git clone
git clone Ulf-D. Ehlert 18 Apr 19:03
  git clone redforce 24 Apr 03:25
Ulf-D. Ehlert
2009-04-18 19:03:37 UTC (about 16 years ago)
git clone
I have the following problem:
I started 'git clone ...' (with a very slow dial-up connection), loading 40% or so (139MB in .git/objects/tmp_pack_a4emJI), then downloading was interrupted.
How can I restart without losing the downloaded files? The User's Manual just says
"The initial clone may be time-consuming for a large project, but you will only need to clone once." but apparently it doesn't tell how to clone once if something went wrong.
Using Subversion, that was easy:
SVN git -----------------------------
svn checkout git clone
interrupt
svn checkout ???
Ulf
2009-04-24 03:25:09 UTC (about 16 years ago)
git clone
I found some postings stating that this is not possible. I don't know if it's true, but this may help you indirectly (depending on what you want to do):
http://git.or.cz/gitwiki/GitFaq#head-4accce922b66f2a1188d636bbd20d259db089187
Q: How do I do a quick clone without history revisions? A: If you just want to checkout the latest source code of a project who may has very large repo, you can use
git clone --depth 1 your_repo_url
