gegl cmd-line ppm patch
gegl cmd-line ppm patch Henrik Akesson 14 Apr 11:27
  gegl cmd-line ppm patch Martin Nordholts 20 Apr 07:19
   gegl cmd-line ppm patch Henrik Akesson 20 Apr 10:24
    gegl cmd-line ppm patch Martin Nordholts 21 Apr 19:41
Henrik Akesson
2009-04-14 11:27:18 UTC (about 16 years ago)
New patch...
Cheers,
Henrik
[ppm_bin.diff]
Patch from Henrik Akesson that adds ppm output file format on the command-line application. It is done by parsing the filename extension of the --output parameter, which is used to choose the output node type created (png-save or ppm-save). * bin/gegl.c
* bin/gegl-options.c
* bin/gegl-options.h
Martin Nordholts
2009-04-20 07:19:08 UTC (about 16 years ago)
Henrik Akesson wrote:
New patch...
Hi Henrik
Could we through IRC arrange me doing a git pull from you through e.g. a temporarily running git-daemon on your side? Would be nice to get a git workflow going for GEGL (and GIMP). Once I have pulled I can easily review, test and finally commit when things look OK.
BR, Martin
Henrik Akesson
2009-04-20 10:24:01 UTC (about 16 years ago)
Martin,
Well, I've got a git repo set up, even though I didn't start using it yet (will very soon).
I'll have a look to see if I can set up my computer for public access at home (living in a shared appartment and don't have the passwd for the router).
Would be good if you could add the patches I've sent "manually" and then in the future I'll make sure that you can do it the "git way".
Cheers,
Henrik
2009/4/20 Martin Nordholts :
New patch...
Hi Henrik
BR, Martin
Martin Nordholts
2009-04-21 19:41:18 UTC (about 16 years ago)
I've done that now
BR,
Martin
2009-04-21 Martin Nordholts
Add ppm output file format on the command-line application. It is done by parsing the filename extension of the --output parameter, which is used to choose the output node type created (png-save or ppm-save).
Patch from Henrik Akesson.
* bin/gegl.c * bin/gegl-options.c
Add a portable pixmap loader and saver that can read/write both the ascii and the binary formats.
* operations/external/Makefile.am * operations/external/ppm-load.c * operations/external/ppm-save.c
