help with git
10 of 10 messages available
help with git Marco Ciampa 19 Apr 17:17
  help with git julien 19 Apr 21:55
   help with git julien 20 Apr 07:30
    help with git Ulf-D. Ehlert 20 Apr 12:54
     help with git Roman Joost 20 Apr 13:20
      help with git Ulf-D. Ehlert 27 Apr 13:27
       help with git Roman Joost 27 Apr 14:06
        help with git Ulf-D. Ehlert 29 Apr 14:02
  help with git Ulf-D. Ehlert 21 Apr 12:44
   help with git Marco Ciampa 21 Apr 22:54
Marco Ciampa
2009-04-19 17:17:52 UTC (about 16 years ago)
help with git
I've successfully 'cloned' the gimp-help-2 repo in my brand-new portable. Now, done the configure/make steps I see as modified with 'git status' all po/it/* files.
I see this:
$git status # On branch master
# Changed but not updated:
# (use "git add ..." to update what will be committed) #
# modified: po/it/appendix.po
# modified: po/it/concepts.po
# modified: po/it/dialogs.po
# modified: po/it/filters.po
# modified: po/it/filters/alpha-to-logo.po # modified: po/it/filters/animation.po # modified: po/it/filters/artistic.po # modified: po/it/filters/blur.po
# modified: po/it/filters/combine.po # modified: po/it/filters/decor.po # modified: po/it/filters/distort.po # modified: po/it/filters/edge-detect.po # modified: po/it/filters/enhance.po # modified: po/it/filters/generic.po # modified: po/it/filters/light_effects.po # modified: po/it/filters/map.po
# modified: po/it/filters/noise.po # modified: po/it/filters/render.po # modified: po/it/filters/web.po
# modified: po/it/gimp.po
# modified: po/it/glossary.po
# modified: po/it/introduction.po
# modified: po/it/menus.po
# modified: po/it/menus/colors.po
# modified: po/it/menus/colors/auto.po # modified: po/it/menus/colors/components.po # modified: po/it/menus/colors/info.po # modified: po/it/menus/colors/map.po # modified: po/it/menus/edit.po
# modified: po/it/menus/file.po
# modified: po/it/menus/help.po
# modified: po/it/menus/image.po
# modified: po/it/menus/layer.po
# modified: po/it/menus/select.po
# modified: po/it/menus/view.po
# modified: po/it/preface.po
# modified: po/it/toolbox.po
# modified: po/it/tutorial.po
# modified: po/it/using.po
# modified: po/it/using/preferences.po #
# Untracked files:
# (use "git add ..." to include in what will be committed) #
# .xml2po.mo
# AUTHORS
no changes added to commit (use "git add" and/or "git commit -a")
But I haven't changed anything and I do not want to commit some timestamp change.
What can I do?
TIA
julien
2009-04-19 21:55:59 UTC (about 16 years ago)
help with git
I cloned three times, and after running ./autogen.sh, I never had your problem...
Julien
julien
2009-04-20 07:30:56 UTC (about 16 years ago)
help with git
because I have not used 'make pot' up yet. I only pushed copy-pasted ready files from my svn folder to the Git folder.
I think this problem is due to 'make pot' that updates pot revision dates in all pot files.
Julien
Ulf-D. Ehlert
2009-04-20 12:54:28 UTC (about 16 years ago)
help with git
julien (Montag, 20. April 2009, 07:31):
We can add a 'touch -r srcfile potfile' to prevent 'make' updating the po files.
According to the autoconf manual, this may lead to "timestamp truncation problems" on some "ancient" systems, but I think we should ignore this until somebody reports a problem.
Ulf
PS: I will (mis)use the doap file as a trainings object for learning git. :-| @Roman: shouldn't the list of maintainers in the the doap file be the same as in MAINTAINERS?
Roman Joost
2009-04-20 13:20:49 UTC (about 16 years ago)
help with git
Ulf
I actually thought the the doap file would be now *the* compulsory file for managing maintainers. Thats why I added more than me to the doap file as a maintainer.
Appearently that is not the case. If you really need to, update the MAINTAINERS file. I reckon it'll go away in the future...
Cheers,
Ulf-D. Ehlert
2009-04-21 12:44:10 UTC (about 16 years ago)
help with git
Marco Ciampa (Sonntag, 19. April 2009, 17:17):
$git status
# On branch master
Try 'git checkout po/it' (don't know if it works recursively, otherwise use "find po/it -name '*.po' | xargs git checkout"), this should revert any changes and touch the po files, so that pot files are newer than src files and po files are newer than pot files, which should make 'make' happy again.
Bye,
Ulf
Marco Ciampa
2009-04-21 22:54:12 UTC (about 16 years ago)
help with git
$git status
# On branch master
Bye,
Ulf
Thank you Ulf, I've erased the entire local repository and re-make-d it. Now 'make' work as expected, many thanks again!
bye
Ulf-D. Ehlert
2009-04-27 13:27:35 UTC (almost 16 years ago)
help with git
Roman Joost (Montag, 20. April 2009, 13:20):
"DOAP is primarily intended for computer consumption..."
Why? It's a useful information at a prominent place, while nobody will read 'gimp-help-2.doap'.
Ulf
Roman Joost
2009-04-27 14:06:19 UTC (almost 16 years ago)
help with git
Hi Ulf,
My assumption was based on this mail:
http://www.mail-archive.com/gnome-infrastructure@gnome.org/msg00894.html
Now, because that's already a year old, things must have been changed already ...
I just saw both files read by the gnome infrastructure, not really by people.
Cheers,
Ulf-D. Ehlert
2009-04-29 14:02:00 UTC (almost 16 years ago)
help with git
Roman Joost (Montag, 27. April 2009, 14:06):
http://www.mail-archive.com/gnome-infrastructure@gnome.org/msg00894.h tml
An interesting idea mentioned in that thread was generating MAINTAINERS and AUTHORS from the doap file.
Ulf
