help-2. Download the appropriate package for your distribution, or get the source tarball at ftp://ftp.gnu.org/pub/gnu/automake/ Please install/upgrade the missing tools and call me again.
/however, my automake version is 1.7.9...
anyone can tell me what I should do?
Roman Joost
2009-05-11 15:52:29 UTC (almost 16 years ago)
You need to install automake version 1.10 to run the autogen.sh. Not sure which distribution you're using, but it should be provided by the most.
Cheers,
huntxu
2009-05-11 15:59:46 UTC (almost 16 years ago)
anyone can tell me what I should do? _______________________________________________ Gimp-docs mailing list
Gimp-docs@lists.XCF.Berkeley.EDU
Mine is 1.10.2 on archlinux.
What linux distribution are you using? There must be binaries of automake.
You can also download and complie by yourself.
gbstack
2009-05-11 16:01:54 UTC (almost 16 years ago)
oh,I'm using ubuntu 8.04.
You mean that although I have installed automake 1.7.9,only automake 1.10 can finish it?
Thanks for replying:)
Cheers,
gbstack
2009-05-11 16:03:53 UTC (almost 16 years ago)
Cheers,
Marco Ciampa
2009-05-11 23:29:24 UTC (almost 16 years ago)
I think you better have to upgrade to 9.04 and, btw, it's a lot faster! :-)
gbstack
2009-05-12 15:40:40 UTC (almost 16 years ago)
yeah,I think I should have a try:)
